12th Sep 2020, 11:29 am | #1 |
ABS Slot
I need to cut a rectangular slot 12mm x 8mm in an ABS box for a rocker switch.
I'm considering just drilling some holes and clearing out the corners with a small file(s) - anyone one know a reliable source for such a small file(s)? A junior hacksaw blade was my second option? I have a Dremel and did think about using a cutting disk but I had visions of that going very wrong with such a small slot!
BVWS Member |
12th Sep 2020, 12:03 pm | #2 |
Re: ABS Slot
CPC list seven different items under 'Needle Files' https://cpc.farnell.com/w/c/tools-ma...e=inc-in-stock. I'm sure other tool stockists would have them too. Look for 'needle files' or 'warding files'.
Cheers, GJ
http://www.ampregen.com |
12th Sep 2020, 3:49 pm | #3 | |
Re: ABS Slot
Just ordered a set.
BVWS Member |
12th Sep 2020, 4:22 pm | #4 |
Re: ABS Slot
Just done one like that; effortless with my Minidrill (not a Dremell)and a small burr. Couldn't survive without it.
B
12th Sep 2020, 4:24 pm | #5 |
Re: ABS Slot
You're welcome. I've been at this hobby for years and still I sometimes can't find a supplier for the bust thing I'm holding in my hand because I don't know what the people who make it call it . I can remember the days when I'd just show it to the chap behind a shop counter ...
Cheers, GJ
12th Sep 2020, 4:32 pm | #6 |
Re: ABS Slot
Nowadays I normally just use a small slot drill in the milling machine (actually a lathe + vertical slide) but that's not an option for everybody.
Before that I'd drill the corner holes as you suggest but then drill a large (in this case 7.5mm or 8mm if you think you can get the latter accurately enough placed to remove a lot of the waste. Then I could use 'normal' size files (rather then needle files0 to do a lot of the work which I found a lot easier and quicker. |
12th Sep 2020, 5:21 pm | #7 |
Re: ABS Slot
One small hole and a fret saw?
12th Sep 2020, 7:09 pm | #8 |
Re: ABS Slot
I did a largish rectangle in an ABS box for an LCD recently - string of drill holes then an Abrafile to join them up and finished with normal hand filing.
George |
12th Sep 2020, 11:35 pm | #9 |
Re: ABS Slot
I have done most of the above with success. The important part is accurately marking. I stick a sticky label over where I'm about to cut, pencil the outline of intended hole. When satisfied, I LIGHTLY cut through the paper JUST into ABS with a Stanley knife and steel ruler. Once I have removed most of the ABS remove the paper then file up to the knife mark.
For round holes I find a step drill is the best, no tearing of ABS especially larger holes up to around 30mm. John.
My favourite text message "I'll be there in five minutes, if not read again" Last edited by 60 oldjohn; 12th Sep 2020 at 11:46 pm. |
13th Sep 2020, 7:36 am | #10 |
Re: ABS Slot
For my last project that needed a few illuminated rocker switches I used round ones. Made life a lot easier! Marlin did a nice range in many colours both LED and neon.
13th Sep 2020, 9:45 am | #11 |
Re: ABS Slot
Don't file/saw freehand, use a straightedge to define the cut. Vice jaws are ideal but it's usually difficult to clamp a box, or scrap steel bar clamped to your box
- Julian It's good here |
13th Sep 2020, 10:33 am | #12 |
Re: ABS Slot
Don't use a Dremel with a cutting disk. The ABS melts around the cut and you lose accuracy. Been there, done it once. I usually carefully mark out, chain drill and then use a file.
Oh for a milling machine! Craig |
13th Sep 2020, 10:39 am | #13 |
Re: ABS Slot
Stick a piece of paper over the proposed hole and mark out the shape. Then using a 1mm bit in a minidrill drill the corner holes. Drill a line of holes between the corners following the contours of the hole. Then using the side flutes of the drill link up the holes to remove the waste between the holes and the centre of the switch hole can be removed. I have used this method for many years with success. You have to be careful not to apply too much sideways pressure on the drill otherwise it will snap. Also do not allow too much heat to build up as the plastic will attach itself to the bit increasing its diameter. Finish off with a scalpel or file.
Happy drilling, Peter. |
