Old 25th Jul 2021, 8:38 am   #1
aurelZlatko
aurelZlatko's Avatar
Default Vintage FM front end tuner Help?
hello
I want to build FM tuner front end posted by Argus25
https://www.vintage-radio.net/forum/...d.php?t=145179
it is with
AF124 preamp and AF125 osc/mixer...
I can read some values from document but not all because image is
blur and i simply cannot read whole component values
like in preamp is that 1.5k or 15k ?
also first caps is 33pF i can read but under that one i cannot
please any help or link to clear-er image
i really like to build this one because i have similar transistors
AF139
AF279
AF239
BF939
BF670
etc
thanks in advance
aurelZlatko is offline
Old 25th Jul 2021, 11:28 am   #2
Herald1360
Herald1360's Avatar
Default Re: Vintage FM front end tuner Help?
Hi, attached is a slightly better copy.
You can find it also in here:
https://frank.pocnet.net/other/Phili..._3_1971-11.pdf
See p48 of the pdf
HTH
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 25th Jul 2021, 12:08 pm   #3
John_BS
John_BS's Avatar
There are many designs for FM front-ends from that era: are you happy that this design is limited to 101 MHz?
John
John_BS is offline
Old 25th Jul 2021, 12:24 pm   #4
aurelZlatko
Well in the document it's stated that it tunes from 88 to 108. I don't see 101?
But OK maybe I am wrong.
Thanks a lot for the link!
Old 25th Jul 2021, 2:56 pm   #5
aurelZlatko
Ahh yes I see it now, but I think with some calculation could be changed to 88 to 108.
Well I would be happy if it worked and I expect good sound.
Old 27th Jul 2021, 6:00 pm   #6
aurelZlatko
hello again.
I made a quick build of the above FM tuner and I have data about coils, but I don't know what is a coil inner diameter.
any advice?
Old 31st Jul 2021, 5:26 pm   #7
John_BS
John_BS's Avatar
Try 12mm
John
John_BS is offline
Old 2nd Aug 2021, 3:29 pm   #8
aurelZlatko
Ok i try with 10mm and not work well..ok i will try
with 10 mm
If that not work i wil use varicaps BB109 on 3V and 11 & 10 turns of 0.5
on 2.5mm diameter ..that must work!
Old 3rd Aug 2021, 12:43 pm   #9
orbanp1
For some ideas look at the Technics ST-930 receiver, though it uses an eight-gang tuning capacitor.
Here is a good article on it with analysis and modifications:
http://www.ham-radio.com/k6sti/st-9030.htm
Regards, Peter
orbanp1 is offline
