Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval. |
17th Feb 2021, 2:31 pm | #1 |
Unable to upload pictures
I am trying to post some radios for sale and keep getting errors when trying to upload the pictures. I get service unavailable due to maintenance or capacity problems.
is there a problem with the forum server? Peter |
17th Feb 2021, 3:11 pm | #2 |
Re: Unable to upload pictures
Not aware there is but have not tried to upload today, although I need to.
17th Feb 2021, 3:27 pm | #3 |
You will occasionally see this message if the server is unusually busy. It should be OK if you wait a couple of minutes and try again. Often the server is only overcapacity for a second or two.
17th Feb 2021, 4:43 pm | #4 |
I have just tried again. It sits there for ages saying uploading then gives the following message:
"Service Unavailable The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later. Additionally, a 503 Service Unavailable error was encountered while trying to use an ErrorDocument to handle the request." Peter |
17th Feb 2021, 4:56 pm | #5 |
Just a quick try
Seems to work OK for me Cheers Mike T
Invisible airwaves crackle with life or at least they used to Mike T BVWS member. www.cossor.co.uk Last edited by Cobaltblue; 17th Feb 2021 at 4:57 pm. Reason: test worked |
17th Feb 2021, 5:05 pm | #6 |
Let's see... seems OK for me too.
17th Feb 2021, 5:10 pm | #7 |
Just to ensure that it's not just moderators for whom it works:
17th Feb 2021, 5:11 pm | #8 |
Thats really odd, I just tried using Chrome instead of Firefox and got the same error.
Just in case its something peculiar about the pictures I will try and attach a file to this message. Peter Edit, well that worked, I will try resizing the pictures I am trying to upload. Thanks for the help. Peter |
17th Feb 2021, 5:16 pm | #9 |
That thought had just occurred to me too. It is worth checking the size of the images you're trying to upload, as it may be that the resizing procedure simply gives up if it's too big.
17th Feb 2021, 5:22 pm | #10 |
OK, its file size. I used to always resize before uploading but have got lazy recently as the system was so successful at re-sizing.
I have just resized the pictures and uploaded them in my offered post. Thanks again for the help. Peter |
17th Feb 2021, 5:30 pm | #11 |
There may be a problem if the images are really huge - something may time out while they're uploading.
17th Feb 2021, 5:35 pm | #12 |
Administrator
If it is a vary big file it could time out if your connection isn't that fast or the server is busy.
The forum software does a reasonably good job of resizing most of the time, but with mobile phones having ever higher resolution cameras and producing ever bigger images we will probably have more issues like this. I normally resize to within the limits first, which also allows me to crop closer to the item of interest, rotate if necessary and do any level tweaks first. Remember there is a higher file size limit for ZIP files so if you need to add photos over the forum size limit for clarity or detail then put them in a ZIP file and upload that instead. No processing needed by the forum software for those. |
17th Feb 2021, 6:01 pm | #13 |
The original pictures were all just under 3 Meg, I tried to upload 4 of them.
Lesson learnt, I will resize in future. Peter |
17th Feb 2021, 6:13 pm | #14 |
The easiest solution is to change your camera resolution if you know you're taking pictures to upload to the net.
17th Feb 2021, 6:30 pm | #15 |
I use Image Resizer but I understand that this is now available from the Microsoft app store as a "PowerToy"
https://www.microsoft.com/en-us/p/re...ot:overviewtab Peter |
18th Feb 2021, 10:59 am | #16 |
Administrator
Hard limits set in the configuration here for image uploads are:
Maximum size = 5000 x 5000 pixels. Anything over won't be resized or accepted. Maximum upload size = 64MB. If uploading several images simultaneously that is the total not per image. If exceeded you will get a server error message. |
