Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval. |
1st Nov 2020, 10:57 pm | #1 |
Symbols in Subscribed Threads
On the LH side are two columns, one for the status of the thread and there is a code for the icons. The other column is mostly a page-of-text icon, but occasionally can be a yellow smiley or a question mark in a blue circle.
What do these mean?
- Julian It's good here |
1st Nov 2020, 11:01 pm | #2 |
Re: Symbols in Subscribed Threads
Underneath your Message there are Post Icons
If you wish you can select one to show how your feeling about the post or thread. Normally No Icon is shown unless you select one Cheers Mike T
1st Nov 2020, 11:02 pm | #3 |
Is that the one you mean?
2nd Nov 2020, 12:47 am | #4 |
Thanks, but I can't edit any icons
2nd Nov 2020, 1:06 am | #5 |
I think you have to be actually creating your post text and have clicked "Go Advanced"
If I'm right, this one should have a red grumpy one. EDIT: Yup, that worked. The pick field isn't there if you just type into the quick reply box. David
2nd Nov 2020, 1:12 am | #6 |
eh
My question was about my Subscribed Threads page, not about starting new threads in Forum Announcements and Comments My image above shows the bottom of my Subscribed Threads page Haven't you got a Subscribed Threads page?
2nd Nov 2020, 1:28 am | #7 |
It is relating to the first post in the thread you are subscribed to. For example, if you were subscribed to this particular thread:-
https://www.vintage-radio.net/forum/...d.php?t=172418 You would have a question mark in the second colum, because the starter of the thread entered a ? icon when starting the thread. I believe they are generally meant to be used by posters to signify graphically the theme of the post, these are the limited options. Clear as mud. Adrian |
2nd Nov 2020, 1:33 am | #8 |
I've never really looked at that, but here's a screenshot from mine.
The left column shows how many posts you had in the thread (hover over it) and the date of the last one, unless the thread is closed. The right one displays the piccy in the thread title, if it has one |
2nd Nov 2020, 10:39 am | #9 |
Thanks guys - a lot clearer than mud now
2nd Nov 2020, 10:45 am | #10 | |
Cheers Mike T
2nd Nov 2020, 11:55 am | #11 |
Have never seen this before and I have nothing in Subscribed Threads.
What is it for and how does it work please ? David |
2nd Nov 2020, 11:59 am | #12 |
I have now found information on it under "Board FAQ" so will have a good read of that.
2nd Nov 2020, 7:13 pm | #13 |
It would be very helpful to move most of my subscribed threads into different folders.
I've created the folders I want to use but how do we move them from the main page? Do you have to subscribe again and delete from the main page?
2nd Nov 2020, 8:26 pm | #14 |
Select the entry using the tick box on the right, then on the bottom banner, move to folder.
2nd Nov 2020, 10:25 pm | #15 |
Brill! Thanks Bill, I'm up and running
It's a 2-stage process, 2nd stage is where you select which folder
