Old 19th Jan 2020, 9:21 pm   #341
john_newcombe
Default Re: Gemini 80-Bus System
John: Thanks for the above I have the Emulator booting and the disk image works fine. I haven't looked closely but from the size I am thinking that this is a raw image rather than a DMP (or other layout), is this correct? I didn't appreciate that XBeaver could use raw images. The image won't boot the actual machine (using the Gotek) which is a little puzzling, however, I will investigate this further as this could simply be a Gotek config issue.
I have attached links to four photographs of IC 14 in the hope this will help you unravel this particular mystery. Let me know if you need more.
https://glasstty.com/wiki/index.php/...849_IC14_1.jpg
https://glasstty.com/wiki/index.php/...849_IC14_2.jpg
https://glasstty.com/wiki/index.php/...849_IC14_3.jpg
https://glasstty.com/wiki/index.php/...849_IC14_4.jpg
john_newcombe is offline
Old 19th Jan 2020, 11:08 pm   #342
JohnBHanson
Raw is the format that is used if a format option is not specified (eg the default).
Note that some formats (such as compressed .imd) are read only.
Most non raw formats are copied into ram or parsed on initialisation.
A useful trick with raw format is to use a symbolic link in the configuration file. It is then possible to change the symbolic link from a command shell while xbeaver is running to change floppy disk. Do not try this trick with formats that are cached
ps - check the first sector matches your system especially the first two bytes.
JohnBHanson is offline
Old 20th Jan 2020, 5:33 am   #343
JohnBHanson
Looks like IC14 is a 74LS51 - thanks John for all the work
Old 20th Jan 2020, 5:44 am   #344
JohnBHanson
I have checked the signature wanted in simon.rom (offset 0xf031) and it is 6d 47 which is correct for booting the mfb floppy image I posted.
Old 20th Jan 2020, 9:59 am   #345
john_newcombe
Whilst investigating the Gotek issue, I have started to get confused over the disk layouts. I would appreciate it if you confirm my understanding. i.e.
  • The Gemini Bios interprets GEMDDDS (double sided 35 track disks) as 70 track disks with 10 (512 byte) sectors per track.
  • The Gemini Bios interprets GEMQDDS (double sided 80 track disks) as 80 track disks with 20 (512 byte) sectors per track.
Is this correct?
With GEMDDDS the disk was accessed in the order; Side 0, Trk 0, Sect 0-9 followed by Side 1 Trk 0 Sect 0-9 etc. and the Goteks 'interleaved' file-layout setting seemed to work well...
Code:
#   interleaved:   Interleaved cylinder ordering: c0s0, c0s1, c1s0, c1s1, ...
My confusion is that I cannot get my head around what the physical layout of the GEMQDDS disk is. Looking at the disk image it looks like the sectors are arranged differently with what is presumably CPM stored on sectors 1 to 10 and 21-30 with 11-20 all set to E5. I am wondering if for the purposes of the Gotek whether these need to be shuffled in someway, I certainly can give it a try as it will only take a few lines of code.
In terms of the Gotek, my thinking is that a physical disk has 2 sides, 35/80 cylinders and 10, 512 byte, sectors per track irrespective of how the data is arranged, however, there is a question of how the Gotek accesses the disk image file. Based on the successful GEMDDDS images on the rack system I am assuming it simply accesses them in order.
For completeness, the full range of file layout options are as follows...
Code:
# Optional: Image file track layout. Default is "interleaved".
# Comma-separated values:
#   sequential:    Sequential cylinder ordering: all side 0, then side 1.
#   reverse-sideN: Side-N cylinders are ordered from high to low (N=0,1).
#   sides-swapped: Sides 0 and 1 ordering is swapped in the image file.
#   eg. "sequential,reverse-side1"
#file-layout = interleaved
Old 20th Jan 2020, 10:23 am   #346
JohnBHanson
I think you want interleaved. It actually does not matter what CP/M believes it is actually what is recorded in the file that is important and that is defined by the geometry statement in the .cfg file for the emulator.
QDDS format is 80 tracks, 2 sides and 10 sectors per track. However CP/M does not understand sides and hence the bios re-maps the side count by doubling either the number of sectors of the number of tracks. When the bios drives the hardware it actually drives it as 80 cylinders 2 sides and 10 sectors per track and that is what you need for your floppy setup.
The next issue is the file format should be consistent for the gotek and the xbeaver emulator. This is controlled by the geometry parameter depending on the letter 'S' being present. In raw format without the S option the order of tracks in the file is cyl0side0 cyl0side1, cyl1side0, cyl1side1. Each track consisting of sectors 0..9 in order.
see routine flp_linear_block in floppy.c for details.
So I think you need interleaved set for your file layout - which appears to be also the default.
I hope that helps.
Old 20th Jan 2020, 10:51 am   #347
john_newcombe
OK, thanks, but what about the bootable floppy image you sent me?
When you helped me construct the DDDS disk image for the Gotek the boot sector was on side 0 sector 0 and cp/m was on the following 16 sectors (if I remember correctly), with all of the sectors stored in the image in order, it all worked nicely with the interleaves setting.
The image we have for QDDS seems to use side 0 sector 0 for the boot sector then sectors 1-10 and sectors 20-30 for the OS, are you saying that I can just ignore that and leave it all to the boot loader/bios to sort this out?
Old 20th Jan 2020, 11:04 am   #348
JohnBHanson
I enclose a log of the disk activity for booting - this should explain everything....
Old 23rd Jan 2020, 2:57 am   #349
john_newcombe
Many thanks, eally appreciated. I will take a look.
Old 27th Mar 2020, 10:03 pm   #350
fighne65
So having spent my first years out of college working on Nascom and Gemini Systems 80Bus boards if I can be of help please ask. I still have a G811 running R/PM as my Z80 board.
fighne65 is offline
Old 16th Apr 2020, 1:44 pm   #351
john_newcombe
Thanks so much, I am sure your knowledge will get tapped. I am in the middle of trying to bring a Gemini MFB back to life but have had to step away for a few weeks/months. Hopefully will be able to get to look at it again soon, the support of this forum has been amazing.
I have a G811 with RP/M running also, it's using a Gotek for storage at the moment as the floppy I have is a little unreliable.
Old 16th Apr 2020, 4:38 pm   #352
AdrianH
AdrianH's Avatar
My word, Gemini Systems CP/M Z80 8 bit systems, this is all bringing back memories to me.
I was a Nascom II user, and then later bought a Gemini system with an 8 inch 5Meg drive, how many years ago was that I wonder?
I passed loads of gear, boards mag's etc to a collector that lived in Leyland many years ago, so perhaps some of the old boards are still around, a speech synth board, paged ram, 19 inch case etc. Also a twin tape drive system.
Memories of graphics programs on a green screen drawing strange shapes.
Adrian
AdrianH is offline
Old 22nd Apr 2020, 10:56 am   #353
john_newcombe
Adrian
Good to hear from you, I think we need to get in touch with that collector. These things are quite rare and I would love to try and safe and share as much of the system software etc as I can.
Old 22nd Apr 2020, 8:59 pm   #354
AdrianH
AdrianH's Avatar
There is not a chance I can remember any details, can only suggest you try this web page (If you can cope with the green text) http://www.nascomhomepage.com
Adrian
AdrianH is offline
Old 24th Apr 2020, 10:18 am   #355
qazxsw123
I have an interesting problem other members may be able to help with.
using a gemini 3 card system gm849/813/832 running cpm 2.2 when I enter a simple "DIR" command only one directory item is listed but if I enter "DIR *.COM" all the com files are listed, same for "DIR *.TXT" I've tried this with different hardware and different floppy drives with different copies of CPM. using the SD program will list all the files on the disk.
Any suggestions?
qazxsw123 is offline
Old 24th Apr 2020, 1:22 pm   #356
kan_turk
kan_turk's Avatar
Hi
Have you tried “DIR *.*” ?
kan_turk is offline
Old 24th Apr 2020, 2:30 pm   #357
qazxsw123
yes only one file displayed, if i look in the temp area above f700h I can see a number of files so the directory was read correctly and try and run one of these programs they run correctly.
Old 30th Apr 2020, 8:31 pm   #358
Mixtel0
Mixtel0's Avatar
Hiya Adrian!
(Waves...)
I'm Mick, that collector in Leyland. My current collection of Nascom & Gemini stuff (and quite a bit of info) is at http://www.nascom.info
Funnily enough, I started reading this forum yesterday in the hope that there might be something on disk interfacing for the Gemini. I've been tidying out my shed and came across a "kit" (i.e. pile of bits) for what I assume was my old Nascom-1 19" rack. It made me think that perhaps it's time I had a working Gemini. I have previously tested a GM813 and an IVC and they appear to be working - unlike either of the Gemini keyboards that I have. I've just ordered one of the cheap logic analyzers off ebay so figuring out what's up should be easy enough with that.
Currently I've no means to read & write EPROMs so that may have to wait a while. I don't think I have anything that I haven't seen mentioned on here already though. Actually, the whole project is going to have to wait until I've finished sorting the shed out. lol.
Mixtel0 is offline
Old 2nd May 2020, 12:54 pm   #359
john_newcombe
Originally Posted by Mixtel0 View Post
Hiya Adrian!
(Waves...)
I can probably sort out any eproms you might need I have a decent programmer, so when you are ready just send me a hex file. an eprom (blank or otherwise) along with a envelope/stamp for returning it. I have some Gemini eproms here anyway so may not even need a hex file. Glad to help.
Old 2nd May 2020, 2:50 pm   #360
qazxsw123
disk image files for cpm 2.2 bios 3.5 and basic programs
