Old 10th Apr 2014, 10:45 pm   #1
Libratron
Libratron's Avatar
Default Sony SL-F30 Recording problem
Hi at all.
Finally i have find a working video head disk, for my SL-F30.
Now it's play fine with great quality, but recording in black and white.
It's a fault on a Y/C p.c.b?
Thanks at all.
Libratron
Libratron is offline
Old 11th Apr 2014, 12:34 am   #2
DangerMan
Default Re: Sony SL-F30 Recording problem
Are you sure you have fitted it correctly?
If it's 180 degrees out, that could explain things.
DangerMan is offline
Old 11th Apr 2014, 2:36 pm   #3
Libratron
Libratron's Avatar
I resolved.
The problem is a rca cable to input socket, with bnc adapter, not working.
Replace with a working cable, now recording with color.
Sorry at all.
Libratron
Old 13th Apr 2014, 10:51 am   #4
AidanLunn
AidanLunn's Avatar
It sounds more likely that you have simply not wired the replacement head drum/disk in correctly. You must make sure that the cables to it are soldered to the correct tags on the head drum otherwise faults like this show up.
AidanLunn is offline
Old 13th Apr 2014, 12:49 pm   #5
Libratron
Libratron's Avatar
Hi Aidan,
I have solder the wire perfectly of the head disk, the problem is the old cable.
Testing with my VTC-5150 in (playback o in recording) the image is in black e white.
The problem is a my old rca cable.
Thanks for interesting.
Libratron
Old 13th Apr 2014, 3:24 pm   #6
Libratron
Libratron's Avatar
A photo of the test pattern recorded with the SL-F30:
Name:	Test Pattern.jpg
Libratron
