Old 27th Jul 2021, 8:28 am   #1
DNorris40
Default Telefunken Opus 7 turntable connector.
Morning All, on the back of the Opus 7 are 2 inputs, the first a DIN socket for tape and secondly another type of socket for connecting the record player. I am trying to fathom out what type of connector this is, where I would get one and how it should be wired. Basically it looks like it has 2 round pins left and right and a rectangle shaped pin between them.
Any thoughts please?
Dave
DNorris40 is offline
Old 27th Jul 2021, 8:43 am   #2
TonyDuell
Default Re: Telefunken Opus 7 turntable connector.
This sounds like the socket that Philips used on their radios and tape recorders.
The central pin is a dummy. I think there was a convention that inputs had flat pins and outputs had round pins. The outer 2 pins are signal and ground, one of the sockets should be marked with an earth symbol.
A pair of 4mm plugs will fit in most cases. If not, try 1/8" wander plugs if you can find any.
TonyDuell is offline
Old 31st Jul 2021, 12:37 am   #3
DNorris40
Tony, thanks for the info. I will have a search and see what I can find.
Dave
Old 31st Jul 2021, 4:29 pm   #4
TonyDuell
The service manual for my Telefunken Magnetofon 85 tape recorder describes an add-on 'diode socket' plate that could be fitted to radio sets in place of the pickup socket and which provided a 3 pin DIN socket for the tape recorder and a replacement pickup socket.
I have attached the diagram of this unit which may helo with the pickup socket. That is shown at the top of the diagram, note the 2 outer sockets, one is earthed the other is signal. The central flat pin is also earthed, but as I said it was rarely connected in the plug (one suggestion I read was that the main reason for the central pin was to prevent the audio plug being plugged into a mains socket)
