22nd Apr 2019, 3:30 pm | #1 |
Emiscope 3/1 Testing, and value?
Hello All,
Having a bit of a pre Freidricschafen tidy up (and fund raiser ) - Big Amateur Radio rally in Germany.... I have come across an unmarked CRT that looks to me to be an Emiscope 3/1. I have tested the heaters for continuity, and operation - 4v applied to the heater terminals results in the heater lighting, and 1.35A being drawn from the PSU. I do not have anything here that will drive this CRT, so is there anything else I can do to test it? I am looking to sell the tube in any case, but have no idea of it's value - Pre War TV stuff is a little beyond my means, so I very much doubt that a 904 will come my way for a few tens of pounds Could the assembled experts suggest any non destructive or potentially non damaging test methods, and some indication of a fair market value? Cheers Sean
Engineers make things work and have spare bits when finished Last edited by Sean Williams; 22nd Apr 2019 at 3:38 pm. |
22nd Apr 2019, 4:47 pm | #2 |
Re: Emiscope 3/1 Testing, and value?
Hello Sean,
I would be interested in this tube to try it out in my Marconiphone set, but somehow I doubt that it is a 3/1. All 3/1's that I have seen photo's of, seem to have a much longer aquadag layer on the inside. See attached picture. Jac p.s. photo is part of a photo by Catkins on this forum |
22nd Apr 2019, 5:17 pm | #3 |
Hi Sean,
That looks quite a find! I guess you could illuminate the screen with a pocket U/V torch in a dark room if you want to check the phosphor for ion burns and check its colour, especially if it's not a 3/1. The 3/1 often seems to suffer from temporary inter-electrode leaks on warm-up, so try connecting an Avo, on its high resistance measuring range, between the grid and cathode, with the lead bearing the negative test voltage on the grid, and then apply 4v to the heater. If there's an intermittent 'warm-up' leak, this will show it. Check also between heater and cathode. Hope the tube is a good 'un! Steve Last edited by Panrock; 22nd Apr 2019 at 5:44 pm. |
22nd Apr 2019, 9:07 pm | #4 |
I learnt from Jac a good test to see ion burn on 6/6s. Supply the heater as normal, keep cathode and grid at zero volts, apply something in the 200 volt range to A1 and something like 1000 volts to the final anode. (Experiment with the A1 voltage for best results.) I didn't have a convenient high voltage source but paid about about £5 for a little module that generates a nice safe 1000 volts. A permanent magnet can then be used to steer the defocused beam to the centre of the screen.
Peter |
22nd Apr 2019, 9:33 pm | #5 |
Thanks All,
From the digging I have currently managed, I cannot find any other EMISCOPE tube other than a 3/1 that matches the physical arrangement of this one. I do not have a UV light source here, have tried various torches and LED sources to exploit the UV content to no avail. Will give the method Peter describes a bash - I have plenty of PSUs that will provide the required voltages, al be it at a quite low impedance, so will be keeping the fingers well away
22nd Apr 2019, 9:43 pm | #6 |
No Longer a Member
I think that 3/1 you have is a valuable CRT, they are practically unobtainium.
It also looks pretty good cosmetically, it has a known good heater and the getter looks great. I would suggest not tinkering with it applying voltages, it won't tell you anything useful about it, the thing you want to know especially, that is if the emission is good enough to display a reasonable TV picture. With CRT's that run around 2kV EHT, the overall beam energy is very low on a full TV raster and they have to be in fairly good order (low gas and good cathode emission and good phosphor) to get a reasonable focused image. A blob of a de-focused beam won't help you asses that. Plus, without scanning coils running there is always a chance of a phosphor burn, even applying lower voltages. Also don't put permanent magnets anywhere near its gun structure. The safer and better move is to find somebody with a working set, drop it into the set and check the TV image. Last edited by Argus25; 22nd Apr 2019 at 9:49 pm. |
22nd Apr 2019, 9:45 pm | #7 |
Ah, a slight flaw in the method described Peter, this is a triode, so no A1 to play with.
I guess the same approach will work with the triode, just need to be careful to keep the beam intensity low to save burning the phosphor
22nd Apr 2019, 9:47 pm | #8 | |
I wonder if anyone localish to me has a suitable set and would be happy to test the tube on my behalf?
22nd Apr 2019, 10:08 pm | #9 |
No Longer a Member
If it is excellent on testing in a set, the person who tests it will probably want it as it may be better than their own 3-1 ! I would want it, especially if it tested well and I lived in the UK, but I would not like to take the risk shipping it to Australia, just in case it got damaged / broken. That would be a real loss and I'm not talking just about financial loss, it cannot be replaced. It is better to avoid shipping at all for this rare part (unless you hand carry it in good packing) and hand it directly to the person who wants it.
23rd Apr 2019, 8:35 am | #10 |
Sean, Testing in a set would certainly be best but if you decide to test it with a defocused beam I think you might find that with the 3/1 the burnt area may not be the concentrated centre spot but rather a much larger circular area with a well defined edge in which case you might need to explore a rather larger sweep with the magnet.
Peter |
23rd Apr 2019, 8:48 am | #11 |
To illustrate this, a photo of the 3/1 in my 706.
Hope this helps. Jac |
23rd Apr 2019, 9:07 am | #12 |
I have never seen a 3/1 with a side evacuated seal on the bulb. It may well be a very early tube possibly experimental. I believe the 3/1 were manufactured like it's big brother the 6/6 from Pyrex hard glass.
1000v will not burn the screen and 500V may well give an indication on a 5" tube. Due to zero focusing field the unfocused beam will show the familiar 'moon' pattern on the screen and will give a good indication as to the tube's condition. I have done this many times as a test. When working on an early receiver with mains derived EHT, one of the first tests I carry out is to determine the make of the EHT smoothing capacitor/s. If they are the the Bakelite TCC Visconol type I disconnect them. Next the HT rectifier valve/s are removed and the set powered up. You can do this with a variac/limiter if you feel nervous. The focus arrangement with these early receivers is almost universally electromagnetic so there is no danger of producing a sharply focused spot that would burn a mark on the tube if there is no HT to activate the focus coil. A quick visual check will prove for certain that a focus coil is fitted. It works very well with triode tubes typically Mazda CRM types but will also give a fair indication with tetrodes such as the MW22-7 employed in the Pye D16T. Even without the A1 voltage a patch is produced but of lower brightness. Of course care has to be taken but this rough test will often prove the viability of an unknown tube and the condition of the EHT transformer. I carried this out recently with a 3/32 EMI tube and posted the outcome on a recent thread. Good luck with your tube and I hope it is a good one! John. |
23rd Apr 2019, 10:14 am | #13 |
Hi John,
My 3/1 in the Marconiphone 706 also has no evacuation pip on the bulb, but if the photo by Catkins (2015) and a photo of the CRT booklet (also by Catkins) are any indication, both with and without pip on the bulb were made. Please see attachments. Jac edit: added a photo of the 3/1 on my CRT tester at 2 kV anode voltage. In reality brightness is much less than it appears to be on the photo. Last edited by Jac; 23rd Apr 2019 at 10:19 am. |
23rd Apr 2019, 6:07 pm | #14 |
The CRT with the side evacuation in that picture is from my Marconi 706. This tube is o/c so I would be very interested in a new one! A 3/1 appeared on ebay a few years ago which also turned out to be dud. This also had side evacuation...
23rd Apr 2019, 6:47 pm | #15 |
Without a working CRT I never got far with my restoration (I have since obtained a 5FP4 so I've been intending to start on it again for at least the last year). My brother's HMV 904 was in working order 3 years ago, but hasn't been turned on since. We're also not quite round the corner, being 2.5 hours drive away.
23rd Apr 2019, 10:14 pm | #16 |
Well, I put the brave pants on tonight - et voila! A white phosphor!
I moved the beam around with a magnet as Peter suggested, and there appears to be no Ion burn to speak of other than the pinprick in the centre of the tube face. EHT was around 900v and heater at 4v at the CRT base.
24th Apr 2019, 12:41 am | #17 |
Great stuff, I'm sure that crt will make someone very happy!
24th Apr 2019, 12:17 pm | #18 |
Hi Sean,
Could you provide a close-up picture of the gun assembly? Thanks. |
25th Apr 2019, 10:25 pm | #19 |
No response to my post and no response to a PM so I guess this is now sold.
26th Apr 2019, 5:29 am | #20 |
No, not sold, just away with work, and this isnt a selling thread
