Old 26th Jul 2020, 6:26 pm   #1
vinrads
Default Encapsulating output tx's
Just a thought before I paint these , I have fitted two EL84 push pull output tx's in aluminium boxes to make them look pretty , question ! the wires may be crossing each other primary side sec should be ok , thought's please Mick.
vinrads is offline   Reply With Quote
Old 26th Jul 2020, 7:06 pm   #2
merlinmaxwell
merlinmaxwell's Avatar
Default Re: Encapsulating output tx's
No problem at all (as long as the insulation holds up!). All the wires carry the same signal so crossover isn't an issue.
Old 26th Jul 2020, 7:33 pm   #3
vinrads
Thank's that's good news , a picture of the tx's before painting , they were made of 3" box section the top was glued on using araldite the corners rounded off , they will be satin black. "nice " Mick.
Old 5th Aug 2020, 1:44 pm   #4
retailer
That's a great way to finish off a TX, I was thinking of folding something up but this looks better.
retailer is offline   Reply With Quote
Old 5th Aug 2020, 5:37 pm   #5
vinrads
Hi I have not fitted them yet so here is a picture of them painted, good luck with yours, Mick.
Old 5th Aug 2020, 6:27 pm   #6
sortedradio
sortedradio's Avatar
They look great!
Martin
BVWS member
GQRP Club
sortedradio is offline   Reply With Quote
Old 6th Aug 2020, 5:43 pm   #7
Petedox
Petedox's Avatar
That's a brilliant idea Mick, I built a 300B SET amp a couple of years back and couldn't really find decent enclosures that fitted the Hammond transformers and looked right (plus they were pretty expensive). Also I rather underestimated the weight of the finished amp meaning it was easy to slightly twist the chassis when moving unless supported equally all round.
This has inspired me to revisit the project and start some metal bashing, so thanks!
Pete
Petedox is offline   Reply With Quote
Old 6th Aug 2020, 5:59 pm   #8
vinrads
Hi Pete ,good for you for revisiting the project , I found the ali box section on E Bay , good luck with your project. Mick.
Old 7th Aug 2020, 7:20 pm   #9
Bookman
Hi Mick,
Any reason why you did not bother potting these items; just curious?
Joe
Bookman is offline   Reply With Quote
Old 7th Aug 2020, 7:43 pm   #10
vinrads
Hi Joe , the transformers were ex equipment , I had to have one rewound , if the other one packed up in the near future ,I can easily remove it and replace , no other reason , Mick.
