2nd Aug 2021, 5:20 pm | #1 |
Help Identifying Wax Cap
I wonder could someone identify the value of the attached wax capacitor please. It is marked L.E.M. and 270 (R?) but it a bit smudged.
Thanks! |
2nd Aug 2021, 5:23 pm | #2 |
Re: Help Identifying Wax Cap
Looks like a 270pF mica to me. Unlikely to be bad.
2nd Aug 2021, 7:59 pm | #3 |
4th Aug 2021, 8:39 am | #4 |
OK, thanks guys. It looks like a wax cap as the coating has a little give in it and I can scrape a bit of it off with a screwdriver.
4th Aug 2021, 9:59 am | #5 |
Often early Mica capacitors were encapsulated in wax, not to be confused with paper capacitors with a wax coating which are often referred to as waxey's.
David |
4th Aug 2021, 12:07 pm | #6 |
This is an important distinction. When we refer to 'waxies' it is specifically the wax-coated paper capacitors that are invariably leaky. The problem is that the paper is hygroscopic and in the absence of hermetic sealing it absorbs water over time (although more recent studies suggest that some water may also be produced by decomposition of the paper.)
Mica capacitors are not hygroscopic therefore the choice of encapsulation, whether a resin moulding, dip or wax does not make much of a difference to their lifespan, so the presence of wax on a mica cap is not cause for concern and the capacitor is likely to be as good as new. |
