10th Oct 2021, 11:21 pm | #21 |
Re: Commodore PET 2001 voltage regulators
Thanks for checking those connections - when stating the results of resistance measurements could you also please state the units of measurement as well as the figures (so Ohms, K-Ohms M-Ohms, etcetera). I guess with your stated figures of 620 and 580 you mean Ohms, but maybe not.
If your meter has a 'diode test' range on it could you please do them again but this time measure all five with the probes placed red to tapered end, black to flat end, and then measure them all again but this time with black probe to tapered end, red probe to flat end. In this mode your meter indicates the voltage drop across the diode rather than its resistance. Incidentally these measurements need to be made with JP8 plug unplugged, otherwise you may be measuring the mains transformer as well as the diodes. |
11th Oct 2021, 9:43 am | #22 |
For ease of reference I'm attaching a copy of the 320351 board layout. This might help in identifying test points in relation to the schematic as component designations are clearly marked.
Alan |
11th Oct 2021, 11:24 am | #23 |
I can't help feeling that it would be a good idea to lift one end of each of the suspect rectifier diodes (CR1, CR2, CR4, CR5 & CR3) in order to carry out proper open circuit diode tests. If nothing else this would at least eliminate them from our enquiries. In circuit testing can produce such confusing results. The solder pads are quite large and with a little deft application of the soldering iron it should be possible to avoid troublesome board damage.
It does concern me a little that the board has been worked on before which can make things tricky in diagnostic terms especially if the previous repairer gave up and consigned the PET to the loft in frustration. I've just switched on my PET 2001 for the first time in a while and am relieved to say that it's still working well. Alan |
11th Oct 2021, 12:00 pm | #24 |
I'm not sure (because we don't know Retromit well yet) how confident he (or possibly she) is at desoldering components cleanly especially in antique double sided PCBs, so I was hoping to see an obviously bad diode without desoldering any, but if the results are inconclusive then you are right, it may be necessary to measure them with one end disconnected from the circuit. If we do identify a bad one in-circuit then it would be easier and less stressful to the PCB to snip out the diode body and remove the legs separately.
Going all the way back to #1 we can see that the machine has worked for a period, however brief, so we can say that the various mods are harmless and probably original, except for the socketing of the RAM which was obviously done when someone had a RAM problem at some point in the past. I have some concerns that the machine running without +5V but with the other supplies still present may have caused some device damage that was not there originally. Last edited by SiriusHardware; 11th Oct 2021 at 12:08 pm. |
11th Oct 2021, 12:31 pm | #25 |
Let's see how the OP feels about a bit of soldering work. With regard to possible damage due to having no +5V lines the fact that the PET briefly showed signs of life again @ post #11 is a hopeful sign. However this again indicates a possible poor connection/joint rather than complete component failure. I must admit that I'd be doing a bit of wiggling and prodding (plastic chopstick being the instrument of choice!).
Alan Last edited by ajgriff; 11th Oct 2021 at 12:39 pm. |
11th Oct 2021, 1:11 pm | #26 |
The case history as I understand it is that when acquired it had an apparent display fault, was fixed by replacement of the screen RAM, was turned off apparently working but on next start, would not turn on and, on investigation, had lost its 5V supplies.
The machine has not been seen working since, so we'll just have to see what happens once the supplies are up again. |
11th Oct 2021, 1:25 pm | #27 |
My understanding of post #11 is that the PET did briefly produce a random character screen after the OP had carried out some of the suggested checks before dying again.
Alan |
11th Oct 2021, 1:57 pm | #28 |
Indeed so, I should pay more attention.
11th Oct 2021, 9:00 pm | #29 |
Thanks for all the replies/thoughts, and apologies for my late update on these. Just from some of the replies, I've included the original screen shot of when I first aquired the PET. It was from this that I replaced the video RAM which (briefly) showed the Commodore BASIC screen. After switching the PET off, then back on, this is where I am now. It did briefly kick into life (with the garbled screen picture I posted), but since them the screen has been blank. I'll start to go through the other replies, and some more tests that have been carried out. Regarding soldering, I'm happy to do this. I have worked previously on other 8-bit machines, and have soldered/desoldered. This is the first time I've ever had the chance to look over a PET. Right, I'll update with the rest of the findings! Thanks, Tim. |
11th Oct 2021, 9:07 pm | #30 |
Yes, that pattern is more reminiscent of a problem with the display RAM which you obviously did fix when you replaced that. Just have to get to the bottom of this ******* power problem and then we'll see where we really are.
Good to know that you are confident with soldering, we never really know where to pitch advice initially - if we aim too low we run the risk of patronising someone who has been working with electronics for years but if we aim high we could end up frightening off a newcomer who doesn't understand a word of what we are saying. We usually find the right level in the end. |
11th Oct 2021, 9:08 pm | #31 |
For the diode test, I carried out the following. I believe the output is in ohms, but with this being a basic multimeter, there is no value for the unit.
Multimeter on diode test and red end tapered, blank flat. All the bottom four diodes (X and Y, plus the two others near the silver capacitor) registered a value of '1'; the diode (W) near the capacitor registered 1689. When black was on the tapered end, and red on flat: The bottom four diodes (left to right) measured: 1 = 570 2 = 591 3 = 578 4 = 583 W (near the capacitor) = 532 |
11th Oct 2021, 9:10 pm | #32 |
I looked over the resistance readings again, and apologies for missing the units that should have been applied. When setting the multimeter to 2000 ohms range, the following was carried out:
Black on flat end, red tapered: All bottom four diodes registerd '1'. The diode near the capacitor (W) measured a 4 figure value. Red on flat end, black tapered: All showed a four figure value in the 2000 ohms range. |
11th Oct 2021, 9:13 pm | #33 |
If your meter was on 'Diode test' (was it?) then those readings in #31 look broadly OK. If you try doing one of the later group again you may see a decimal point ahead of the three figures, ie, '.570'. If so that means a forward voltage drop of 0.570 - generally speaking a forward voltage reading of around 0.5V to 0.6V is healthy for a Silicon diode, which these are.
Your resistance readings also look OK to me. So it doesn't look like that is it either. |
11th Oct 2021, 9:14 pm | #34 | |
11th Oct 2021, 9:16 pm | #35 | |
11th Oct 2021, 9:23 pm | #36 |
I am just wondering why there was a difference in the diode test for the diode near the capacitor (marked W on the picture you gave). When the multimeter was on diode test with the red end on the tapered side and the black on the flat side, then all the other diodes registered a value of '1', whereas the 'W' diode registered 1689?
I thought they would all register '1'? |
11th Oct 2021, 9:36 pm | #37 | |
Going back to some measurements you made earlier -
Referring to the layout diagram kindly attached by AJ in post #22, please measure the DC voltage (with respect to 0V) on -CR1 / CR2 tapered ends (which I previously marked as 'Z') -JP1 pin 4 Electrically speaking, these are the same place / same circuit node so if they are not at exactly the same voltage there must be an open circuit or high resistance between them. If the voltage on 'Z' has changed again and is the same as the voltage on JP1 pin 4, then it looks as though we have an intermittent fault to contend with. I suppose this is to be anticipated since we have already seen the supply present, then absent, then briefly present, then absent again. By the way - what / where are you using for your 0V point to put the black meter lead on when measuring voltages? |
11th Oct 2021, 9:45 pm | #38 | |
If one of the diodes had been short-circuit or very low resistance (which is the most usual way for them to fail) then that would have been obvious even when measuring them in-circuit. There are times when it's reasonable to try to measure things in-circuit and times when you definitely should separate the suspect component from everything else it is connected to before trying to measure it. At the moment my feeling is the diodes are OK, but we may come back to them. |
11th Oct 2021, 11:14 pm | #39 | |
12th Oct 2021, 10:01 am | #40 |
If it's ever required, I still have the two test EPROMs with the daver2 and slothir's test code on them if that'll help. Happy to post them on to the OP of this thread.
