27th Sep 2020, 9:49 am | #1 |
Bardwell guitar amp
Hi all
I have one of those Bardwells amp boards and a 12" 8ohm speaker. I was simply going to use the speaker connected to a guitar amp and build a box to house the speaker, but I was wondering if I could use the amp board to make a combo. What I want to ask is, can I safely connect one speaker to what is, I believe, a stereo amp? Second question is what sort of power supply would be best? Martjn
Is it live, or is it... no, it's live actually... |
27th Sep 2020, 11:48 am | #2 |
Re: Bardwell guitar amp
Is this the amplifier, there have been a few threads about it: https://www.vintage-radio.net/forum/...7&postcount=27
27th Sep 2020, 12:55 pm | #3 |
If you are only going to use one speaker then you must connect a "dummy load" (a resistor) to the unused channell. Even so, you may be dissappointed with the sound.
This little amp will have great difficulty handling the transients of a guitar.
Edward. |
27th Sep 2020, 3:03 pm | #4 |
Thanks chaps. Resistor between o e speaker out and common ground?
My original idea was to make a simple speaker cab to use with a small guitar amp head I have, but that is way too high gain and will be sold soon. It has no clean setting at all! It seems to start at 11! I will lash up the speaker and amp and see how it sounds. I have no big expectations, but recall that I did manage for a few years in my teens using a Sony midi system.
27th Sep 2020, 5:28 pm | #5 |
As you're using an 8 Ohm speaker, you'd need an 8 Ohm resistor across the unused channel output and ground. As that's not a preferred value, I guess 2 x 15 Ohm in parallel (7.5 Ohms) would suffice. If you use a couple of 5 Watt ceramic ones they would handle 10 Watts between them, so that would easily cope with the output of the unused channel.
EG, order code 924-815 at this link: https://www.esr.co.uk/components/pro...-resistors.htm Amazing little amps - virtually indestructible. Bardwells had boxes full of them in their cellar that never shifted for twenty years till word got out. This is what they sound like, or should do: https://www.youtube.com/watch?v=5gZXleVOTIs Hope that helps.
27th Sep 2020, 6:36 pm | #6 |
Genuine question - if the OP puts a short across the input of the unused channel, is a resistor still necessary?
George |
27th Sep 2020, 7:00 pm | #7 |
Thanks David. We used to play Klaus Wunderlich when I was the Saturday lad at Romers HiFi!
I think I may need to order a few bits for the amp such as new caps perhaps and, given the feedback so far, am also wondering whether to make a box and treat it as a stereo amp instead. I need neither a hifi amp nor a guitar amp as such, but I fancy an easy project with a useful outcome.
28th Sep 2020, 9:25 am | #8 |
Why not - it makes so much more sense. Ideally a pair of 8" full-range, 8 ohm, 5 Watt speakers. The sound would be fuller and more widely spread.
Edward. |
