Old 25th Apr 2018, 9:54 pm   #101
Freya
Freya's Avatar
Default Re: First TV Project - Ekco TCG316 - Any Advice Appreciated
L33 & L34 have a resistance of 20 + 8 ohms, from the Ekco sheets. I wonder if you have crossed over the ends of two windings perhaps by accident.
Stephen
Freya is offline
Old 25th Apr 2018, 10:02 pm   #102
Vakito227
Vakito227's Avatar
Yep, all the HT circuitry is shorted to chassis
So far I have traced the short all the way back to - dare I say it - The coil!
I'll keep you posted
Edit: well the good news is the short continues past the coil so the coil can be deemed as okay
Edit 2: I found the short, I soldered one of L34's wires in the wrong place
Edit 3: I took a photo before I removed the old coil and it looks like the old coil was wired in the shorted position too. No idea how or why?
Vakito227 is offline
Old 26th Apr 2018, 6:53 am   #103
beery
beery's Avatar
I can't see why that would be. Maybe the coil from the TMB272 has a different pin out.
It would be a good idea to have another U191 to hand, because after a 'cherry red event' a valve will often have significantly lower emission. Lets hope it still works well enough for you to properly get first light on the CRT.
Andy
beery is offline
Old 26th Apr 2018, 4:59 pm   #104
Vakito227
Vakito227's Avatar
It was wrong to drawing, one of the windings was connected to the wire that goes straight through the middle of the linearity coil to the chassis!
I'm now getting a nice big arc from the U26 anode although the valve itself is still not lighting...
Peter
Old 26th Apr 2018, 5:06 pm   #105
Freya
Freya's Avatar
So its suspect U26 holder or winding breaking down.
You could use an EHT diode in place of the U26, or delve into the U26 holder and wind a new coil using the inner core of coax cable.
Stephen
Freya is offline
Old 26th Apr 2018, 8:10 pm   #106
Vakito227
Vakito227's Avatar
Well I rewound it using inner coaxial cable and the valve does not light, I even tried using the spare U26 I have and still nothing. I can't see how anything is preventing it
ID:	161871   Click image for larger version
Old 26th Apr 2018, 8:26 pm   #107
Freya
Freya's Avatar
With the U26 base disconnected from the the valve, can you measure the ac on the relevant pins. Make sure your winding is providing sufficient voltage.
Take care to to keep away from the u26 pins themselves whilst doing it.
Stephen
Freya is offline
Old 26th Apr 2018, 8:29 pm   #108
1100 man
1100 man's Avatar
Hi Peter,
Well it sounds like there is a lot more energy around now, but maybe still not enough to light the U26 heater.
Can you measure the screen volts and grid volts of the 30P4? Also what does the HT measure now there is a bit more load?
Most important, what are the boost volts?
Double check the wiring & connections to the width, linearity and both line scan coils. Make sure it agrees with the circuit diagram!
Nick
1100 man is offline
Old 26th Apr 2018, 9:08 pm   #109
Vakito227
Vakito227's Avatar
I'm a bit confused about this, isn't the voltage in the winding around 16KV? That would ruin my meter!
30P4 screen = 215VDC
30P4 grid = [-21VDC]
I'm not really sure where to measure the boost voltage so I have a number of values. sorry if it causes any confusion.
Boost cap (LOPT side) 250VDC 660VAC
Boost Cap (HT rail side) 220VDC 500VAC
Old 26th Apr 2018, 9:17 pm   #110
julie_m
The voltage between the ends of the EHT winding (one of which is close enough to earth as makes no odds, by comparison) is very high, but the voltage across the heater winding (one end of which is connected to the high-voltage end) is much less. As long as both connections of your test meter are securely clipped to the heater connections, and you don't touch the meter and there is nothing made of metal within a distance of about a centimetre for every kV, it will be fine.
julie_m is offline
Old 26th Apr 2018, 9:26 pm   #111
Freya
Freya's Avatar
With the U26 disconnected from the valve pins the EHT will not be present on the base, take the U26 away and do the test.
The coil you made only provides the AC needed for the heater which is at EHT potential when connected to the valve.
All HT and Boost measurments should be taken as DC
I think you need 1 extra turn on the winding.
Stephen
Freya is offline
Old 26th Apr 2018, 9:34 pm   #112
Vakito227
Vakito227's Avatar
Sorry I'm still unsure, do you mean the wires I have circled in the picture?
Old 26th Apr 2018, 9:43 pm   #113
1100 man
1100 man's Avatar
The winding that powers the U26 heater is a single turn of wire wrapped round one limb of the transformer. It is not connected electrically to any other winding and is completely isolated. BUT, with the U26 installed, it assumes the potential of the rectified EHT ie 16KV. This is because the cathode of the rectifier is connected to its heater. Therefore the insulation on the heater winding needs to withstand 16kV.
So without the U26 plugged in, there would be no high voltage on the heater winding. However, there would be little point measuring it with a conventional meter as it will have pulses of energy at 10Khz and the meter won't give a meaningful result.
The U26 top cap, which will be dangling in free space without the valve inserted, will have a very high voltage on which would certainly kill your meter!!
Your voltage readings still confirm that the line stage is not operating correctly!!
The boost volts, measured on the LOPT end of the capacitor, (meter set to DC volts) is still way too low: only just above the HT of 220V.
The screen of the 30P4 is too high as is the HT, indicating that the line stage is not drawing enough current.
Until the line stage is working absolutely correctly, the U26 heater will not light as there will not be enough energy induced into the heater winding.
Nick
1100 man is offline
Old 26th Apr 2018, 9:44 pm   #114
Heatercathodeshort
Heatercathodeshort's Avatar
Better to connect a 2.5v torch bulb across the winding you have circled. It should light quite brightly. The heater of the U26 is only 2V.
If the lamp does light I suspect that the voltage correcting resistor inside the base is probably O/C, disconnected or incorrectly wired. It is not a conventional resistor, just a loop of Eureka resistance wire. You may have mistaken it for a short length of non insulated wire. Quite understandable. John.
Heatercathodeshort is offline
Old 27th Apr 2018, 10:59 am   #115
ms660
ms660's Avatar
According to the voltage measurements it looks like there's something amiss with V16's screen circuit, only pulling just over 1mA.
Try connecting a DC voltmeter between the screen's tag on the valve holder and chassis, disconnected V16's top cap and apply power, if the voltage starts to drop below 120 volts switch off immediately.
Lawrence.
ms660 is offline
Old 27th Apr 2018, 1:16 pm   #116
Vakito227
Vakito227's Avatar
I just tried that and immediately after turning it on I heard a loud crackling noise, sounded very ominous not sure where it came from
Old 27th Apr 2018, 1:26 pm   #117
ms660
ms660's Avatar
Lawrence.
ms660 is offline
Old 27th Apr 2018, 1:34 pm   #118
Vakito227
Vakito227's Avatar
Luckily I tried turning it on again and I'm still getting an arc from the LOPT so that didn't go bang, still unsure what did though but I don't think I'll be able to take that measurement right now
Old 27th Apr 2018, 2:54 pm   #119
Vakito227
Vakito227's Avatar
Do you reckon the 0.003 Hunts cap between the 30P4 screen and the chassis is the problem?
Old 27th Apr 2018, 3:11 pm   #120
ms660
ms660's Avatar
I don't know but if it's a Hunts I would replace it anyways.
The measurement I suggested was to see if the screen grids electrode connection was intact.
Lawrence.
ms660 is offline
