Old 21st Apr 2019, 8:42 pm   #1
Karen O
Default AM to VSB changeover
I was surprised to learn recently that the switch to vestigial sideband, as a more bandwidth economic replacement for straight amplitude modulation, occurred during the 405 era, and not with the introduction of 625, as I had previously assumed.
What was the consequence of this for people with AM sets? Were they stuffed (to use the vernacular)?
Karen O is offline
Old 21st Apr 2019, 8:59 pm   #2
julie_m
Default Re: AM to VSB changeover
As far as I understand, VSB was designed to be received on a receiver meant for full AM.
julie_m is offline
Old 21st Apr 2019, 9:07 pm   #3
FERNSEH
FERNSEH's Avatar
The Alexandra Palace transmitter used a double vision sideband transmission characteristic. When it was replaced in 1955 by the channel B1 Crystal Palace TX a vestigial vision sideband was used. This presented a problem with certain receivers which were aligned to the upper sideband. The Baird T5 I'm presently restoring was aligned in such a manner. Another TV receiver that comes to mind was the Ultra V470.
AP was the only 405 line transmitter to use DSB.
I believe that in the last few years of the UK analogue system I the vestigial sideband was trimmed back from 1.25Mhz to 0.75Mhz. Please confirm if the latter figure is correct.
DFWB.
FERNSEH is offline
Old 22nd Apr 2019, 8:47 am   #4
Graham G3ZVT
Graham G3ZVT's Avatar
A legacy of that was the larger frequency jump between channel 1 and 2, compared with the other band I channels.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 22nd Apr 2019, 9:35 am   #5
Panrock
Panrock's Avatar
A description I found on file of the VSB curve relative-to-carrier reads as follows (Ch1 frequencies in brackets). I am not sure of its original source:
Fc = 0dB (45.0 MHz)
Fc + 0.75MHz (45.75 MHz) = -3dB or lower
Fc + 2MHz (47.0 MHz) = -30dB or lower
Steve
Panrock is offline
Old 22nd Apr 2019, 10:34 am   #6
FERNSEH
FERNSEH's Avatar
Response curves taken from the manual of the Mullard AC1 experimental TV receiver.
This was a TRF receiver aligned to the upper sideband. Note the lift in the HF end of the response curve in order to enhance the video upper frequencies.
DFWB.
ID:	181636   Click image for larger version
FERNSEH is offline
