23rd Sep 2018, 9:11 am | #1 |
"How many valves does a man need?"
"How many valves does a man need"?
I was asked this in a quizzical way by my daughter when she was trying to help me organise my house. I thought about how to answer that to a non electronically minded person but in the end kept quiet and said nothing. Pete |
23rd Sep 2018, 9:34 am | #2 |
Re: "How many valves does a man need?"
Ask her how many handbags or shoes she needs. Then explain that some radios have dozens of valves. Your need is for lots of valves to cover all possibilities. Valves tend to increase in value as well tell her.
Rob
23rd Sep 2018, 10:22 am | #3 |
No win situation, keeping quiet was the wisest option.
Frank |
23rd Sep 2018, 10:35 am | #4 |
I often wonder that as well.....looking at my modest stock and wondering how many I'm actually going to use.....
23rd Sep 2018, 12:11 pm | #5 |
23rd Sep 2018, 12:35 pm | #6 |
No Marc, we are NOT counting sphincters!
But I did spot two chaps at Golborne taking turns to be photographed cradling a large transmitting valve like a newborn baby!
Regards, Ken. BVWS member |
23rd Sep 2018, 12:40 pm | #7 |
I’m the same with transistors. Large order of about 2000 of them turned up the other day and my wife said “you’re too old to use all them up”.
Challenge accepted! |
23rd Sep 2018, 12:43 pm | #8 |
Usually, each time the need for one arises, one more than he has...
Paul |
23rd Sep 2018, 1:38 pm | #9 |
Wallis Simpson once said " You can never have too much money; be too thin, or have too many vacuum tubes"
23rd Sep 2018, 2:09 pm | #10 |
You need none, the right one is handy for a job, may as well have a few (hundred) just in case. I took an old PLxxx to work and took it apart to show the chaps at work how they did it. All where entertained and educated, many questions followed. I now have a hole in my stock, do I need another?
23rd Sep 2018, 2:15 pm | #11 |
The quick answer is 340.
This is based on the number of regular valve stock lines I found I needed to maintain as a radio and tv restorer (170) multiplied by a stock of two for each. Actually, the numbers of the above I had were often larger, and I had loads of other valves I would never need. Nothing unusual there! Steve |
23rd Sep 2018, 2:45 pm | #12 |
Some people just don't get the worry created by the following (is this because it rarely affects them?)
....Unobtainable/Unobtainium Discontinued Obsolete Superceded Banned 'If you want to sell it it's worth nothing, if you want to buy one the sky's the limit' House Clearance.... A- 'So, have you got all the spares that you need off the donor, then? Can we scrap it?' B- 'I don't know WHICH spares i need until something breaks- so without a crystal ball i can't tell' Three weeks later A- So, have you got all the spares you need off the donor then? Can we scrap it...? |
23rd Sep 2018, 3:16 pm | #13 |
Banned? Is there a story Mr P?
23rd Sep 2018, 4:00 pm | #14 |
23rd Sep 2018, 5:16 pm | #15 |
Heh! No chaps, i was referring more to legislative bans than domestic. 8' tubes, Halogen lamps, etc!
23rd Sep 2018, 8:38 pm | #16 |
The question was about valves (electronic ones) not lamps.
23rd Sep 2018, 8:46 pm | #17 |
I don't need valves, seems they find and need me
Cheers Mike T
23rd Sep 2018, 9:54 pm | #18 |
Transistors build up much faster than valves because they are smaller.
23rd Sep 2018, 10:25 pm | #19 |
Bipoler?
Wouldn't mind a sample of one of those
23rd Sep 2018, 10:58 pm | #20 |
Surely the answer is "n +1", where 'n' is the number i have now.
