Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 20th Nov 2020, 9:46 pm   #41
ms660
ms660's Avatar
Default Re: Adding Greek letters to posts.
Cheer's Graham, it's a mystery to me too, because entering the three number code for µ (Alt + 230) returns just that.....µ.....
Lawrence.
ms660 is offline
Old 20th Nov 2020, 10:03 pm   #42
Station X
Station X's Avatar
The behaviour of the numeric keypad depends on your keyboard and language options.
Mine are set to English (United Kingdom) United Kingdom Keyboard. If I select an American keyboard layout ALT + 227 stops working.
Graham. Forum Moderator
Station X is offline
Old 20th Nov 2020, 10:11 pm   #43
ms660
ms660's Avatar
Graham, mine is set the same as yours is "English (United Kingdom) United Kingdom keyboard"
All a bit strange.
Lawrence.
ms660 is offline
Old 20th Nov 2020, 10:31 pm   #44
Uncle Bulgaria
Uncle Bulgaria's Avatar
Goodness - a glass of wine later and this has grown to three pages!
Yes, it's a minefield. For me Ò is Alt+227. You can sometimes get different things for left and right Alt keys.
You have to check on your own character map. For me, (UK English, UK keyboard) there is no Alt code for Pi, so I discovered the method for making the hex code work. See attached snip. I have to look in the 'Unicode' section of the Character Map to find Pi, while Mu is also available in the much more limited 'DOS Western Europe' section (second snip - note Alt code bottom right, Hex bottom left). There is no Pi available in my DOS Western Europe list, so I have to use the Unicode hex.
ID:	220846   Click image for larger version
Uncle Bulgaria is offline
Old 20th Nov 2020, 11:07 pm   #45
Dave Moll
Dave Moll's Avatar
Originally Posted by Station X View Post
Originally Posted by ms660 View Post
Ok, pressed that Num key then did Alt + 227 it didn't shoot to Google and this is the symbol that appeared in this post....Ò....:
Lawrence.
How strange. I have to type Alt 0210 to get a Ò
Yes, those both give the same character.
Last edited by Dave Moll; 20th Nov 2020 at 11:13 pm. Reason: quote added for clarity
Dave Moll is offline
Old 20th Nov 2020, 11:12 pm   #46
emeritus
This issue was raised in a thread a few years ago. In XP the issue was what character set had been selected in one of the settings menus. With the US set, ALT + 227 gave Pi, whereas with the default character set as Multilingual (Latin 1), it gave Ò. I don't have a Windows 10 system so don't know what or where the corresponding menus/settings are.
emeritus is offline
Old 20th Nov 2020, 11:31 pm   #47
Tim
Tim's Avatar
Could we have a few of the common characters added to the Emojis on "go advanced"?
Tim is offline
Old 21st Nov 2020, 2:09 am   #48
emeritus
This was the old thread:
https://www.vintage-radio.net/forum/...d.php?t=108843
My experience with XP is at #11
emeritus is offline
Old 21st Nov 2020, 10:57 am   #49
ms660
ms660's Avatar
So how do I get Pi using Alt + a number code....Anyone?
Lawrence.
ms660 is offline
Old 21st Nov 2020, 11:19 am   #50
Dave Moll
Dave Moll's Avatar
As I implied earlier, I don't think you can with the standard UK English character set. It's only available as a Unicode.
Old 21st Nov 2020, 11:25 am   #51
Station X
Station X's Avatar
For NUM LOC then ALT + 227 to work all language and keyboard settings must be set to UK English.
Start
Settings
Time & Language
Language
Windows display language
ID:	220856   Click image for larger version
Old 21st Nov 2020, 11:41 am   #52
ms660
ms660's Avatar
Start
Settings
Time & Language
Language
As I said earlier they are and here's the result of Alt+227 using the numeric keypad "Ò" it's not the Pi symbol.
Lawrence.
ms660 is offline
Old 21st Nov 2020, 11:43 am   #53
Station X
Station X's Avatar
Sorry Lawrence, but I cannot assist you further. Those are my W10 settings on three machines and they work.
Perhaps someone else can help.
Old 21st Nov 2020, 11:47 am   #54
ms660
ms660's Avatar
So you are saying that Alt+227 on your computer returns a Pi symbol?
Lawrence.
ms660 is offline
Old 21st Nov 2020, 11:48 am   #55
Station X
Station X's Avatar
Yes. So long as Num Lock is on and I use the numeric keypad.
π π π
Old 21st Nov 2020, 12:07 pm   #56
Station X
Station X's Avatar
I can reproduce your problem Lawrence.
Start
Settings
Time and Language
Language
Scroll down the window
Administrative Language settings
Change system locale...
Must be set to English (United States) from the drop down list.
Old 21st Nov 2020, 12:07 pm   #57
ms660
ms660's Avatar
Thanks Graham.
It's strange.
I can do Alt+230 from a code list that was posted earlier and get the expected µ but no expected Pi symbol when doing Alt+227.
My language/keyboard settings enclosed.
Lawrence.
ID:	220866   Click image for larger version
ms660 is offline
Old 21st Nov 2020, 12:12 pm   #58
Station X
Station X's Avatar
Follow the procedure in post #56 and check your system locale... I've added a picture to that post.
Old 21st Nov 2020, 12:35 pm   #59
ms660
ms660's Avatar
......π π π
Cheers for that Graham.
Lawrence.
ms660 is offline
Old 21st Nov 2020, 1:11 pm   #60
Station X
Station X's Avatar
I guess the factory settings depend on where the PC was sourced from. I've checked two Dells and an HP, all bought in the UK and they're set like that.
