Old 30th Aug 2020, 2:12 pm   #1
vinrads
Default Excelsior 55 dial drive .
Having made a new front panel, I removed all the pulleys etc, the pulleys were fixed on pillars which were riveted to the front panel, these had to be drilled out, how to fix them on the new panel! I drilled and tapped for 6 BA screws, the other fixings were just bent over lugs so no problem. Time to attempt the dial drive, some two hours later I had it working, it would have been sooner if the picture on the internet was correct, it seemed to be OK but when offering the dial I discovered the tracking was reversed, LF was HF and reverse buer, time to get the thinking hat on, so the cords on the drum need reversing! not so easy, but I had success in the end, there is a clever little device which allows only a few turns on the tuning spindle.
New dials made by Ben Dijkma .
The next job is to paint the case, needs a bit of thinking about.
Mick.
ID:	214620   Click image for larger version
ID:	214621   Click image for larger version
ID:	214622   Click image for larger version
vinrads is offline
Old 30th Aug 2020, 11:29 pm   #2
Herald1360
Herald1360's Avatar
Default Re: Excelsior 55 dial drive .
Hats off and a salute to the escapologist for getting out of that!
What are the two mini drives at the bottom for?
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 31st Aug 2020, 7:56 am   #3
vinrads
Hi Chris the small drums are for the waveband and tone switch indicators. Mick.
vinrads is offline
Old 31st Aug 2020, 11:58 am   #4
Herald1360
Herald1360's Avatar
Ah, yes!
Why use just a knob with a mark on it and a few engraved letters when some string, a spring in some sleeving, a drum and a pulley can be added to the mix?
My most "Gallic" set is quite restrained in comparison.
....__________
Old 31st Aug 2020, 9:11 pm   #5
vinrads
That's nice. is it the original dial , I notice the mirror ones do suffer from foxing! I think that what they call it ,anyway it's were the damp get's in , Mick.
vinrads is offline
