Old 22nd Apr 2014, 11:18 pm   #1
FERNSEH
FERNSEH's Avatar
Default Marconi VT161: local distant control repair.
The local distant control in my Marconi VT161 has fallen to pieces. There's is no chance of course of finding an exact replacement so a conventional 2Meg pot will have to be used instead. This will involve using my favourite device, the adaptor plate.
The local distant control sets the delay voltage to the AGC supplied to the RF amplifier. When receiving very weak signals it is desirable to remove or delay the AGC voltage supplied to the PCC84 RF amplifier. Doing this can improve the signal to noise ratio. On strong signals no AGC delay is required and the full AGC voltage is fed to the RF valve.
There are few other jobs to do the set before the chassis is installed into the cabinet.
DFWB.
ID:	91908   Click image for larger version
FERNSEH is offline
Old 23rd Apr 2014, 8:36 am   #2
Tazman1966
Tazman1966's Avatar
Default Re: Marconi VT161: local distant control repair.
Nice job (as always). It looks like it was there from new.
All the very best,
Tas
Tazman1966 is offline
Old 23rd Apr 2014, 11:36 am   #3
Hybrid tellies
Hybrid tellies's Avatar
A very nice tidy job.
Simon
BVWS member
Hybrid tellies is offline
Old 23rd Apr 2014, 12:09 pm   #4
Peter.N.
Yep very neat, looks like an RS pot.
Peter.N. is offline
Old 23rd Apr 2014, 12:42 pm   #5
FERNSEH
FERNSEH's Avatar
The original component was a Morganite make and the replacement is a Welwyn. It does have a RS look about.
I've turned my attention to the sound. The original PCL82 was low emission and has been replaced. Also the 0.01mfd Hunts coupling capacitor to the grid of the triode section needed replacement.
Much more sound now.
The Marconi VT161 has direct line sync. This set is always prone to slightly ragged verticals, something I must look into to later.
TV sets with blocking oscillators do seem less prone to ragged verticals than those with multivibrator line oscillators.
Focus Diode (Brian) called around today and he noticed another adaptor plate, this one was fitted by the manufacturer. The metalwork allows the fitment of an octal line output valve, say a PL36, and as this set uses the PL81 which has the smaller B9A base an adaptor plate is called for.
DFWB.
FERNSEH is offline
Old 23rd Apr 2014, 2:10 pm   #6
Focus Diode
Focus Diode's Avatar
Lovely set and a great performer. David's done a great adaptor for the dropper too as can be seen in the photo below, a brilliant piece of work the manufacturer would've been proud of.
Cheers,
Brian
Name:	Marconi VT161 dropper.jpg
Focus Diode is offline
