Old 20th Jul 2022, 11:08 pm   #1
roadracing57
Default PYE P.J 501TG Cabinet restoration
Hi first Cabinet restore here. Have probably researched too much about cabinet restoration that i am completly confused now. Top of it was very bad, and small chips missing of the veneer, will get veneer ordered so hope to patch these up. as you can see i have removed the finish on the top. the rest actually while there is a few scartches here and there is in good shape so am just going to clean it up and may spray clear laquer over it when ready?
Question is how do i do the top and with what?
Do i spray a halfords clear lacquer over top before i do anything and then use an oil or stain it?
What colour stain do i go with to try match to the bottom as close as possible.
Or was this cabinet french polished when it was leaving the factory and that is the finish i should go with.
Any help would be great.
thanks,
Phelim
ID:	261238   Click image for larger version
ID:	261239   Click image for larger version
ID:	261240   Click image for larger version
roadracing57 is offline
Old 22nd Jul 2022, 11:29 am   #2
Silicon
Default Re: PYE P.J 501TG Cabinet restoration
I don't know much about cabinet restoration but will hazard a guess that they originally used a tinted cellulose spray finish on bare wood.
Silicon is offline
Old 23rd Jul 2022, 7:13 pm   #3
Dickie
If you're ordering veneer specially then get some spare so you can experiment to get the right finish. If you're going to stain it then start with a light shade. It's easy to stain the veneer darker, but almost impossible to stain it lighter.
Regards,
Richard, BVWS member
Dickie is offline
