5th Feb 2021, 5:11 pm | #61 |
Re: Thoughts on Heathkit Equipment?
Getting back to Heathkit, there are 2 specific dislikes I have :
Firstly their 'scopes, at least the ones I've seen, had AC coupled Y amplifiers. They do not go down to DC. That makes them useless for a lot of work I do. To be fair a lot of the 'amateur' scopes of the time were similar, but... Secondly the units are hard to service once assembled. PCBs are hard-wired in place with other things mounted around them. Often you essentially have to reverse the assembly instructions, desoldering wires as you go to get to parts. |
6th Feb 2021, 2:04 pm | #62 |
Hi!
One of the most challenging Heathkit Projects from my Heathkit Collection is the HFW–1 Sweep RF Generator that will need a total rebuild from scratch due to many assembly mistakes – I'm hoping the original "builder" hasn't wrecked the special controlled inductor ("Incrediuctor!" the advertising blurb called it!) otherwise that'll mean a friendly chat with Ed! – full of brown Hunts "Mouldseals" underneath and every one will have to be thrown out! Thankfully I managed to find a pdf of the original assembly manual complete! Incidentally, to anyone restoring chassis–built equipment, it's well worth buying a roll of 1 mm ptfe sleeving for component lead out wires – it doesn't melt off the lead when you solder the tags the components connect to! Braided or varnished cotton sleeving was very useful as well as this also doesn't peel off a hot component lead during soldering operations but I'm not sure whether you can still buy it these days! Chris Williams
6th Feb 2021, 4:22 pm | #63 |
Oh I like this thread. I am drawn to Heathkit stuff like a lunatic and have owned probably 30 items over the years. Unfortunately nearly all of the stuff I’ve had is poorly constructed or knackered by the end user. The joy of it is that it’s fairly well documented, mostly easy to decipher if it isn’t and most of the parts aren’t too difficult to locate. So it usually survives. As for performance it’s usually exactly the correct compromise between professional kit and being cheap.
But some real criminals are out there on the construction side of things. The worst being the Heathkit factory builds which were mostly terrible! Typical example of how you can un-knacker stuff creatively here: https://www.vintage-radio.net/forum/...d.php?t=136242 Can’t believe that was nearly 4 years ago now |
6th Feb 2021, 6:15 pm | #64 | |
I picked on up at a ham radio swap meet several years later. Mine is equipped with the optional AC adaptor. The build quality is really good. After looking it over, I thought it was not really worth getting excited about. I still like valve based equipment better. Another Dave or David, as you please, USradcoll1 |
10th Feb 2021, 4:40 pm | #65 |
David[/QUOTE]
It seemed like a lot of us lusted after a Mohican when we were just starting this radio hobby and yes, it was beyond our reach as well. I picked on up at a ham radio swap meet several years later. Mine is equipped with the optional AC adaptor. The build quality is really good. After looking it over, I thought it was not really worth getting excited about. I still like valve based equipment better. Another Dave or David, as you please, USradcoll1 [/QUOTE] I acquired one of these recently with the mains option - I recapped the audio and power sections with new electrolytics (although I missed one hiding behind something) but left the rest alone, apart from a squirt of contact cleaner in various places/switches. With a 10 foot length of wire it was OK but not startling. |
10th Feb 2021, 4:51 pm | #66 |
I know (worth more as the unbuilt kit) but just cannot help myself. In the interim I have their built up VTM (7-U??) which is driving me bonkers with a fault (will not balance) despite just about rebuilding the whole darned thing/replacing valves etc etc. To add insult to injury all the meter readings (on valve pins etc) are in the correct range.
10th Feb 2021, 5:10 pm | #67 | |
I feel though that stripping something down and finding it's unrepairable is more emotionally satisfying than simply going out to replace it. Of course one would like it to be fixable cheaply but not everything turns out that way - however if nothing else you have learnt how that particular item comes apart for the next or similar item. And if things have been damaged in the dissembly (always that one screw hiding somewhere or clip that snaps off ) but it's unrepairable anyway then it does not feel quite so bad. Anyway many thanks to david for posting his material on the RF sig gen - think it will be a great help for one I've got somewhere. if only I can locate it |
10th Feb 2021, 7:28 pm | #68 |
Avocollector
It is just possible that your V7A-U that won't balance needs to be put in an airing cupboard to dry out the paxolin circuit board. My one improved after drying it out. Ron |
12th Feb 2021, 3:24 pm | #69 |
That's a great suggestion - many thanks for it. Getting to the stage where a total rebuild was looking like the only solution.
14th Feb 2021, 11:49 am | #70 |
I had a problem many moons ago with achieving a balance on a V7A. The balance varied significantly across several samples of 12AU7 valves I had available, some were more unbalanced than others.
The fix was to tweak the values of the cathode resistors of the 12AU7. Note that on the V7A, the balance control allows zero setting to be either in the normal place on the left hand end of the scale, or centre scale (useful on equipment with both positive and negative rails), so left hand zero does not occur with the control at mid position. Stuart |
14th Feb 2021, 7:26 pm | #71 | |
I still have the Allied Knight-kit VTVM I built in 1962 and it still works perfect! I haven't used it in ages since digital meters became popular! Dave, USradcoll1. That's my story and I'm sticking with it! |
23rd Feb 2021, 1:21 pm | #72 |
There is a two-page retrospective review article on the Heathkit IB-101 frequency counter in the latest QST issue, March 2021. It's a reprint from May '71.
15th Mar 2021, 9:09 pm | #73 |
Hi Folks, just to add my thoughts on Heathkit.
I had an output transformer for an MA12 amp to rewind. It used a pair of EL84's in UL mode on a 1 3/3" stack of No29 lams, Unisil material. It was a good design and well made; interleaved pri and sec and the lam stack for output watts was generous. Hopefully when repaired it should sound very good. It looked like a well made product Ed |
16th Mar 2021, 10:12 am | #74 |
The 'kit' bit of the name tends to make people look down on their equipment, but they understood their target markets.
The UK Hi-Fi equipment was designed when George Tillet was chief engineer and a lot of it diverges significantly from the US parent. He was heavily involved in the 50s British Hi-Fi scene and presumably wanted something good enough to compete with Leak etc. More here: https://www.gammaelectronics.xyz/aud...1983_coda.html I do have to say though that the USP-1 pre-pre-amp is a slightly odd beast. |
