Old 4th Oct 2015, 8:58 pm   #1
alm7rom
alm7rom's Avatar
Location: Al-Kharj near Riyadh, Kingdom of Saudi Arabia.
Default Help with National NV-780EM VHS
the problem in this video when i press vtr
its turn on for a second and off. the clock working
what the problem ...
alm7rom is offline
Old 5th Oct 2015, 12:50 am   #2
Clydeuk
Default Re: Help with National NV-780EM VHS
Sorry don't know the model but would suggest worth checking the power supply for bad capacitors. Very common on some Panasonic units. Just a starting point maybe others can elaborate.
Clydeuk is offline
Old 5th Oct 2015, 2:19 am   #3
alm7rom
alm7rom's Avatar
i think it is not in the power
i have another power it's the same problem
alm7rom is offline
Old 5th Oct 2015, 4:54 pm   #4
John123
Not sure if this model has automatic power-up when inserting a tape, but worth trying if it has. Also check the VTR switch isn't sticky or damaged; clean the mode switch; check for dry solder joints.
Regards,
John
John123 is offline
Old 6th Oct 2015, 2:26 pm   #5
dj_fivos_sak
I have the service manual for this machine. This model has a switching power supply since it is 110-240 volt automatic. And it is a multi system too.
dj_fivos_sak is offline
Old 6th Oct 2015, 2:41 pm   #6
Maarten
Try heating the power supply with a hair dryer. If the situation improves while it is hot, it has bad capacitors for sure. If the situation doesn't improve, it can still be anything.
Maarten is offline
Old 6th Oct 2015, 4:40 pm   #7
vhs doctor
When you press the operate button can you hear the capstan motor rotating?
vhs doctor is offline
Old 7th Oct 2015, 12:15 am   #8
alm7rom
alm7rom's Avatar
Yes
alm7rom is offline
Old 7th Oct 2015, 9:32 am   #9
vhs doctor
When the capstan rotates check if the supply reel table also rotate
Old 8th Oct 2015, 7:45 am   #10
alm7rom
alm7rom's Avatar
Yes
alm7rom is offline
Old 8th Oct 2015, 9:39 am   #11
vhs doctor
The second display below the deck (function display) works ok
Old 8th Oct 2015, 9:04 pm   #12
alm7rom
alm7rom's Avatar
Yes work but shut down in second the clock still working
alm7rom is offline
Old 8th Oct 2015, 9:49 pm   #13
dj_fivos_sak
Check the zener diode and the caps in the switching power supply.
Old 9th Oct 2015, 4:19 pm   #14
Libratron
Libratron's Avatar
Check the All Voltage in the PSU.
You need Schematic and SM of this VTR,
to check the voltage's are coeherent with the schematic.
Libra
Libratron is offline
Old 9th Oct 2015, 10:34 pm   #15
ben
ben's Avatar
This is a relatively early front loader from the mid 80s. D deck.
If it's the one I'm thinking of, it has a transformer PSU.
On powerup, the mech should 'shuffle' the reel idler. If this doesn't happen, then the drive belts should be replaced and the mode switch cleaned. That shoud solve this fault.
There was also a resistor of very low ohms/safety type, that used to go high, cannot recall if it was in the PSU or on the main PCB where the voltage lines come in. Will try and find some info.
Regards,
Ben.
ben is offline
Old 10th Oct 2015, 1:51 am   #16
Maarten
I think that one is on the main PCB. At least in the NV-830 and NV-850 which may be related models. R1001 or something close to that comes to mind.
Maarten is offline
Old 10th Oct 2015, 11:10 pm   #17
vhs doctor
You can download the service manual from here
http://freeservicemanuals.info/en/se...sonic/NV780EM/
These type of panasonic/national mechanism (D1) when the VCR operates the mechanism proceed a <<selftest>> the capstan motor rotate the suplly reel table and the loading motor make a small movement (rotation). if the self test find a failure the VCR rotate for a few seconds the capstan or the loading motor (it depends from the failure) and then turn OFF.
Old 11th Oct 2015, 3:05 pm   #18
HamishBoxer
HamishBoxer's Avatar
I believe the person who the machine belongs to has tried another power supply and still has the same fault?
HamishBoxer is offline
Old 12th Oct 2015, 1:11 am   #19
alm7rom
alm7rom's Avatar
thank you all
I will do everything
alm7rom is offline
Old 14th Oct 2015, 4:28 pm   #20
boxdoctor
My money is on the mode switch being faulty or having dirty contacts.
I had a lot of trouble with this series not doing its switch-on 'shuffle' and then shutting down due to the mode switch having dirty contacts. Tony
boxdoctor is offline
