Old 19th Aug 2006, 9:02 pm   #1
tvden
tvden's Avatar
Exclamation SONY 9-90UB hum (intercarrier buzz)
Hi
I have now located a set of knobs for this set, this just leaves the problem of hum on sound!
This happens when the camera changes shots so sound is OK, then a camera change starts the hum and then this goes off when the camera changes shots again.
I know nothing at all about transistor TVs - does anyone know what is causing this fault?
tvden is offline
Old 19th Aug 2006, 11:56 pm   #2
Steve_P
Steve_P's Avatar
Default Re: SONY 9-90UB Hum
These again. I must be missing something with these - ah well....
This problem was common on valve sets too - ever worked on a Thorn 1400 ?, there were tons of mods for this. Now there's an open door for memories! Anyway, it's called Vision on Sound Buzz, and it's noticably annoying as a camera change will set it off or stop it.
The two diodes are D403 and D404. These come out of a variable coil thing. Give that a tweak.
Steve P
P.S. Getting to it is your problem....!
Steve_P is offline
Old 20th Aug 2006, 1:58 pm   #3
tvden
tvden's Avatar
Steve many thanks for extra info, I will prob start another thread on the 1400 regards TVden
tvden is offline
