Old 6th Feb 2021, 1:10 pm   #1
jonnybear
jonnybear's Avatar
Default Parker Pen Refill Recycle Probe
I hate throwing things away, already used one of these as trimmer tool for a brass radio trimmer slug, today I found a couple of used refills in recycling my wife had thrown out, ever the Scrooge I thought they would make a nice tactile probe, using a cable clip masonry nail and a bit of rubber tubing, I set to work
First remove the ball and holder, clean out any old ink left with hot water, then force fit pointed end of nail, then grind head to a point, slide on rubber pipe and you have a useful tool.
John
ID:	226057   Click image for larger version
jonnybear is offline
Old 6th Feb 2021, 5:36 pm   #2
Kentode
Kentode's Avatar
Default Re: Parker Pen Refill Recycle Probe
I retrieved a ballpoint pen from the bin and used it for the probe on my Velleman signal generator!
I'm not tight, just careful!
Regards, Ken.
BVWS member
Kentode is offline
Old 16th Mar 2021, 9:25 am   #3
jonnybear
jonnybear's Avatar
Mk2 if you cut the shank further up and give it a light squeeze with pliers to make a oblong profile,it is suitable for larger profile brass trimmers, and being steel is very robust will not open up and round off trimmer.
John
Old 16th Mar 2021, 10:09 am   #4
vinrads
Thanks John that tip is a good tip Mick.
vinrads is offline
