Old 28th Nov 2020, 9:56 am   #1
GaryBrigden
Default Sharp PC-1500 not working
Hello,
I have acquired a Sharp pocket Computer 1500, with 4 colour plotter.
When pressing the ON button, the LCD flashes and then fades to nothing, and the keyboard is unresponsive.
If I press the reset, the LCD flashes again, then fades and as I release the reset, the same behaviour.
Has anyone had experience with these little devices and might recognise this?
I suspect something has blown, but where to start?
Many thanks
GaryBrigden is offline
Old 28th Nov 2020, 5:50 pm   #2
Slothie
Default Re: Sharp PC-1500 not working
I've no specific knowledge of these, but I have repaired a few old calculators. I would start off carefully dismantling it (there's probably a youtube video - look for Tandy PC-2 as well which is rebadged model) cleaning it out and look for signs of corrosion - only a tiny bit can cause shorts. There's also a couple of electrolytic caps from what I can see in photos which could cause problems in the usual manner. The ICs in calculators from this period seem to be pretty reliable, so I would look at the other components.
Its also possible the crystal is damaged, with no clock nothing will work and they are susceptible to damage.
Slothie is offline
Old 28th Nov 2020, 6:08 pm   #3
TonyDuell
As Slothie said, the Tandy/ Radio Shack PC2 is a close clone but with a diffferent keyboard layout. The circuitry is much the same and the service manual for that is on the web.
I have the offiical Sharp technical reference manual on my bookshelf but that's more about machine code programming and interfacing than repairing the machine. I will look to see if there's anything of interest though.
The 2 large ICs on the lower PCB are the processor (LH5801) and I/O (LH5810 or LH5811). Also in there are RAM (if this is a plain PC1500, it's CMOS 2114-a-like things I think), a system ROM, etc.
I have had the I/O controllers fail, but the machine would normally still power up. Just an electrical row or column of the keyboard would be dead.
TonyDuell is offline
Old 29th Nov 2020, 12:00 am   #4
GaryBrigden
Thank you for your replies.
I have ventured to taken the unit apart, and all looks fine with the soldering and surprisingly looking in good health generally.
I suspect the power regulator to be the issue. In this unit it is a 14pin resin based chip that controls a host of things around power.
I am looking for the part online but think it is a Sharp component and not readily available so may have to butcher another 1500 for one.
Thanks
