Old 26th Jul 2021, 8:37 pm   #1
John_BS
John_BS's Avatar
Default Radford amp; parts queries
1. Can anyone please confirm the make-up of these grey RS capacitors? They show measurable leakage and a loss tangent much inferior to polycarbonate, which might suggest they are paper based?
2. This STA 12 amp has not been messed with too much, and it's very likely that the 'resistor' mounted on the socket of the GZ34 rectifier is original. Is this a brimistor? If, so, based on its dimensions, it's an STC CZ1?
John
ID:	238267   Click image for larger version
John_BS is offline
Old 26th Jul 2021, 8:47 pm   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: Radford amp; parts queries
ISTR that these are Mixed Dielectric types.
See this page.
https://www.vintage-radio.com/repair...apacitors.html
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 26th Jul 2021, 9:03 pm   #3
Dickie
This thread suggests it may be a CZ6? (roundabout post 10, as fitted to the MA15)
https://www.vintage-radio.net/forum/...d.php?t=164829
Regards,
Richard, BVWS member
Dickie is online now
Old 26th Jul 2021, 9:11 pm   #4
G6Tanuki
G6Tanuki's Avatar
I've had those grey RS capacitors fail in the past - the innards swell and crack the plastic outer-casing.
Personally I'd be installing some nice shiny new LCR or Kemet yellows in their place - then you know things will be good-to-go for another couple of decades.
G6Tanuki is offline
Old 26th Jul 2021, 9:57 pm   #5
John_BS
John_BS's Avatar
See this page.
Mike T
Mike: thanks for that. Having read the capacitor page above, it could perhaps do with an update!
John
John_BS is offline
Old 26th Jul 2021, 10:04 pm   #6
John_BS
John_BS's Avatar
Richard: you could well be right. Both the CZ1 and CZ6 are 1.25" long, but I was trying to guess the type from the cold resistance: this sample measures 8k2 at room temp, which is higher than either. So I susepct it's cooked at some point and changed characteristics. It measures 250 ohms at 100mA, again with normal room ambient
As this amp uses 20uF main smoothing caps, it may not be necessary to employ the brimistor at all? I may try using a fixed R to keep the HT voltage about right?
John
John_BS is offline
Old 27th Jul 2021, 8:58 pm   #7
buggies
buggies's Avatar
Yes - think these are they - monochrome cat but look like they could be the grey ones.
ID:	238330   Click image for larger version
George
buggies is offline
Old 27th Jul 2021, 9:19 pm   #8
Cobaltblue
Cobaltblue's Avatar
See this page.
Mike T
John
Yes Paul has been saying that for a while now but that page was probably created almost 20 years ago and those capacitors will not have improved with age that's for sure
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 27th Jul 2021, 9:47 pm   #9
Philips210
Hi.
Yes, I quite agree. Those mixed dielectric capacitors often test leaky and many have swollen up cracking the case. Shades of Rifas here! I suppose the paper part of the dielectric has absorbed moisture over a long period which would cause the innards to expand and rupture the case.
I've come across various colour mixed dielectric caps. I've seen grey, white, blue and white, blue and grey, and blue and yellow cases. I don't know if there's any significance relating to the case colour. I recall the blue and yellow case versions were often used by BRC/Thorn. I think their 1400 chassis used them.
Regards,
Symon
Philips210 is offline
