Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 27th Nov 2020, 12:01 pm   #1
McMurdo
McMurdo's Avatar
Default Forum time?
Don't know if its me or the forum but posts are appearing with the time of post marked at an hour ahead of the actual time.
Kevin
McMurdo is offline
Old 27th Nov 2020, 12:04 pm   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: forum time?
Unless you made this post at 10:01 its showing correctly for me at 11:01
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 27th Nov 2020, 12:09 pm   #3
Dave Moll
Dave Moll's Avatar
It's probably worth checking in your profile what time zone you have set. If you're set to Central European Time (or whatever it's called) you will be one hour ahead.
Dave Moll is offline
Old 27th Nov 2020, 2:05 pm   #4
paulsherwin
paulsherwin's Avatar
Default Re: Forum time?
The forum operates internally on GMT and adjusts what you see according to your local time zone as stated in your profile.
paulsherwin is offline
Old 28th Nov 2020, 12:44 pm   #5
Paul Stenning
Administrator
Paul Stenning's Avatar
User CP - Edit Options.
Scroll down to the date and time part, make sure it is set to GMT and to detect DST.
Paul Stenning
Forum Admin/Owner and BVWS Webmaster
Paul Stenning is offline
Old 28th Nov 2020, 12:54 pm   #6
Radio_Dave
Radio_Dave's Avatar
It does it to me if I'm logged out for some reason?
Regards
Radio_Dave is offline
Old 29th Nov 2020, 10:01 am   #7
Paul Stenning
Administrator
If you are logged out it follows the software default. That was GMT+1 but I have changed it to GMT, which will be wrong in the summer but at least makes sense.
Paul Stenning
Old 29th Nov 2020, 3:33 pm   #8
Jon_G4MDC
Jon_G4MDC's Avatar
This was bothering me recently until I discovered that the device I was using was not actually logged in as me. It corrected itself after I logged in.
I was going to post about it but discovered just in time that it was a self inflicted problem. That won't be true in every case but at least be warned - it happens as mentioned in Post #6 above.
Jon_G4MDC is offline
Old 29th Nov 2020, 3:42 pm   #9
paulsherwin
You could write a little script to set GMT/BST as appropriate, but it's probably not worth bothering about.
Old 29th Nov 2020, 5:37 pm   #10
Dave Moll
Dave Moll's Avatar
At least if the default is GMT, that is equivalent to Universal Time (UT), which is an international standard used in some circumstances (where time zones are inappropriate).
Old 29th Nov 2020, 11:29 pm   #11
Paul Stenning
Administrator
The BST option for non-logged-in users is supposed to do that but it doesn't work for some reason. It does work correctly when logged in though, which is more important.
Paul Stenning
