28th Oct 2020, 11:52 pm | #681 | |
Re: Mk14 vdu
I’m wishing I had a copy of the hardware to join the fun, but sure that between you this is going to be solved soon. |
29th Oct 2020, 12:09 am | #682 | ||
Re: Mk14 vdu
29th Oct 2020, 12:33 am | #683 |
Re: Mk14 vdu
I'm still here, despite trying to escape and think about something else for a while at least a couple of hours ago. Mark has a real MK14 but as we know the early versions don't have connections for the VDU, nor do they have the useful memory hole at 0200-07FF, that area being occupied by 'images' of the OS in all revisions prior to issue V.
If I did consider connecting a VDU to the MK14 now I think I would solder a 40-pin turned pin socket to the CPU pads on the underside of the PCB, put a 40-pin header plug on the end of a wide bit of ribbon cable and use that to convey all the necessary signals back towards and beyond the rear end of the PCB. The trouble is that's not the only problem to overcome, there are a few minor mods to the PCB and the small matter of having to change the crystal from its original 4.43MHz to a 4.00MHz one - all modifications which I did make to my original machine back in the day and subsequently later reversed. I wouldn't think of connecting the VDU back up to it now. What you really need is one of Slothie's famed issue VI replica PCBs, if you look back to the very early pages of this thread Slothie posted the design files for his PCB and you could actually have a small batch made yourself if you wanted to. I did that and got the minimum five made - one is the one I am using, one I sold to Tim for exactly what it had cost me (5 GBP), one I gave to Phil over in France for his generosity in providing many people here with Scrumpi, PIC14 and other PCBs and the remaining two I sent to Slothie to do with as he saw fit, so I no longer have any spares myself but the process of getting them made was surprisingly painless and quite quick. |
29th Oct 2020, 3:03 am | #684 |
Re: Mk14 vdu
I did download the files for Slothie’s replica and still thinking about getting a few made. I have most of the components. Displays are in UK at my Mum’s, since last year, I guess nobody expected international travel to become so difficult this time last year when I ordered them from the Netherlands. Only thing that would be a problem is the proms, I was considering replacing with a 2716 or 2732, possibly connected via the vdu connections on the edge connector.
I also started laying out a keypad and display board, to be compatible with RC2014 bus, and I have an SC/MP board designed for the same bus that I haven’t had manufactured yet. I got a bit diverted playing with an INS8073 wired to the same bus. Maybe I should post some details in the homebrew section. |
29th Oct 2020, 10:14 am | #685 |
Re: Mk14 vdu
If you are thinking of getting the PCBs made, I found JLCPCB to be considerably cheaper for a board this size than PCBWAY. The quality is very good too, both in the circuit and silkscreen. I recall I tried a couple of the European manufacturers and either had trouble getting the website quote to work or the cost was huge, albeit this was a few years ago now and I didn't make an exhaustive search so it might be worth checking again - you may even find it worth trying Oshpark, Seeed or other US/Canadian manufacturers, I didn't mainly because shipping costs have always been high for the UK.
As for the PROMs, I was going to make an adaptor from matrix board that plugged into one of the PROM sockets with the 4 data bits going via a bit of ribbon cable to the other socket, but fortunately I managed to get some Tesla PROMs programmed with help from people in the UK, France and Germany - they were more travelled that I was, so not a route I'd recommend. There are people on here that can program genuine National Semi DM74S571 chips and these do pop up on eBay from time to time. I would imagine memory is probably going to be your worst problem, they are available but recently seem to have spiked in prices - perhaps you'll have more luck with chips from the USA if shipping is less than the rediculous amount it is to europe. It would be interesting to see your experiences with the 8073, they are very rare! Information on the SC/MP 3 is also pretty hard to find. |
29th Oct 2020, 5:43 pm | #686 |
Re: Mk14 vdu
I bought 10 of AM9111BPC from utsource last year at about $2.30 each and used two of these to fix my original MK14. I resisted the temptation to test the other 8 in the MK14 in case of damage to the sockets. Shipping and import cost might still be an issue but as this was part of a larger order it wasn’t much of an impact on the cost of the ram chips.
I have used Jlcpcb a few times. They have a 102.4 x 102.4 limit on the low cost offer compared to 100 x 100 from most of the others. It doesn’t sound much different but does allow 40 pin headers to be used. |
29th Oct 2020, 5:55 pm | #687 |
Re: Mk14 vdu
JLCPCB was who I ordered mine from, Slothie's 'package' uploaded to them without any problems, the only change I made was to order them in black rather than the default green. I must say they did a nice job.
29th Oct 2020, 6:04 pm | #688 |
Re: Mk14 vdu
It's also worth remembering that 74S571s are not the only pin compatible PROMs which can be used in the MK14, here, courtesy of mikesarcade.com, is a cross reference list showing a number of compatible types. The 'TS' at far left signfifies these are all tri-state output types, there are others with the same pinout which have open-collector outputs and would not be suitable for the MK14.
Code:
Signetics MMI TI Harris Raytheon AMD National Intel --------- --- -- ------ -------- --- -------- ----- TS 82S131 (50ns) 6306-1 - 7621-5 29611 27S13 74S571 3622 82S131A(30ns) 63S241 - 7621A - 27S13A 74S571A 3622A |
29th Oct 2020, 6:57 pm | #689 |
Re: Mk14 vdu
I got a quote today from JLCPCB and it was $13.20 + $8,54 for shipping to the UK for 5 MK14 boards that are too big for their low cost boards. I tried other places - OSH park wanted $247 for 3! Most of the UK and european sites didn't have online quotes aside from PCB cart whose I couldnt get to work! PCBWay was $72+$24 shipping for 5 which seems odd because theyre being pushed as a cheap PCB house...
29th Oct 2020, 7:07 pm | #690 |
Re: Mk14 vdu
The price for my batch of 5 from JLCPCB back in mid-year was a tiny bit over 25 GBP for 5 including packing and post to the UK. I don't think they incurred any duty, but whether that was by accident or design I don't know.
29th Oct 2020, 8:23 pm | #691 |
Re: Mk14 vdu
Mamma Mia!
(Here I go again..) First check for tonight will be to run the same version of CHARSET again but this time with OrtonView running the most recent pre-optimisation firmware (which I call V1.01). The rationale behind this is that we were so preoccupied with the very obvious system slowdown in that version that we did not really test and experiment with it very much, so I just want to see if the pre-op version also does this - if it doesn't we can surmise that it is something specifically in the optimised version which causes writes to one page to occasionally also cause a write to the same location in another page. I think this is already our default theory, but I prefer to prove things one way or the other and not just make assumptions as to what is more likely. After that I'll revert to the latest mainstream firmware and have a go to capture what is going on around the occasional _CE pulses for the main RAM 0Fxx when the charset program is continually writing to 0Bxx. This is one case where I could do with being able to capture more than two channels, but it is what it is. |
29th Oct 2020, 9:05 pm | #692 |
Re: Mk14 vdu
I've got one more trick to try - I've widened the margins for NENIN release during the active display region. This will mean the SC/MP running a bit slower but worth it if it works.
I'm really struggling to understand how the PIC VDU can alter memory contents. It has to be something to do with abortive write cycles...? |
29th Oct 2020, 9:14 pm | #693 |
Re: Mk14 vdu
29th Oct 2020, 9:17 pm | #694 |
Re: Mk14 vdu
Yes, and its strange how it is at specific memory addresses too. It should be possible to get it to work though, since the 1st version worked so well. I don't think you need worry about consuming a fair bit more bus time as the revised software is so fast (too fast!).
29th Oct 2020, 9:41 pm | #695 | |
Re: Mk14 vdu
29th Oct 2020, 9:58 pm | #696 | |
Re: Mk14 vdu
I'm so sorry that I can't seem to crack this one, my friends. We're so close, too. |
29th Oct 2020, 10:06 pm | #697 | |
Re: Mk14 vdu
I do not think it is the VDU doing the write. The level of corruption is definitely proportional to the number and type of writes in a program - the writes are related in place to the original ST statements which is why I am supporting the corruption of the address bus while NWDS is still low and maybe _CS for the RAMS is changing to the new address - meanwhile the SC/MP is merrily retrying its write now it has been allowed access. |
29th Oct 2020, 10:09 pm | #698 | ||
Re: Mk14 vdu
29th Oct 2020, 10:11 pm | #699 | |
Re: Mk14 vdu
If you get actual National Semiconductor DM74S571 PROMs there is a documented Arduino project for programming those, https://hackaday.io/project/25953-pr...rom-programmer but be warned that neither it (nor any programmer capable of programming the Nat Semi parts) can programme the Tesla version - despite the misleading similarity between the part numbers the programming regime is quite different - there are a couple of threads about that somewhere. I can tell you that I have a device programmer which can programme the Nat Semi DM74S571, Signetics 82S131 and AMD 27S13 and I'm happy to programme them for anyone who can get a pair of blank PROMs to me, although that offer will be less useful to you than most since you happen to be in Canada. |
29th Oct 2020, 10:22 pm | #700 |
Re: Mk14 vdu
Sorry, I was wondering which one might be easier to build a homebrew programmer for. It looks like the signetics has more information available on programming. I’ll try giving the local shop a call tomorrow to check the price.
