Old 16th Dec 2018, 2:39 pm   #81
19Seventy7
19Seventy7's Avatar
Default Re: CRT is brighter to one side [Hitachi CTP213]
I haven't turned it on as I didnt want to risk it, I'll test it now and report back.
Thanks.
19Seventy7 is offline
Old 16th Dec 2018, 2:41 pm   #82
mark2collection
mark2collection's Avatar
The PCB (Printed Circuit Board) will be mounted in the centre of the TV, most likely on a chassis. TV's of this generation typically have a metal chassis.
As Lawrence has said, do be careful.
You may find glue holding long-ish wire(s) in place on the track-side (sometimes referred to as the solder-side) of the circuit board, worth looking at any main PCB's or Sub-PCB's, the latter are much like daughter 'cards' in a desktop computer.
It wasn't uncommon to find TV's modified in this way by the factory, over a production run.
Mark
mark2collection is offline
Old 16th Dec 2018, 2:42 pm   #83
Station X
Station X's Avatar
Thanks.
I wasn't suggesting you should do that as I'm no vintage TV expert.
If I were you I'd await advice from someone more knowledgable.
Graham. Forum Moderator
Station X is offline
Old 16th Dec 2018, 2:55 pm   #84
19Seventy7
19Seventy7's Avatar
Oh oops. I’ve turned the TV and there is no burning smell, however the picture is “smeared” and there is a humming/buzzing sound from the speaker. I'll attach some photos, showing the smearing.
Thanks for explaining the PCB, I'll take another look in a minute, if I do see the glue, should I remove it, as Mark said cures it, or leave it?
Thanks
Old 16th Dec 2018, 4:02 pm   #85
Refugee
Refugee's Avatar
It may also have a problem with the line driver capacitor.
C738 close to T702/TR703.
It is likely to blow the power transistor driving the line output transformer.
Refugee is online now
Old 16th Dec 2018, 4:47 pm   #86
19Seventy7
19Seventy7's Avatar
I can see C736, but i cannot see C738, I think I’ll need to take the board out, but I'm not sure if i can without disconnecting all wires, which I don't mind doing, if it needs to be done.
The wires are attatched to plastic connectors, do these just push in and pull off other connectors, or do these get soldered on? Don’t want to try and take one off and break anything.
Thanks
Old 16th Dec 2018, 5:09 pm   #87
Refugee
Refugee's Avatar
It looks like 738 to me.
Old 16th Dec 2018, 5:37 pm   #88
19Seventy7
19Seventy7's Avatar
Thank you, I've been using my phone for the day, and I couldn't read it properly I've come on to my PC, where I can read it properly.
In my earlier reply, I meant that I could see C736 on the board, but not C738. I'm not sure if they're close together
I'll find out what capacitors I need and hopefully order them tonight or tomorrow.
Edit: Looking at the service manual, looking at the replacement capacitators needed, the voltage is said to be "DC160WV" but looking online, no listings have WV, which I believe is Working Voltage? I've searched whether WV and voltage is the same thing, but no answers have been given.
My question is, are they the same? I just want to make sure.
Thanks.
Old 16th Dec 2018, 7:08 pm   #89
samjmann
samjmann's Avatar
You're right in that WV stands for working voltage. In this instance the capacitor is rated at 160V.dc So there there should not be any more than 160Vdc across the capacitors terminals. Much more than this and the cap' is likely to rupture or even explode! Simply choose this voltage or higher and you should be OK.
Back in the seventies I used to service these sets. The thing was that they hardly ever went wrong. Hence 'common faults' that we can remember now were few and far between. What I would say is if the line driver capacitor is failing, normally one side of the the picture is squashed and compressed, and it will make the line output transistor run hot or fail. From what I can see from your pictures, the problem would be in the RGB output stage, of which there are references earlier in the thread.
Please do be careful with these sets, I've lost count of the number of shocks I got over the years with 'live chassis design'. SJM.
samjmann is offline
Old 16th Dec 2018, 8:19 pm   #90
19Seventy7
19Seventy7's Avatar
That explains a lot about the burning, luckily it seems to be okay now. I'll replace the LD capacitor, which I think was the original issue? I'm not sure, but iI'll go back and check.
I think I should be okay replacing them as I have soldered before, and I have always got this forum or the internet should I need extra help.
I'll be very careful, I usually unplug electronics when working on them, turn them on to test, and if I need to work on it, turn it off again.
The TV will be unplugged when being worked on, and only plugged in when testing and when in use.
Thanks
Old 16th Dec 2018, 8:36 pm   #91
19Seventy7
19Seventy7's Avatar
It is capacitor C738 that needs replacing?
Just want to make sure.
I also apologise if I'm asking silly questions, I just don't to get anything wrong.
Thanks
Old 16th Dec 2018, 9:35 pm   #92
samjmann
samjmann's Avatar
You're not asking silly questions! C738 appears to be connected to the 110Vdc main supply rail. It's function is to decouple any line frequency pulses that may appear on the supply from the line driver stage as shown in the thumbnail diagram. R725 next to C738 drops the 110v supply to the driver stage T703. R725 will run warm. C738 looks like a 100uF at 160Vdc.
I'm not sure what test gear you have, but a check on the base and collector voltages of T703 would reveal if there is an obvious problem in that area.
Again, switch off, unplug, wait, then connect a meter to the transistor. Then switch on and take note of the readings. Don't take use a meter probe with the set on, you'll end up with a shock. Connect/disconnect with the set off.
Some really clear pictures of the screen, with the phone looking directly at the screen would help. Distortions of the picture help us know what bit of the set is at fault. So a good straight view of the screen is good.
If you do not feel confident at this then please don't go any further. SJM
samjmann is offline
Old 16th Dec 2018, 9:46 pm   #93
19Seventy7
19Seventy7's Avatar
Oh that's good.
you were correct in that C738 is a 100uf 160Vdc, as the replacement parts section of the circuit diagram states. I've been referring to that a lot.
I do not currently have any test equipment, but I can easily get some. What is the recommended gear? Would a Multimeter work? When I do test, where do I connect the meter?
I'll reconnect the Atari now, and take some photos, I cannot guarantee that it'll be the best quality as I don't have a camera, other than my phone.
Thanks
Old 16th Dec 2018, 9:47 pm   #94
ms660
ms660's Avatar
I would leave C738 for the moment, I would post some clear photo's of the screen display with a signal input correctly tuned in and with the colour control turned to minimum.
EDIT: Post crossed.
Lawrence.
ms660 is offline
Old 16th Dec 2018, 10:06 pm   #95
19Seventy7
19Seventy7's Avatar
photos:
The first two are with all 4 controls highest
The second 2 are with all three, apart from colour, which is as minimal as possible, controls on the highest.
That blue tinge is there, and isnt to do with the camera.
There is also no “snow” on the screen when nothing is connected. It just looks like the TV is off
Thanks
ID:	174734   Click image for larger version
ID:	174735   Click image for larger version
ID:	174736   Click image for larger version
Old 17th Dec 2018, 12:10 am   #96
AC/HL
AC/HL's Avatar
Now the subject of a services wanted thread: https://www.vintage-radio.net/forum/...d.php?t=152349
AC/HL is offline
Old 17th Dec 2018, 12:34 am   #97
19Seventy7
19Seventy7's Avatar
Am I able to link this thread to the Request?
Thanks
Old 17th Dec 2018, 1:56 am   #98
Maarten
From the bleeding (clipping) in the picture, I think there's now even less smoothing on the supply line to the RGB stages.
When replacing higher voltage electrolytics in applications like this, I've found the Panasonic ED or EE series to be quite suitable.
Maarten is offline
Old 17th Dec 2018, 2:40 am   #99
19Seventy7
19Seventy7's Avatar
I was thinking of going with some Panasonic capacitors, mainly for the reason it was the only named brand I could find, and were therefore, more comfortable buying.
Thanks
Old 17th Dec 2018, 11:07 am   #100
1100 man
1100 man's Avatar
The RGB output transistors, TR851, 852 & 853 are mounted on the board plugged into the back of the tube. They amplify the 3 primary colour signals (red, green & blue) to drive the tube.
The 200V supply for them is derived from the line o/p transformer (FBT on the diagram), via CR707 & R734. The supply is smoothed by two capacitors, C737 & C754. These are shown as 3.3 mfd at 315V. They will be found somewhere near the LOPT.
These will be a good first step to change as they will address the original shading fault as well. These capacitors are polarised, ie it matters which way round they go!
Looking at the circuit, the chassis metalwork is 'at half mains potential' which was quite normal for colour sets of this period. Consider this to be LIVE when the set is powered so don't touch it or connect it to anything else!
Nick
1100 man is offline
