Old 14th Feb 2009, 1:34 pm   #1
Giulio Maiocco
Giulio Maiocco's Avatar
Default Bush TV22 restoration: mission impossible!
Hello to everybody,
some time ago, I bought a TV22 with the EF91 valves used in the receiver deck, well, the restoration proved to be almost a mission impossible.
I really can't explain this, but I found the LOPT, the frame oscillator transformer and the frame output transformer with open windings, so I had a "full immersion" session rewinding these transformers.
I'm proud to show you the results after more than 3 months of hard work and I would like to assure you that rewinding the lopt (both the primary winding and the overwind, the latter corroded in a lot of spots) was not an easy task, the primary alone counts 2045 turns of 0,22mm wire and the overwind 2960 turns of 0,11mm wire.
Giulio Maiocco (Italy)
ID:	23089   Click image for larger version
ID:	23090   Click image for larger version
ID:	23091   Click image for larger version
ID:	23092   Click image for larger version
Giulio Maiocco is offline
Old 14th Feb 2009, 1:41 pm   #2
Giulio Maiocco
Default Re: Bush TV22 restoration: mission impossible!
... And this is the second part of photos. I hope you like my work!
I still have to set the width, linearity and centering controls because at the moment I don't have a standard converter, but it should arrive on monday or tuesday
Giulio
ID:	23094   Click image for larger version
ID:	23095   Click image for larger version
ID:	23096   Click image for larger version
Old 14th Feb 2009, 2:45 pm   #3
Tazman1966
Tazman1966's Avatar
Hello Giulio.
It looks fantastic so far. What method did you use to rewind the transformers?
I bet you're really looking forward to your standards converter arriving.
All the very best,
Tas
Tazman1966 is offline
Old 14th Feb 2009, 3:01 pm   #4
Giulio Maiocco
Hello Tas,
I used a winding machine to rewind the LOPT primary, as the bobbin length was enough for the kind of winder I have, but the overwind was layer wound (37 layers of 80 turns each) completely by hand. About the frame oscillator transformer, it uses really thin wire (0,06mm + enamel) and I found that a drill with a very low rotation speed was a good method. If someone is interested, I can tell you that the winding turns ratio is quite low, in fact I wound mine with 2200 turns as the secondary winding and 2530 turns as primary, the turns ratio in my case is 1:1.15 and it seems to work well
About the standard converter, I think you won the bet, in fact I'm "anxiously" waiting Monday, always hoping this will be the right day I receive the converter!
Thank you for the positive words!
Giulio Maiocco
Old 14th Feb 2009, 3:33 pm   #5
af024
Excellent work Giulio.
What condition did you find the laminations on the LOPT and how difficult was it to remove them (considering the windings on the inside of the paxolin tube)?
I bet you also had fun (if that's the word) winding the blocking transformer. Did you manage to do it without any wire breaks? Did the laminations go back ok?
Well done is all I can say.
Regards,
Andy
Now where on earth did I remove that from?
af024 is offline
Old 14th Feb 2009, 3:35 pm   #6
FRANK.C
FRANK.C's Avatar
Hi Giulio
Well done.
That was some achievement to rewind the LOPT. It obviously took a lot of dedication. How did you manage to stop the ends of the winding slipping off each layer.
Frank
FRANK.C is offline
Old 14th Feb 2009, 5:01 pm   #7
Giulio Maiocco
Hello Andy,
well, the laminations doesn't have any trace of rust I can see, but for sure the iron core is a tight fit in the square bobbin, especially with all the wax present. A little drop of "svitol" and heat resolved the problem. About the windings, I had to rewind both, so I had nothing to loose, but if you have the primary winding in OK conditions, you might need to adopt a more delicate approach!
Also, I managed to rewind the blocking transformer without breaking the very fine wire driving it with a finger, but the first time I finished the work and attempted to solder the winding ends to the small cardboard tag, I snipped off the innermost wire. End result: start again from step1, I leave to your immagination the bad words I said.... 2nd try I was more careful and all was OK. This rewinding job took me about 3 hours. The lamination too created no problems both to disassemble and reassemble.
Many thanks for your kind words!
Hello Frank,
rewinding the lopt required lots of time and patience, about your question, I left a bit of margin on the paper wrap (about 2mm each side) and stopped the wire with the help of a bit of scotch tape. I must confess I had a couple of "thrilling" moments when the wire tried to escape from it's place. What I can say is that the scotch tape is nowhere near melting point, as I run the whole thing for more than 1 hour and the LOPT was not even warm, even with the hot PL38 next to it!!
Giulio
Old 14th Feb 2009, 5:03 pm   #8
Peter.N.
That was a real labour of love - or fanatiscism , depending who you talk to
That chassis looks brilliant, I remember those sets when they were new - and that's what they looked like.
Peter.N. is offline
Old 14th Feb 2009, 9:40 pm   #9
Steve_P
Steve_P's Avatar
Love, Peter. And also sheer brilliance too. Well done old bean.
Of course if you're into rewinding line output transformers, I'm sure there will be plenty takers....
Cheers,
Steve P.
Steve_P is offline
Old 15th Feb 2009, 11:12 am   #10
Hunts smoothing bomb
Hunts smoothing bomb's Avatar
Hi Giulio,
Absolutely outstanding work! The re-wound LOPT looks excellent, Well done
I'll post you the LOPT from my TV22 to rewind too!!
All the best and can't wait to see a picture on the set when you have your Aurora.
Lee
Lee
Hunts smoothing bomb is offline
Old 15th Feb 2009, 3:57 pm   #11
Boom
I've had my TV22 sitting in the front room for 20 years waiting to be restored. After seeing Giulios w*rk and another forum members TV22 running with a terrific picture on it yesterday I have finally been given the incentive to go ahead.
Boom is offline
Old 15th Feb 2009, 9:19 pm   #12
af024
Hello Giulio,
Yes I can indeed imagine the naughty words. I'm amazed at your persistance.
I'm also interested to learn that the LOPT runs cool. Maybe running it without pitch is a good move.
This work should certainly provide us all with inspiration.
Cheers,
Andy
af024 is offline
Old 16th Feb 2009, 10:52 am   #13
Giulio Maiocco
Hello guys (and gals)
The Aurora converter arrived this morning, so I set all the various controls and... we have beautiful video!! Please note that I'm not too good as a photographer, in reality the image on the screen is much better and razor-sharp focussed!
Lee, what's exactly the problem with your LOPT? I may help you
Also, peter and Steve, thank you for your kind words, I think I'm quite young (near 26 years old), but that was a great experience and I learned lots of things, even if I already restored quite a bit of vintage TV sets! I'm always of the idea that a work must be done the best way possible or nothing
Andy, yes, the LOPT does indeed run cooler without the pitch, but if you eliminate it, you must varnish the overwind with some anti-corona dope to avoid flashes. If you don't follow this "rule" it's more than probable (I would say sure and guaranteed) that the insulations in the overwind will breakdown
Giulio
ID:	23144   Click image for larger version
ID:	23145   Click image for larger version
ID:	23146   Click image for larger version
ID:	23147   Click image for larger version
Old 16th Feb 2009, 9:34 pm   #14
Sideband
Sideband's Avatar
Giulio, that is fantastic work! You also have a very good CRT. I hope it gives many years of good service.
Rich.
Sideband is offline
Old 16th Feb 2009, 10:08 pm   #15
af024
A cracking result Giulio.
I bet that set won't ever leave your collection - there's far too much of your blood, sweat and tears there!
Excellent stuff.
Andy
af024 is offline
Old 16th Feb 2009, 10:23 pm   #16
Tazman1966
Tazman1966's Avatar
Well Giulio, I don't know what to say! What a pleasing result. I hope that you enjoy the set for years to come.
All the very best,
Tas
Old 16th Feb 2009, 10:25 pm   #17
FRANK.C
FRANK.C's Avatar
Mighty work, a great outcome.
One you should be really proud of.
Frank
FRANK.C is offline
Old 16th Feb 2009, 10:46 pm   #18
chipp1968
chipp1968's Avatar
Very impressive ,lovelly little set
chipp1968 is offline
Old 16th Feb 2009, 10:49 pm   #19
Line whistle
Line whistle's Avatar
Top job,
Cheers, Des.
www.freewebs.com/405tv
Line whistle is offline
Old 17th Feb 2009, 7:38 am   #20
Top Anode
More patience than I had at your age! Well done.
As a child, I was fascinated by the heart shaped cam on my mother's sewing machine. It guided the cotton onto the bobbin for re-winding. I can imagine that such a form would be difficult to design, so are there proprietary ones for coil-winding etc.? It occurs to me that such a shape would only have to be scaled up or down to do most straight winding jobs, but the more complex winding on IF transformers and tuning coils is quite a different issue.
I've often wondered what voltages the lacquer coating will withstand. On a LOPT, I would imagine there about as high as one would get in the domestic environment. No doubt the original designers work hard to give some leeway in the design, but does anyone know the typical voltages between strands?
It does sound as though the original wire might have been faulty.
Top Anode is offline
