Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 17th Feb 2021, 2:31 pm   #1
Electronpusher0
Default Unable to upload pictures
I am trying to post some radios for sale and keep getting errors when trying to upload the pictures. I get service unavailable due to maintenance or capacity problems.
is there a problem with the forum server?
Peter
Electronpusher0 is offline
Old 17th Feb 2021, 3:11 pm   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: Unable to upload pictures
Not aware there is but have not tried to upload today, although I need to.
HamishBoxer is offline
Old 17th Feb 2021, 3:27 pm   #3
paulsherwin
paulsherwin's Avatar
You will occasionally see this message if the server is unusually busy. It should be OK if you wait a couple of minutes and try again. Often the server is only overcapacity for a second or two.
paulsherwin is offline
Old 17th Feb 2021, 4:43 pm   #4
Electronpusher0
I have just tried again. It sits there for ages saying uploading then gives the following message:
"Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Additionally, a 503 Service Unavailable error was encountered while trying to use an ErrorDocument to handle the request."
Peter
Old 17th Feb 2021, 4:56 pm   #5
Cobaltblue
Cobaltblue's Avatar
Just a quick try
Seems to work OK for me
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 17th Feb 2021, 5:05 pm   #6
paulsherwin
Let's see... seems OK for me too.
Old 17th Feb 2021, 5:10 pm   #7
Dave Moll
Dave Moll's Avatar
Just to ensure that it's not just moderators for whom it works:
Dave Moll is offline
Old 17th Feb 2021, 5:11 pm   #8
Electronpusher0
Thats really odd, I just tried using Chrome instead of Firefox and got the same error.
Just in case its something peculiar about the pictures I will try and attach a file to this message.
Peter
Edit, well that worked, I will try resizing the pictures I am trying to upload.
Thanks for the help.
Peter
Old 17th Feb 2021, 5:16 pm   #9
Dave Moll
Dave Moll's Avatar
That thought had just occurred to me too. It is worth checking the size of the images you're trying to upload, as it may be that the resizing procedure simply gives up if it's too big.
Old 17th Feb 2021, 5:22 pm   #10
Electronpusher0
OK, its file size. I used to always resize before uploading but have got lazy recently as the system was so successful at re-sizing.
I have just resized the pictures and uploaded them in my offered post.
Thanks again for the help.
Peter
Old 17th Feb 2021, 5:30 pm   #11
paulsherwin
There may be a problem if the images are really huge - something may time out while they're uploading.
Old 17th Feb 2021, 5:35 pm   #12
Paul Stenning
Administrator
Paul Stenning's Avatar
If it is a vary big file it could time out if your connection isn't that fast or the server is busy.
The forum software does a reasonably good job of resizing most of the time, but with mobile phones having ever higher resolution cameras and producing ever bigger images we will probably have more issues like this.
I normally resize to within the limits first, which also allows me to crop closer to the item of interest, rotate if necessary and do any level tweaks first.
Remember there is a higher file size limit for ZIP files so if you need to add photos over the forum size limit for clarity or detail then put them in a ZIP file and upload that instead. No processing needed by the forum software for those.
Paul Stenning
Paul Stenning is offline
Old 17th Feb 2021, 6:01 pm   #13
Electronpusher0
The original pictures were all just under 3 Meg, I tried to upload 4 of them.
Lesson learnt, I will resize in future.
Peter
Old 17th Feb 2021, 6:13 pm   #14
paulsherwin
The easiest solution is to change your camera resolution if you know you're taking pictures to upload to the net.
Old 17th Feb 2021, 6:30 pm   #15
Electronpusher0
I use Image Resizer but I understand that this is now available from the Microsoft app store as a "PowerToy"
https://www.microsoft.com/en-us/p/re...ot:overviewtab
Peter
Name:	Image Resizer screenshot.jpg
Old 18th Feb 2021, 10:59 am   #16
Paul Stenning
Administrator
Hard limits set in the configuration here for image uploads are:
Maximum size = 5000 x 5000 pixels. Anything over won't be resized or accepted.
Maximum upload size = 64MB. If uploading several images simultaneously that is the total not per image. If exceeded you will get a server error message.
Paul Stenning
