Old 24th Jul 2021, 6:55 pm   #21
G.Castle
Default Re: Understanding Dual Can Electrolytics
A friend told me that they called an ESR meter a "Smugometer" because in a service and repair scenario at best they can only confirm a diagnosis.
If they don't leak physically, there's no excessive electrical leakage at rated voltage, and hum or ripple on the supply, then any replacement is likely to have inferior longevity.
Just my humble opinion.
G.Castle is offline
Old 24th Jul 2021, 6:56 pm   #22
HamishBoxer
HamishBoxer's Avatar
Graham's figures give you a good guide as to where readings should be at. Peak meters BTW are first class I add.
HamishBoxer is offline
Old 27th Jul 2021, 10:49 pm   #23
Graham G3ZVT
Graham G3ZVT's Avatar
About 15 years I was introduced to one of Bob Parker's ESR meters and used it to locate the cause of many S.M. power supply problems by testing the electrolytics in situ
Still, before that I wouldn't have thought about measuring ESR like that.
I knew what "effective series resistance" was, but only in the context of "equivalent circuits" not as a fault-finding strategy.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 27th Jul 2021, 11:32 pm   #24
Red to black
Red to black's Avatar
The ESR meter was (and still is) a valuable tool as far as SMPS are concerned.
This became more apparent with the advent of certain satellite receivers such as the Analogue Amstrad SRD510 and Pace PRD800/900 series.
Initially we wondered why they wouldn't work when the caps measured ok via more 'normal' means but worked when they were replaced, and I think it was by a man called Ray Porter in one of the TV mags that first explained what ESR actually was.
Then the various technical departments caught up! and the rest was history, the Peak Atlas ESR meter being a most useful tool in the workshop around this time.
Red to black is offline
Old 28th Jul 2021, 9:28 am   #25
peter_scott
peter_scott's Avatar
Originally Posted by Station X View Post
In some respects modern capacitance meters are one of the worst things ever invented. People don't seem to understand that capacitors fail because of electrical leakage which can't be checked except at the full working voltage.
In some ways modern capacitance testers work quite well because if the capacitor reads significantly high in value you know its leaky. There are lots of old Meggers around and they test quite well for leakage at high voltage.
Peter
peter_scott is offline
Old 28th Jul 2021, 12:26 pm   #26
Station X
Station X's Avatar
I wouldn't disagree. It's just that some people don't understand why the measured capacitance is higher than that stated on the capacitor. itself.
Graham. Forum Moderator
Station X is offline
Old 28th Jul 2021, 12:44 pm   #27
Maarten
You wouldn't test a steam boiler designed to work at 200 psi with a 2 psi hydraulic test would you?
Realising that if it fails at 2 psi, it's surely bad, can help turning them into useful instruments. Every instrument has its limitations and when the operator takes them into account, can still be useful.
Maarten is offline
Old 28th Jul 2021, 7:47 pm   #28
Heatercathodeshort
Heatercathodeshort's Avatar
Yes yes yes. Like a large quantity of test equipment they are only a guide and remember that many older electrolytic capacitors had a tolerance of + 100% - 10%. They are practically impossible to test with any certainty. John.
Heatercathodeshort is offline
Old 29th Jul 2021, 1:12 am   #29
G.Castle
Yes, and I'd agree that is an excellent use for such a piece of test equipment I'm sure.
However as the thread was intended to be I believe about the perhaps two or three electrolytic capacitors that may be found in a bog standard mid twentieth century wireless set, there's little use for anything other than method and observation: is the end swollen or leaking? Does it get hot, or draw excessive leakage current? Is there excessive ripple/hum? If yes it's time to act.
Watched a guy doing a set once that had low audio gain and worse than usual bass response, (cathode resistor bypass cap). After faffing around with replacement of three resistors that were a few percent over value, and using an Armada of test equipment including a capacitance bridge, (OK), and an ESR meter he came to the same conclusions.
He held up the ESR meter and announced "worth its weight in gold"
I'm sure they are marvelous in their place, but experience and good fault finding technique is far more useful.
What's not unusual is when an enthusiastic amateur gets hold of these wonderful pieces of test equipment but are then unsure how to translate the readings into a course of action.
Regards,
Greg.
G.Castle is offline
Old 29th Jul 2021, 6:04 am   #30
ricard
ricard's Avatar
As noted above, when it comes to PSU filtering caps, if they don't get warm and there's no excessive ripple, they're probably serviceable. But the question is, how much ripple is too much? Is there are rule of thumb for valve equipment, say 10% of the B+ voltage? Or is it better to temporarily connect a capacitor of similar value in parallel and observe if it makes any noticeable difference (improvement hopefully) to the audible hum?
ricard is offline
Old 29th Jul 2021, 10:16 am   #31
DonaldStott
DonaldStott's Avatar
As I mentioned in my opening Post "Not sure what those numbers are telling me but more than happy to be enlightened - thanks in advance. "
BVWS Member
DonaldStott is offline
