14th Jan 2013, 3:38 pm | #1 |
5.25 & 3.5 inch diskettes -any use still?
Hello,
I'm trying to have a tidy at home and have tripped over another box of computer floppy discs, manuals and CDs. This reminded me that I have a pile of similar bits growing in the loft -including an IBM PS/2 with external 5.25" drive. Not sure really why I am keeping them! Are 5.25 and 3.5 inch floppy discs of any use to collectors or are there so many about still that I should just send them down the tip? Have around 40 5.25" 3M DS DD "diskettes", some still sealed in boxes and a similar amount of 3.5", probably half of them used. There are also a few Magazine cover discs (mainly useless demos) and DOS 4, boxed with manuals -all 5.25". This isn't an "Items Offered" post, so don't place any 'orders' here. I would create a more detailed list in the correct section if people think that they should be steered away from landfill. Regards, SR |
14th Jan 2013, 3:45 pm | #2 |
Re: 5.25 & 3.5 inch diskettes -any use still?
Are the 3½" discs 1.4M (HD) or 720K (DD)? The 1.4M ones have a second hole on the opposite side from the write-protection hole.
14th Jan 2013, 4:06 pm | #3 |
Hello Dave, Pretty much all the 3.5" are HD as they have the second hole. I did buy a pack of WHSmith 720K DD ones and some of those are floating about. There are some Maxells (MF2HD) promising 2MB.
SR |
14th Jan 2013, 7:06 pm | #4 |
Yes, these disks are worth keeping or offering. There are still people (like me) using them and looking for blank ones. DD (as opposed to HD) are particularly difficult, being older and less numerous.
Chris |
14th Jan 2013, 10:46 pm | #5 |
In my early days we had 8" floppies... yes 8" with hard sectors determined by holes punched near the hub as well as soft sectored with just one index hole per rotation. 125KB was storage for single sided disks then!!
14th Jan 2013, 11:17 pm | #6 |
I must confess that I too am old enough to remember 8" floppies. DEC RX01 perhaps? I think they were soft sectored.
14th Jan 2013, 11:54 pm | #7 |
Both 3.5 and 5.25 low density are useful for collectors especially for Commodore 64 and Amiga use. Definatley don't take them to the tip!!!
15th Jan 2013, 12:11 pm | #8 |
For the sake of anyone who has never seen an 8" disc (and for the rest of us to wallow in nostalgia), here is one of mine. I notice, however, that even the soft-sectored discs were a lot less standardised than the 5¼" ones - having just looked at one of my Cromemco 8" discs, I notice that the index hole is positioned differently.
15th Jan 2013, 2:26 pm | #9 |
The beauty of 8" and 5-1/4" floppies was that you could drive you office chair over them and, even though wrinkled, they'd still work perfectly! I never had a dead 5-1/4" but threw endless 3-1/2" floppies away which failed.
Yes they are collectable. |
16th Jan 2013, 3:57 am | #10 |
Circa 1990 I found what was, according to its printed lable, a single-sided 3 1/2" disk in one of the scrap bins at the Marconi Research Centre where I was then working. I think it was made by SONY. The only visible difference from a 720k disk was that the sliding cover would latch in the open position, requiring you to squeeze the corner of the casing to release it to cover the magnetic surface. Both sides of the disk were visible when the cover was slid open. It wouldn't read or format either in a Windows 98PC or an Amstrad PCW 3 1/2" drive. I have never come across any references to single-sided 3 1/2" disks.
16th Jan 2013, 7:16 am | #11 |
Early Apple Macs and Atari STs could use single sided 3.5in disks. Double sided soon became the standard, though.
16th Jan 2013, 1:37 pm | #12 |
I am not quite old enough to have used 8" discs but I do remember 5.25" ones.
Circa 2000 NASA were said to be trawling eBay and similar sites for 8" discs and drives as the space shuttle used them! For the record the HD 3.5" floppies are still quite easy to obtain, my local WH Smiths still has them on sale. The 720K discs are harder but it's quite possible to use a 1.4Mb disc in a drive designed for 720K...also many early Atari ST users utilised double sided discs in a single sided drive...it merely read and wrote to one side only. |
16th Jan 2013, 1:47 pm | #13 |
I was in the floppy drive business in 1980s and a lot of the US made 8" drives were very unstable and needed regular realignment. My company sold Mitsubishi 8" and 5 1/4" well engineered drives that went on for ever without being touched.
16th Jan 2013, 2:17 pm | #14 |
We still use eight-inch floppies to carry our HF broadcast schedule. There have been occasional drive problems, but we haven't had one for years.
Attached is a pic of part of our BBC D&ED Automatic Control System, incorporating dual 8" drives.
Regds, Russell W. B. G4YLI. |
16th Jan 2013, 5:58 pm | #15 |
From memory the index hole on the 8inch floppies indicated whether it was high or low density, there were certainly two different locations.
Robin |
16th Jan 2013, 9:18 pm | #16 |
Do you actually have experience of doing this? I ask because I have never been able to make a 720K drive access or format a 1.4M disc, even with the second hole covered up. Presumably, however, the hole would only be detected by a 1.4M drive and is irrelevant to a 720K one.
16th Jan 2013, 9:31 pm | #17 |
Looking more carefully at one of my Cromemco discs, I see that it does, in fact, have two index holes. The one in the same place as the one I displayed earlier being covered up by a sticker.
Judging by the legend on the sticker, it would appear that the different positions indicate whether the disc is single- or double-sided.
16th Jan 2013, 9:52 pm | #18 |
I have formatted 1.44M disks to 720k in the external 720k 3 1/2" drive I fitted to my Amstrad PCW8256. While it usually worked, formtting and writing took a long time as it sounded as if the drive was repetitively going back for another go to complete the operation. The respective magnetic coatings of 720k and 1.44M disks have different coercivities. I haven't tried to format a 1.44M to 720K using a 1.44 M drive.
16th Jan 2013, 10:17 pm | #19 |
I once upon a time drilled the second hole in some 720K discs and formatted them to 1.44 meg without any trouble.
16th Jan 2013, 10:31 pm | #20 | |
In contrast, 360k and 1.2M 5.25" discs have very different coercivities, so 1.2M discs are completely hopeless in non-HD drives. Chris
