21st Nov 2020, 4:45 pm | #21 |
Re: SMD soldering
Hi Steve, Good luck with your soldering, everyone has their own method. I find using the tined flux (from Ebay £2.09 in Grey / red tin) is easiest. Using a piece of wire, cocktail stick or similar apply flux to pad then use same wire to pick up component (sticky) and place in position. I did try with tweezers only for the component to escape, never to be seen again.
John.
My favourite text message "I'll be there in five minutes, if not read again" |
21st Nov 2020, 4:54 pm | #22 |
Re: SMD soldering
Something also worth noting is that SMD ceramic caps can go short-circuit due to thermal stress. Annoyingly, this can happen a while down the line (typically when the unit is in service...). If you are soldering them, do everything you can to minimise heat stress - short circuited caps can do a lot of damage!
21st Nov 2020, 5:03 pm | #23 | |
Re: SMD soldering
John.
21st Nov 2020, 9:57 pm | #24 | ||
Re: SMD soldering
I can't say 100% that the shorts weren't stress related. However, I find this implausible, considering how much abuse SMD caps get in modern gear such as phones and the like. Nor do I see how they'd get the physical abuse when soldered. My feeling is that they like a short, sharp soldering cycle - and beyond that can brew up trouble down the road. |
21st Nov 2020, 10:11 pm | #25 |
Re: SMD soldering
SMD seems an incredible tech advance to me. I am practicing my skills and enjoying the journey. When I consider the reductions in scale of passives as well as switches (esp power MOSFETs) I wonder what the future will look like.
I also note that this down-scaling of size vastly reduces stray inductance particularly and associated problems with circuits operating at colossal switching speeds. I am curious to know from the experts how mass-production works, including the avoidance of thermal stress during soldering.
Al |
21st Nov 2020, 10:21 pm | #26 |
Re: SMD soldering
They use little machines
This is most of one board assembly line. You might want to watch this (music a bit poor though) https://www.youtube.com/watch?v=t9Se56mFDFA Cheers Mike T
Invisible airwaves crackle with life or at least they used to Mike T BVWS member. www.cossor.co.uk Last edited by Cobaltblue; 21st Nov 2020 at 10:24 pm. Reason: added link |
21st Nov 2020, 10:35 pm | #27 |
Re: SMD soldering
Wow!
J
21st Nov 2020, 10:40 pm | #28 |
Re: SMD soldering
whaaaat, Mike? Did I see 39,000 components per hour? I don’t have any German so I can’t understand the text but I see the incredible reality of these robots doing their thing. What’s the soldering time ? It seems blisteringly fast.
I wonder what the inventor of the first monolithic audio amplifier (I only saw the ad. the other day for he first time in a vintage magazine ) and prolific circuit designer / publisher of the 1960’s to 70’s, Clive Sinclair, makes of all this? Wow.
Al |
21st Nov 2020, 10:53 pm | #29 |
Re: SMD soldering
Due to Covid I don't go over the factory as often as I used to but these machines are something else.
I was trying to find the video of the flow soldering part. The first picture is actually part of the Siemens factory in Poole from the Mobility twitter feed. I just noticed there is an English version of the placement machines. https://www.youtube.com/watch?v=T_NQC5cmRRM Cheers Mike T
21st Nov 2020, 11:00 pm | #30 |
Re: SMD soldering
Thanks for that version, Mike. I find this mind-blowing.
I have used an online service to make a board for me from a file I supplied but I had no idea of the reality. The scale of the robotics seems remarkable, just a few humans in the frame as millions of components an hour get picked and placed. How did this all get designed?
Al |
22nd Nov 2020, 12:10 am | #31 |
Re: SMD soldering
The limitation is the number of different part values each station can have threaded up at one time.
Designers have to limit the number of different resistor and capacitor values they use on a board. This can look wierd to people looking at diagrams downstream. David
22nd Nov 2020, 11:42 am | #32 |
Re: SMD soldering
Regarding the capacitors, it's a know issue and is known as capacitor cracking. Often caused by localised phsical stress on the component when the PCB is snapped out of it's panel or some other assembly process. In the case of this thread, it could be either thermal shock, mechanical handling, or uneven heating causing mechanical stress.
One customer we supplied insists that strain guages are put on a board in a panel after surface mount, and then run through the rest of the process to check a limit wasn't exceeded. They also have rules about having two MLCCs in series but mounted at right angles (so the chance of cracking both is minimised). The issue occurs after a while, because it's caused by electromigration of the metal through the cracks in the ceramic, driven by the voltage applied. So it only really starts once the device is in service. It depends where in the circuit the cap in question lives and if it's one the main power in then you can have serious issues. And I have seen it happen where an MLCC has gone short after initially testing good. The process had been strain gauged and passed. But without telling me the factory changed the process. Then they had loads of parts that had passed EoL but then failed while being reworked with new Firmware. Luckily that cap was on the output side of the Vreg so the current was limited, and just resulted in lots of dead parts. I'm glad that got caught before we shipped the first batch to the customer. |
22nd Nov 2020, 11:51 am | #33 |
Re: SMD soldering
One evil trick:
Turn a post-it note upside down on the bench. You can put SMT components down on its sticky strip and they won't blow around. You can write values etc on the non sticky part with an arrow pointing at teh component. David
22nd Nov 2020, 12:07 pm | #34 |
Re: SMD soldering
Great idea, David. I’ll give that a try!
Al |
22nd Nov 2020, 1:18 pm | #35 | |
Re: SMD soldering
I did have a few ping out of the tweezers. Couldn't tell them from the dirt once they had done that. I think I lost more than I soldered, probably by 2:1. |
22nd Nov 2020, 1:25 pm | #36 |
Re: SMD soldering
Might i make one more useful suggestion to add to your toolkit, I've always found a small brass wire brush very useful to clean the iron tip, something like an old hush puppies brush.
Greg.
Picture, sound?, DOOR. |
22nd Nov 2020, 1:59 pm | #37 |
Re: SMD soldering
Resistors, useless put in upside down as you can't read the value, place on a bit of paper and a quick tap will flip them over randomly some will be the right way up. Also as most SM stuff is so cheap if you lose track of a component value/type, bin it and get a new one.
23rd Nov 2020, 2:01 am | #38 |
Re: SMD soldering
Industrial tiddlywinks.
I sometimes surround my microscope area with clean, plain coloured card. Any pinged components show up well. Bench surfaces inevitably get marked and graunched-up like a mini battlefield. Even 0603 can hide quite well. Metcal iron stands come with a scrunched-up brass pan-scourer shoved in a little pigeon hole for cleaning bits. Seems to work, and is supposed to avoid the thermal shock of a wet sponge on a very expensive bit. One of the American QRPers had a cannery as a family business. He brought out a range of QRP kits in cans. Pull the tab, open the can and take out the components, then build the set using the can as the cabinet. The one I bought is the canned pan-scourer for cleaning soldering irons. He even sold canned underwear in case you got a nasty shock. RS did a little tin of bit cleaner compound, seemingly a hard piece of solder paste/flux block. Worked brilliantly, but lead based so presumably the people responsible have been taken out and shot by the ROHS people. David
23rd Nov 2020, 11:33 am | #39 | |
Re: SMD soldering
https://uk.rs-online.com/web/p/solde...ories/8183207/ |
23rd Nov 2020, 10:00 pm | #40 |
Re: SMD soldering
Dont know if anyone noticed but I realised at some time in its life the magnifier has been disassembled and the head put back on upside down. Ive sorted it out. im struggling on the smallest parts in not getting too much solder on. May get a tub of solder paste and try it.
