Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 7th Nov 2022, 2:50 pm   #1
Aub
Aub's Avatar
Default Error 403
Just got this error when replying to the thread about the RS Output Transformer. I managed to reply on the second attempt ok. I then tried to edit the reply and got the error 403 again, so gave up.
This happened at approx 13.45
Aub
Life's a long song, but the tune ends too soon for us all.
Aub is online now
Old 7th Nov 2022, 3:52 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Error 403
Was this the post? https://www.vintage-radio.net/forum/...5&postcount=11
I've just edited it without problems.
paulsherwin is offline
Old 7th Nov 2022, 4:32 pm   #3
Aub
Aub's Avatar
Yes. I just wanted to add a smiley face at the end
Aub
Aub is online now
Old 7th Nov 2022, 4:42 pm   #4
paulsherwin
I can't see anything wrong with the post, and my being a moderator wouldn't stop me getting database system errors like 403s. We may never know what the problem was. Paul Stenning will see this thread at some stage and it's his decision how to proceed.
Thanks for the report.
Old 7th Nov 2022, 6:21 pm   #5
Paul Stenning
Administrator
Paul Stenning's Avatar
I can add a after the ? with and without a space between with no problems when I preview.
I'd need to know the exact text entered which causes the error, probably best as a screenshot. The shortest text that causes the problem to occur consistently.
If you are using emojis from a mobile device though, they don't work correctly here and are outside the area I would try to get fixed. Only the smilies within the forum system are expected to work.
Paul Stenning
Paul Stenning is online now
Old 7th Nov 2022, 6:45 pm   #6
paulsherwin
That's a good point. Emojis are unicode characters which aren't supported, and trying to use them will produce unpredictable results.
Old 7th Nov 2022, 8:44 pm   #7
Aub
Aub's Avatar
I used the one from the forum, as I know the ones on my phone give strange results. It's no big deal and I haven't seen it since. It's just that someone said that you wanted to know if it happened since the 403 error someone had the other day.
Thanks
Aub
Aub is online now
Old 7th Nov 2022, 10:38 pm   #8
Terry_VK5TM
Terry_VK5TM's Avatar
Just to add the problems of accessing the site, I got this at 11.27 UTC (last night Oz time). I tried several times a few minutes apart.
All other websites I visited either side of that time opened without problem.
Affected both Firefox and Chrome browsers.
Name:	Forum message 11 27 utc.jpg
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 8th Nov 2022, 1:55 pm   #9
Dickie
I have just tried to start a new thread with a few pictures attached and when clicking on the preview or submit new thread buttons I get error 403. No emojis. Removing the pictures made no difference. How best to investigate this?
Richard, BVWS member
Dickie is offline
Old 8th Nov 2022, 2:30 pm   #10
paulsherwin
Please attach a screenshot of the text you're trying to post.
Old 8th Nov 2022, 2:37 pm   #11
Dickie
Here is the text copied and pasted:
I collected this from forum member RichardGM a couple of days ago thinking it would be a nice winter project to bring this once-noble set back to its best. On removing the back to have a quick look round I was surprised to be presented with a set of B9A and B7G valves. Looking further the loudspeaker and output transformer were rattling around loose in the cabinet. And then I looked at the back of the rear panel to see a written note “rebuilt in April ’59 “ with all the valve changes noted.
I can only guess that this must be an unfinished project. It seems to have the original mains transformer, but there is no obvious modification to achieve the necessary 6V heater supply. It must have taken some serious work to put in a different set of valves , not exactly equivalents, and change some component values to suit. I wonder if it ever got as far as testing? The loudspeaker was not connected to anything, clearly having its connections severed and replaced with a horrible choc-block. The metal bracket it was resting on is either not original or there is a bit missing, as when all is lined up together the speaker doesn’t line up with it’s hole in the cabinet. Nor is there enough room to fit the output transformer in its normal position. Perhaps the rebuilder lost interest in it before finishing.
So could this have ever worked?
- Odd I can post it here but not in a new thread?
Have tried posting it a bit at a time and eventually it all worked. It will remain a mystery. thanks for the attention Paul. maybe delete these posts?
Dickie is offline
Old 8th Nov 2022, 2:51 pm   #12
paulsherwin
What was the title?
The double quotes around "rebuilt in '59" look odd. Have you copied the text from a word processor which has done some fancy formatting?
Old 8th Nov 2022, 2:54 pm   #13
Dickie
https://www.vintage-radio.net/forum/...23#post1512123
Dickie is offline
Old 8th Nov 2022, 2:58 pm   #14
paulsherwin
I can't account for that, but those double quotes do look like Unicode characters to me. As said earlier, they will produce inconsistent and unpredictable results.
Old 8th Nov 2022, 3:04 pm   #15
Dickie
Originally Posted by paulsherwin View Post
What was the title?
Yes! As recommended by others I compose lengthy posts in MS word and then CTRL C and CTRL V. A point to watch out for in future.
Dickie is offline
Old 8th Nov 2022, 3:19 pm   #16
paulsherwin
Just use something like Notepad or Wordpad for drafting. It'll probably run faster too.
I think you can stop Word messing around with quotes like this, but can't remember how to do it.
Old 8th Nov 2022, 7:09 pm   #17
Philips210
I was wondering if its anything to do with an apostrophe in the '59 appearing between the double quotation marks.
Symon
Philips210 is offline
Old 9th Nov 2022, 12:02 am   #18
SiriusHardware
A reminder that was getting the same error occasionally when merely clicking on links to move from reading one forum post or thread or subsection to another. It hasn't happened to me since the weekend before last though.
SiriusHardware is online now
