30th Mar 2015, 10:47 am | #101 |
Administrator
Re: Obsolete Technologies that baffle the modern generation.
Another reminder after more posts deleted or edited...
30th Mar 2015, 11:23 am | #102 |
An ancient Meccano Magazine that I read as a child had plans to make a similar setup using the earpieces from old telephones. Unfortunately I never obtained the required parts as we only had the one phone and it was rented from BT anyway!
30th Mar 2015, 11:34 am | #103 |
Perhaps the very concept that you could make anything for yourself is alien to the current generation of kids?
I remember having a 'Hobbies' catalogue with an article on building your own radio (1.4v and 90v valves) It involved cutting materials and soldering, so it wasn't just an assemble-a-kit task. I can't help but think that the majority of people are being brought up to be helpless. David
30th Mar 2015, 12:18 pm | #104 |
In an era of electronic pre-set tuning, digital multiplexes and SDR, even a gang capacitor and reduction drive has an air of, "Eh? What's that about?" to it.
Trying to learn soldering with lead-free solder won't be encouraging too many, either. |
30th Mar 2015, 12:44 pm | #105 |
But you can still buy the old stuff and use it on "Vintage" equipment, as far as I understand? You can use it on non-potable plumbing too, unless they have changed the regs recently.
30th Mar 2015, 12:55 pm | #106 |
How about tinned food with a key that you have to turn to open it? I don't remember seeing those recently. They all seem to be ring pulls.
30th Mar 2015, 1:15 pm | #107 |
Spam certainly comes in tins which open with a key, as do some tinned sardines.
Kettles which have to be boiled on a stove baffle some people. During power cuts it never occurs to some people that they can boil water in a saucepan for a cup of tea or coffee.
30th Mar 2015, 1:30 pm | #108 |
Still a problem to some folk who have mains powered ignition on their gas hob.
30th Mar 2015, 1:34 pm | #109 | |
And of course someone's bound to put a plastic kettle on the gas-ring. |
30th Mar 2015, 1:45 pm | #110 |
Of the two gas stoves I use regularly, one uses a D cell for the ignitor and the other an external 12V supply. Both can be lit with a match.
Heating would present a problem in the event of a power cut, so I'd have to light the open fire.
30th Mar 2015, 1:56 pm | #111 | |
Not as easy as pushing a button on a gas fire! So we can add lighting a solid fuel heater to the list. Mark |
30th Mar 2015, 2:02 pm | #112 |
Corned beef still comes in the key type can, as does Spam.
Andy G1HBE. |
30th Mar 2015, 2:06 pm | #113 |
When I cleaned out my late dad's shed, there was his emergency cooker- an old gas bottle with a burner attached. I remembered it as a lad being used for a brew in his old shop, some 30 years ago. lit by a match ,what else.
I've always thought the ignitors on gas stuff a bit dodgy. Wife cleans our hob, and then there's a constant wail of "it won't light" . But cooking wise, we're dual ,as we still remember the days of power cuts. I haven't seen party lines mentioned yet- and the phantom ringing or occasional bell tinkle, caused by poor mains equipment earth's. |
30th Mar 2015, 2:08 pm | #114 |
Last time I used the 'key' type Spam can I got the short end off the can just fine but the plug of Spam was still stuck fast in the long piece of the can due to fat forming a seal.
quick fix: use a conventional can-opener to cut the blind end of the can off then push the plug of Spam out. |
30th Mar 2015, 2:11 pm | #115 | |
I remember my first away from home place, I bought a nice new camping kettle, took ages to boil on the electric (yes, singular, you could do toast underneath too) ring, the bottom was all shiny new aluminium, a quick blackening using a candle did the trick. Candles, the posh scented kind, I wonder how many have been bought without the thought of how to light it. |
30th Mar 2015, 2:17 pm | #116 |
30th Mar 2015, 2:22 pm | #117 |
I wonder if perhaps Spam could in itself be considered obsolete technology, along with Dried Egg, Fish Paste, and Condensed Milk.
30th Mar 2015, 2:30 pm | #118 |
30th Mar 2015, 3:50 pm | #119 |
A few weeks ago I visited someone who was complaining that the toaster had failed so they couldn't have breakfast
I asked why they hadn't cooked it under the grill, only to get bemused stares. Last Friday I had a phone call from someone who had aquired an old radio. Their complaint was that it wouldnt receive all the stations shown on the dial. (I refrained from suggestion they buy a time machine!) As for the list in Post 97, I have the majority of those items. |
30th Mar 2015, 6:19 pm | #120 |
Could I add to the 'baffling' list [even though they're not electrical/electronic].
Carbon-paper [and the frustration it caused when you were using it in a typewriter and made a mistake] Spirit-duplicators - the Roneo/Banda things where you typed your script on waxed coarse paper/cloth, saturated the resulting master with a sort-of violet-coloured ink, then printed off 20 or 30 progressively-less-clear copies before needing to stop, take the master off the drum, re-ink and get another 20 or 30 copies. if you got more than 4 or 5 'reloads' out of the master before the wax-coating started to flake you were lucky. Music-ruled, tractor-feed fanfold paper: In times past I sweated for hours over program-listings and dumps [FORTRAN-60, JOVIAL and Honeywell GMAP assembler if you must know] printed on this. |
