24th Jul 2021, 12:16 pm | #21 | |
Re: Wima 5/35 capacitor
24th Jul 2021, 12:48 pm | #22 |
While that's true, they can and will fail in a non-pop way when fed from higher impedance sources. Grundig used coupling tantalums in their somewhat higher end hifi amplifiers, and they're prone to generating crackling, popping or noisy noises that you'd normally attribute to failing transistors (those with black legs for example). I haven't paid attention to the working voltage, will do if I get any more in, but I don't think they were as severely underdimensioned as in your example.
24th Jul 2021, 12:50 pm | #23 | |
24th Jul 2021, 1:35 pm | #24 |
You are correct Maarten it's a 120uH Cambion inductor I honestly thought it was a tantalum. I managed to find a better copy of the service manual and all became clear. Next problem finding one.
25th Jul 2021, 5:21 pm | #25 |
The conductor is a 120uH Cambion type there are no further details in the service manual, it's on a oscillator board the most volts involved is 20 VDC what can I replace it with? Thanks .
25th Jul 2021, 8:10 pm | #26 |
Thank you for the interesting information about tantalum capacitors. I didn't realise there were others than the dipped bead types, and was confused reading how reliable they were when I knew that some in my tape deck were causing problems!
The little bead ones are quite useful for replacing equivalent parts in my Uhers, so if your offer was serious julesomega, then I'd be interested! deliverance - here are some 120 µH leaded inductors from RS. It appears Cambion still exist, so you could ask them if they have an equivalent. I am not a circuit expert so I don't know if there's a stringent and particular requirement for this part that means a generic inductor won't be suitable. |
25th Jul 2021, 11:49 pm | #27 |
Oh how embarrassing I knew I'd seen things like that somewhere. I've got a few values but not 120uH in that style
- Julian It's good here |
26th Jul 2021, 5:46 pm | #28 |
As the late L Lawry-Johns commented in Practical Television many years ago. 'Beware the Blue Tant.' J.
26th Jul 2021, 6:00 pm | #29 |
There are certainly inductors in that style. My Marconi signal generator is full of them in the power supply decoupling section. Need to remove them to replace the blue tants.
