26th Jan 2021, 12:55 am | #261 | |
Re: Non-working Commodore PET 3016
Colin. |
26th Jan 2021, 5:29 am | #262 |
Most of us here have been using lead/tin solder for years without wearing gloves (I can't do precision work in gloves!) with no major ill effects. So yes, don't chew solder, wash your hands before handling food but other than that don't panic.
I would also worry that the gloves could be a hazard if you touch the soldering iron with them and they melt onto your skin. And I will never use anything but turned-pin sockets for my projects and repairs. The extra cost (and it's not too bad if you buy the full tubes from RS or somewhere like that) is minor compared to my time and stress tracing a 'silly' fault. I remember repairing a Whitechapel workstation where the processor, MMU, floating point chip, etc were all in turned-pin sockets but for some unknown reason the EPROMs were in 'normal' sockets. You guessed it, bad connections at the EPROM pins caused a lot of faults. |
26th Jan 2021, 8:56 am | #263 |
Hi Tony, I think you meant to say decades rather than years
Going off topic, just for a change. Back in the day we used to avoid RS for sockets or connectors, preference was to use Farnell where we could specify the manufacturer, Augat or Cambion etc. RS usually labelled with their own brand but not to the same standard. I wore out many turned pin sockets in the days of uv eproms after a few months of software upgrades every week. It was nice living in Birmingham, could get almost anything from the RS trade counter. One of the few nice things about Birmingham. Now I’m just experimenting with old ceramic parts I avoid the turned pin sockets, they grip too tight for the first 2 or 3 goes, so putting the same old chip in 2 or 3 different new sockets starts to risk breaking pins. |
26th Jan 2021, 10:03 am | #264 |
I've been using lead-tin solder since I was 11 and while I can't point to any definite side effects lead, once absorbed by the body, is not easily got rid of so it's best not to absorb it in the first place. I've never worn gloves either, but who can say whether my addled wits these days are just due to my being older, or at least partly due to accumulated lead?
Anyway - Like Tony I have been using lead-tin solder for decades and I am still here, so I think it's probably OK for Colin to use it every now and again. |
26th Jan 2021, 10:41 am | #265 |
There have been many studies of lead absorption by the skin and unless the lead is finely powdered or formed into a compound there is little risk of exposure. (e.g. https://pubmed.ncbi.nlm.nih.gov/3238426/ )
Unless your soldering iron is set to 1740 degrees C there is no lead in the flux smoke given off by the soldering process (its still wise to avoid breathing it in as it is all forms of smoke). |
26th Jan 2021, 12:48 pm | #266 |
The side contact sockets are rubbish, for sure, but can be mitigated, somewhat, by a few drops of contact cleaner/lube when putting the chips back in. This can slow the effect of the atmosphere getting into the gap and corroding the contacts. I don't recall seeing any ill effects from doing this ...
Even on a really good quality PCB, cutting out a 40 pin DIL socket is a pain I don't usually want to face! For best reliability the only solution is to solder the chip in! dc EDIT Removing a socket WITHOUT a vacuum de-soldering station - nooooo ! Last edited by dave cox; 26th Jan 2021 at 12:53 pm. |
26th Jan 2021, 3:00 pm | #267 | |
Unfortunately true. Ajgriff's suggestion of cutting the socket spars at top, middle and bottom and then wobbling each separated side from side to side to gradually snap all the pins may be the least bad option, although then you don't have a lot of pin left to get hold of with the tweezers (would have to pick them out from the bottom instead). |
26th Jan 2021, 3:05 pm | #268 |
The lead problem is worst in battery factories where the plates need to be clear of all oil based products before assembly.
When working with solder there is a layer of flux over it so there is far less risk. Pretty well all the solder related regulations are part of a "one kills all" policy that also covers lead acid batteries. It is well worth avoiding breathing flux fumes as they are more likely to be harmful than the lead in our solder. |
26th Jan 2021, 6:13 pm | #269 |
Hi all. Socket removed at the cost of some partially lifted pads on top (see attached photos).
I have gone through continuity tests for the pads that don't look 100% and can confirm that I still have continuity to either their destination, or the first point on their travel to their destination, so I think I may have got away with it. I have new sockets here, but I'm waiting for non-lead-free solder to turn up so I may be a few days before I can get the socket back it. I have again purchased turned sockets and normal sockets. If there's anything else I can do in the meantime, please shout. Otherwise I guess we're waiting for me to solder the new socket in place. Thanks all. Colin. |
26th Jan 2021, 7:02 pm | #270 |
There's not much we can do until you have the chip back in (in a socket). Can you say which of the top side pads (which pin numbers) you think are lifted? You've given us perfect look-down views of both sides but because of that it is difficult to see which pads are separated.
Separated top side pads are potentially a problem, so you are going to have to try to avoid this kind of damage in future. Avoiding any sort of damage at all would be even better . |
26th Jan 2021, 7:41 pm | #271 |
12,24,25,27,32,35 & 38
12 tests fine to UC3/15 24 & 25 are connected underneath to UB3/8 and UB3/11 and test fine 27 tests fine to UE10/6&7 32 tests fine to UE 9/4&5 35 does not connect to anything that I can see on the schematics 38 tests fine to R50 I did try - promise.... |
26th Jan 2021, 10:22 pm | #272 |
Is there a divider chain on the video circuit that could be tested without the cpu fitted?
Any risk of leaving the address lines floating with the cpu not fitted? |
27th Jan 2021, 11:43 am | #273 |
The video/monitor circuitry seems to have problems. As I understand it even with a faulty or missing CPU a functional video system would display a screen full of at signs (code 0x00) as shown below.
I think the focus here is to get the CPU working before moving on to look at the display issues. Alan |
27th Jan 2021, 12:36 pm | #274 | |
27th Jan 2021, 12:54 pm | #275 | |
All a bit academic really as this PET hasn't produced a display of any kind so far. Alan |
27th Jan 2021, 2:25 pm | #276 |
I looked at the schematics and its very different to the 2001 I am familiar with because of the use of dynamic memory and all the timing surrounding that. the phi2 does go to the video circuit but on cursory examination that mostly seems to be to do with access to the video RAM. But you may be right that it needs it for some reason, or if phi2 is stuck high or low it might blank the screen. I did think these machines had a CRTC chip but it seems that was later models (4000 series)
27th Jan 2021, 2:56 pm | #277 | |
Alan |
27th Jan 2021, 3:56 pm | #278 |
Solder's here so I'll get started later on and test continuity when I'm finished and report back.
With regard to the damaged pads (see posts 269 & 271), should I put some solder on those pads (they're all on the top side) before I solder the rest? Or will the solder drain through if I'm soldering from the bottom anyway? Thanks. |
27th Jan 2021, 5:13 pm | #279 |
The solder won't run through from the bottom to the top if you have separated the top pad from the conductive barrel inside the hole. In that case there are a couple of dodges, one being to solder the IC socket pin both on the bottom side of the PCB and the top side. You can't really do that with a conventional socket because you can't see the pins on the top side, they are hidden by the body.
Even with a turned-pin socket where you can see a bit of the IC pins on the top side you will need a pencil thin soldering iron tip to solder the top pads to the socket pins. There is another dodge, which is to repair the damage by passing a very fine strand of bare wire through the cleared hole, bending it over sideways as it emerges from the hole on the top side and bottom side and soldering it to the pads, taking care not to fill the hole with solder because you need to be able to fit the socket afterwards. The IC socket pin has to be able to pass through the hole alongside the fine wire. |
27th Jan 2021, 8:19 pm | #280 |
Rough sketches showing a cross section through a single VIA to illustrate repair methods. First sketch, how things are normally. The orange areas represent copper PCB pads and tracks. The gold coloured element is the component pin, grey is solder, brown is PCB material.
Second sketch, what happens when a top side pad gets separated from the VIA. There is no longer a continuous metal connection between the copper sleeve going through the barrel so solder applied to the lower pad and pin won't flow up through the hole and up onto the top of the pad and around the pin. You therefore have to reinstate the connection between the copper barrel and the top side pad somehow. Third sketch uses a thin strand of bare wire passed through the hole (shown green here) to repair the missing connection between the top and bottom pads. The strand has to be thin enough to let the socket pin pass through the hole as well. I would suggest baring around 3cm of the end of a piece of 7-strand insulated wire and peeling away just one strand and using a bit of that for the repair. Forth sketch reinstates the connection between the top and bottom pad by using the socket pin itself as the bridge between the top and bottom pads but to do this you have to solder the pin to both the bottom and top side pads. You can't do that if you use a conventional socket because you won't be able to get at the pins on the top side, so really a turned pin socket is the one to use if attempting this method, and even then you need a fine tipped iron which can get to the pin and top side pad without burning / melting the plastic frame of the socket. |
