17th Mar 2021, 2:02 am | #1081 | |
Re: Non-working Commodore PET 3016
17th Mar 2021, 2:33 am | #1082 |
Can you run off a list of RAM chips that you could use so that I can have a look in the chest of drawers I rescued from a computer repair shop that shut down a good few years ago.
4116 might be close. 256K ones will be far too high but I might have 64K ones but they are still a bit high. |
17th Mar 2021, 3:53 am | #1083 |
There was a list of compatible memory in the pdf in post #1035.
I think the links could be changed to use 8 of 4116 type instead of 16 of the 8k. |
17th Mar 2021, 8:57 am | #1084 |
I think it's 4108s ideally as that would directly replace any faulty devices found, or possibly 4116 as Mark says. Slightly premature though, any apparent system RAM fault could still be down to a dud 74LS244 buffer.
17th Mar 2021, 9:27 am | #1085 | |
Alan |
17th Mar 2021, 9:28 am | #1086 |
I think the 4108s might be 4116s that have a defect in one half of the memory. So a 4116 could probably be used as a replacement for a defective 4108.
I think its the same as using 4164 in place of 4132. I can check the datasheets in more detail if we think we need to find replacements for some of the 4108s. |
17th Mar 2021, 10:00 am | #1087 | |
https://www.ebay.co.uk/itm/STC-4116-D-memory-ic-ram-QTY-8/393015482007?hash=item5b818c5697:g7kAAOSwMFhfrqUA The only problem is I can't find a datasheet for these STC chips but the seller seems to have dozens of them so upgrading to 32k could even be an option. Alan |
17th Mar 2021, 10:03 am | #1088 | |
I did remember you said that, but Refugee was saying he had an assortment of old ICs that he could look through, so who knows? |
17th Mar 2021, 10:20 am | #1089 |
Definitely worth seeing what Refugee can unearth.
*For Refugee's benefit the chips originally used by Commodore are listed in the PDF document attached to post #1035. Alan Last edited by ajgriff; 17th Mar 2021 at 10:30 am. Reason: Additional comment |
17th Mar 2021, 12:54 pm | #1090 | ||
https://www.petervis.com/Sinclair/Si...tatic_RAM.html - The ZX Spectrum had many of these ones (2N = 200ns?) originally fitted. Although it's not clear what speed 4D marked ones are. It doesn't seem that DRAM were ever 400ns, and that a higher single number on some were actually faster (and same coding may be used by other manufacturers): https://www.electronicspoint.com/for...m-parts.65261/ TMS4532 and OKI M3732 were the one-half reject faulty 4164's (= M3764's) (single rail) DRAM's DRAM IC's are inherently a 'square array', due to Row/Column addressing. So standard all-working sizes will be 1, 4, 16, 64, 256 etc. Most were 1bit only, so needed 8off. But later on 4bit ones (usually with 1 changed to 4 / an extra 4 inserted into part no.) were released, to minimise chip-count. And revised versions of many computers (and PC memory modules) used these. Last edited by ortek_service; 17th Mar 2021 at 1:06 pm. |
17th Mar 2021, 1:37 pm | #1091 |
Looks promising if the buffers turn out to be ok and Refugee doesn't manage to find anything suitable.
Alan |
17th Mar 2021, 2:10 pm | #1092 |
I only had a quick look last night.
I have definitely got 4164 and 4116 and several other bigger sizes like 256. Has a chip select line rearrangement board been looked at? If anyone has reverse engineered the PROM data to see 64K with an adapter board the land freed up by removing the faulty chips would easily accommodate it. It could then be repopulated with 4108s if any are found later. |
17th Mar 2021, 2:19 pm | #1093 |
That's great news! Out of interest how many 4116s do you have going spare?
Alan |
17th Mar 2021, 2:31 pm | #1094 |
I have not counted them or established if the drawers have all the same type in them.
Most of them are 1980s date codes. The chests of drawers were simply rescued and incorporated into my component store with any empty drawers populated with modern components as I needed the space. I am not sure exactly what I have got. There are some chips with very faded part numbers so a look with a digital microscope might reveal something. I will have a better look later today. |
17th Mar 2021, 2:33 pm | #1095 |
I think plan 'A' is to keep the machine as close to its current configuration as possible, so assume for the moment that there are no plans to add non-standard expansions. It may certainly be necessary to fit a set of 4116s or possibly just half-enabled 4116s as 4108 substitutes, if that is possible.
We should really wait and see what comes back from Colin, but I really appreciate Refugee having taken the initial step of looking to see what he has. |
17th Mar 2021, 6:44 pm | #1096 |
I've just been doing a bit of looking about. The pinout for the 4108 seemed remarkably hard to find but I got it eventually, so attached, the pinouts for the 4108 and 4116 respectively. From a connection point of view they seem identical so presumably the 4108 has nothing in the 'unused' half. I think Mark suggested as much earlier.
Am I right in thinking, in that case, that if we keep the machine linked for 16 * 4108 as it is now, we can replace individual suspect 4108s with 4116s without changing anything else, at least until the machine is up and running? |
17th Mar 2021, 7:01 pm | #1097 |
Seems plausible but I'm no expert as you know. Do you have a straightforward strategy for identifying faulty 4108s?
Alan |
17th Mar 2021, 7:18 pm | #1098 |
In the first instance, just to see if there are any suspicious differences in the signal levels on the data connections from the RAMs. As each RAM IC has one bit input and one bit output and shares its single-bit connection with only one other RAM, any visible anomaly on one of those nodes will hopefully narrow it down to 2 RAM ICs and the associated 74LS244 buffer.
Then there is also the possibility of either swapping the high and low banks in the hope that one is working, and / or switching off one half to see what difference that makes. We also have Slothie's test code, and I've also found another diagnostic ROM image which looks quite comprehensive and may also attempt to identify the actual faulty area. Obviously both of these will require EEPROMs or EPROMs to be programmed and an adaptor from the programmed device to the pin outline of the original PROM to be made, so that won't be the first line of attack, although it may not be far behind. |
17th Mar 2021, 7:26 pm | #1099 |
I think the hope is that by looking at each pair of inputs and outputs on the buffers we can see a problem on one of the data lines. Then by comparing that data line with the buffer control signals to determine if its the buffer failing to drive correctly or one of the two ram chips. Then from the ram control lines which of the two ram chips on that data line.
A ram test rom would probably help a lot. Its going to be difficult to capture ram access on the scope as the pet software is not going to be making regular access to ram. |
17th Mar 2021, 8:05 pm | #1100 |
Indeed, we should probably also have Colin check the RAS and CAS refresh signals going to each DRAM as well. Given the seemingly random pattern of IC failures we have found so far, it would be quite possible to have an as yet undiscovered fault in the refresh circuitry.
There was a recent discussion elsewhere on the forum about the relative merits of plastic vs. ceramic IC packages and there was some mention of plastic packages being prone to damage by moisture ingress. From the condition of the PROMs I have no doubt that the machine spent some time in a damp environment somewhere. I've only belatedly realised there is no CS or CE pin on these RAMs so that's why the UI10 / UI11 buffers are there, to gate the connection between the RAM inputs/outputs and the buffered address bus. |
