16th May 2007, 9:12 pm | #1 |
TV24 Picture centreing
Hi Everyone,
I hate to appear dim but the picture on the above set is out of centre. How do I centre it? Many thanks Lee
Lee |
16th May 2007, 9:20 pm | #2 |
Re: TV24 Picture centreing
Perhaps this may help?
Go to http://www.oldtellys.co.uk/otindex.html Click on Monochrome Tubes. There's a diagram of a typical tube neck from an old set. I should know, it's my site! Cheers, Steve P
17th May 2007, 1:40 pm | #3 |
Hi Lee,
not a stupid question with the TV22/24 because it is an unusual, but very effective picture shift method. Slacken (only slightly) the three brass nuts at the back of the focus assembley. You will find two things that look like screw heads at the back of the focus assmebly, these are cams which you can rotate with a screw driver. One cam is for up and down and the other is for side to side. When finnished re-tighten the three nuts. Warning: Whilst the three nuts are slack do not try to adjust the focus. I hope this makes sense. Andy |
