13th Sep 2020, 10:34 am | #1 |
Location: London, UK. Bury, Lancashire quite regularly :)
Hacker Mayflower II.
Bought in Rotherham and brought home to London, sitting on the round tuit pile for a couple of years, finally got round to fixing it.
Cabinet in pretty decent condition I'm pleased to say as woodwork is not my forte. Initially it motor boated like crazy, very low frequency, fit to pop the speaker cone given half a chance. It had obviously had attention before, this appeared to have been limited to replacing the odd coupling cap, crudely restuffing the main reservoir / smoothing can, changing a single ECL86 cathode bias resistor (220R,) and replacing the on-off volume control with a Radiospares example (1 Meg log law /double pole switch.) So in we dived. Hacker had thoughtfully (!) wrapped component leads tightly around their tags so every component was a swine to remove and test. All the non polarised and electrolytic caps leaked - the red tubular ceramics were fine, as expected. The bodged main smoother was replaced. Virtually every resistor was out of tolerance, some by as much as 50%. The 220K ones were particularly bad for some reason. So a blanket change was the order of the day. Only one avoidable error, the solder hadn't "stuck" to one end of R26 (220K) for some reason, so on first test it was silent. V6a anode was at 208 volts and the cathode at 5.6 volts virtually floating. This resolved it worked very nicely.
Thermionic Emission, warms the cockles of your tubes. Last edited by Nanozeugma; 13th Sep 2020 at 10:50 am. |
14th Sep 2020, 11:47 am | #2 |
Re: Hacker Mayflower II.
A very worthwhile restoration. These are one of the best sounding radios of this class.
Simon BVWS member |
14th Sep 2020, 12:35 pm | #3 |
Yes, well done.
As Simon's said, these are lovely sets; well-engineered, well-built, and lovely to use and listen to. My late grandfather bought one secondhand in the late 1970s, got a great deal of pleasure from it, and I still use it now. Some might have been more conservative, but like you, I would have changed a similar number of components. How about a picture of the chassis? They do look lovely, sitting under the huge Goodmans LS. Nick. |
14th Sep 2020, 5:37 pm | #4 |
That's hard work. The procedure I use is to snip the faulty component leads as close as possible to their bodies, then I wind the leads on the new component into a small, tight 'tube' using small round nosed pliers. I then insert the 'tube' over the existing leads and solder in place. That way, you don't have to spend ages trying to remove every last drop of solder from mounting tags and untangling the leads of components - perhaps overheating them in the process. The original soldering on the soldering tag remains solid and untouched. Photos attache of some I've done today on a Philips set
14th Sep 2020, 6:17 pm | #5 |
I do it like Nanozeugma most of the time, especially on sets like Hackers which are a joy to work on because of their nice layout, and which deserve to stay looking smart under the chassis. Your example, Steve, looks like a Grundig or similar... great performers, but what a rat's nest underneath.
However, Steve's point about the risk of overheating (or mechanical damage) during tricky de-soldering work is very valid, so I do it Steve's way if access is tricky and with heat-sensitive components (which includes tags which have PVC-insulated wires attached to them; molten and shrunken PVC insulation looks horrible!). Here's a pic of one of the tag boards on a very sad Hacker which I restored recently. It had been run in an overheated state for long periods, and lots of components were utterly cooked! Note the way I've attached a little polystyrene cap underneath (and in parallel) to the 10K resistor - similar "tube" technique. Last edited by Nickthedentist; 14th Sep 2020 at 6:28 pm. |
14th Sep 2020, 6:23 pm | #6 |
And here's another pic from the depths of a Cossor VHF set's chassis, using Steve's "tube" technique on the lower connection, because there simply wasn't good enough access to do it any other way, without major (and risky) dismantling.
15th Sep 2020, 11:51 am | #7 | |
This is "before". Note the "superbly" restuffed main reservoir / smoother...! The white stuff is some sort of expanding foam.
Thermionic Emission, warms the cockles of your tubes. Last edited by Nanozeugma; 15th Sep 2020 at 12:01 pm. |
15th Sep 2020, 11:53 am | #8 |
This is "after".
Thermionic Emission, warms the cockles of your tubes. |
15th Sep 2020, 12:16 pm | #9 |
Wow, that's more like it. Quality job!
15th Sep 2020, 1:38 pm | #10 |
Thank you
In regard to Steve's (and your) comments regarding removing *everything* back to the tag - or not... The point made about the potential problems with heat is well made and well taken. On the odd occasion where PVC insulation has shrunk back and become unsightly, I simply replace the cable run as well Although I still persist with removing everything (might be OCD, I've been accused of it,) I did experiment with Steve's methodology when restoring a Heathkit AFM-1 recently. I found you could make a nice "coil" on the end of your replacement component using a sewing needle and miniature needle nosed pliers. I have a Telefunken chassis to restore when I get time which is, as alluded to, an absolute rats nest underneath (and on top as well, if truth be told.) For that one, I think the "coil" method will be followed
15th Sep 2020, 4:06 pm | #11 |
Did you re-stuff Bridge Rectifier, or is it original? When I did my RV14 some years since I bolted a modern replacement bridge to the chassis, and added a resistor.
John.
My favourite text message "I'll be there in five minutes, if not read again" |
15th Sep 2020, 5:35 pm | #12 | |
The Selenium rectifier is original. I viewed it with suspicion, given that the original reservoir / smoothing can had obviously gone to meet it's maker and been replaced - after a fashion - before I got the radio. However, it proved to be sound and puts out bags of HT which does not collapse as the valves draw current. So I left it alone.
