Old 4th Nov 2021, 12:47 pm   #1
TALKINGWITHPYE
Location: Carrickfergus, County Antrim, Northern Ireland, UK.
Default Dan 486 desktop
Hello, I have a problem with a 486 desk top. When I switch it on I get a No Video Input but when I press the reset several times it displays garbage on the screen then it boots up and works fine. Would anyone have any ideas as to what may be happening? I use this machine to program old ex pmr radios on to amateur radio bands.
TALKINGWITHPYE is offline
Old 4th Nov 2021, 1:50 pm   #2
SiriusHardware
Default Re: Dan 486 desktop
If memory serves me correctly you used to have another DOS-era PC which you used for this job but you started to have comms errors on that one, and this one must be its replacement.
If you still have the other one the first thing I would try is to swap the PSU from the other machine into this one, assuming they both use 'AT' type interchangeable power supplies with the same connectors.
If not, try
-Turning the PC on
-Press reset as many times as it takes to get it to start
-Leave it running for at least an hour
-Turn it off for 30 seconds
-Turn it back on.
When you do that, does it start by itself, or do you still have to use the reset button to get it to start?
SiriusHardware is offline
Old 5th Nov 2021, 4:19 pm   #3
TALKINGWITHPYE
Thanks SiriusHardware, you hit the jackpot, I replaced the power supply and my PC is back to normal. I was fortuneate in that I had two supplies in the garage, one was a dud but the other one worked fine.
Dave
Old 5th Nov 2021, 7:45 pm   #4
SiriusHardware
Glad that worked out for you. Lucky you had those spares as it might be quite hard to find an AT PSU now.
Old 6th Nov 2021, 5:49 pm   #5
TALKINGWITHPYE
Yes I had a look inside the one I took out and found it was filthy so I think something was perhaps messing up the chopping frequency. I will try a few tests with it after I get an air duster to remove the muck.
