12th Aug 2020, 5:38 pm | #81 | |
Re: The most horrid connector ever...
The cabin has an appliance inlet, which comes in different ingress protection ratings. The one fitted appears to be an IP44 type which is splashproof but not waterproof. The type with the locking ring and gasket (described as a 'skirt' upthread) is rated to IP67 and is waterproof, which would have been a better choice here, in conjunction with an IP67 socket coupler. Neither type necessarily has a flap on the inlet, if it is not intended to offer protection when unmated. An IP44 type sometimes has a flap, an IP67 type has a cap that locks on in place of the coupler using the locking ring. |
12th Aug 2020, 6:18 pm | #82 |
I cannot stand the massive range of very similar USB plug/socket connectors. It was fine with the original rectangular connectors and the square end for the printer but there seems now to be a multitude of similar but ever so slightly different shaped collars which when you have multiple devices, I always get the wrong one, then find it is 180 degrees out because it is nearly rectangular.
Another vote for Lemo connectors especially when someone has accidentally fitted all of the wrong ones to 20 or more temperature and pressure sensors for an engine to go on test and climbing all over it with a seller soldering iron and base station in an environmental test cold chamber changing them all. Christopher Capener
12th Aug 2020, 7:04 pm | #83 |
I can't understand the dislike of Lemo connectors (and presumably similar types by Fischer, Hirose etc.) They are precision-engineered, high-spec products that perform well under extreme conditions. They can be very satisfying to wire because a very high quality result can be obtained. Our industry (cinematography equipment) runs on them and I routinely wire anything from 6-pin 0B's to 20+ pin 2Bs and 104's. Admittedly the vast range tends to result in large stockholding. I have 500+ different items in inventory that just cover the basics. On the shelf in front of me are 16 different cable clamp types just for one size of connector shell, of one product range, of one brand.
The Lemo 00 was mentioned. This is a highly specialised thing with a connector nose just a few mm in diameter, inside which you can have up to 6 pins, while the 2-pin version is rated up for 5A, withstands 250°C over 5000 mating cycles, with full screening etc. The spacing between the solder buckets is about 0.5mm and requires extra-thin-wall heatshrink and extreme care when wiring, but these are the prices you pay for miniaturisation of a high performance connector. |
12th Aug 2020, 7:29 pm | #84 |
there are some ideas on YT that actually a twisted connection heat shrunk in some circumstances is not such a bad idea , not recomended though for mains + voltages.
12th Aug 2020, 8:02 pm | #85 |
I never had any issues with LEMO-connectors or their familiars; in the 80s and 90s we used them in their thousands for instrumentation/data-collection stuff at Rutherford Labs, Harwell, Capenhurst, Daresbury, Chapelcross and the JET site at Culham - they were reliable! But you needed to stick to the specs and use the right cable with the right plug/socket.
I still have a distinct weakness for CAMAC - https://en.wikipedia.org/wiki/Comput...nt_and_Control and NIM: https://en.wikipedia.org/wiki/Nuclea...ntation_Module and the CATHY / CATEX programming-language we used [running under DEC RT-11 on LSI11/02 or 11/23 hardware] for lab data-acquisition. |
12th Aug 2020, 8:09 pm | #86 |
Lemo connectors are lovely things- inevitably for any connector type that's generally compact and precise they take some care and attention in initial choice and in wiring and assembly. Not something I'd really want to put together in the field, definitely a bench, clamp, magnifier, decent iron job but it would be difficult to find something sturdier and more dependable. You pay for that quality but you get excellent clamping, positive polarising and engagement yet you could drop it off a roof or drive over it and it would barely be marked.
12th Aug 2020, 8:24 pm | #87 |
Insulation Displacement connector or IDC. Only meant to be used once, and in a fixed or semi fixed environment. Anyone tasked with terminating hundreds of wires (or even 10s) will value these over what went before!
12th Aug 2020, 8:24 pm | #88 |
F types. Yes the ones that screw onto the sheath are pretty rubbish. But it's possible to get crimp on ones, and I've been quite happy with those. Prefer them to the Belling Lee ones TBH.
Regarding Lemo, there is no doubt that they are a quality connector. Used widely for various kinds of instrumentation in test I've been involved with. But I do have a beef with them, where they have so many odd combinations of polarisation, pins, and so on. Some of the variations are impossible to source through the usual suspects. There are certain suppliers of equipment that know this, and choose the oddball ones so you have to pay £500 or so for a £20 connector and £3 of cable. After being bitten by this too many times, we ended up getting one of our usual suppliers to agree to get the special order versions direct from Lemo, (yes our purchasing dept wouldn't let us buy directly from Lemo). |
12th Aug 2020, 8:29 pm | #89 | |
12th Aug 2020, 10:42 pm | #90 |
I've found F-Type connectors are hard to line up the threads before tightening, especially as it takes a few turns before you realise you are cross-threaded.
For most of the equipment I with with them I've fitted some adaptors so I don't have to worry about messing up the threads.
12th Aug 2020, 10:57 pm | #91 |
Yes, field wiring for use once terminations are far faster and easier with IDC connectors, thank you lord
I don't suffer from Insanity. I enjoy every minute of it. |
12th Aug 2020, 11:04 pm | #92 |
Scart in their later configuration were pretty horrid for most of the reasons already said, the horizontal 'flatform' types were not too bad, there were though one or two TV types(LG/Goldstar at least) that had vertical types of socket where the most commonly available off-set cable entry types were upside-down and simply wouldn't physically fit !
12th Aug 2020, 11:08 pm | #93 |
I liked the GR connectors. I had a 30cm air line which could be used to check scope timings, it having a delay of one light foot (or one nano second as some folks call it).
My parents house originally had Dorman Smith 13A ring main plugs where the live pin was the fuse. Fine until a fuse snapped in half - leaving one half in the live socket. Stuart |
12th Aug 2020, 11:23 pm | #94 |
Because I have a fondness for GR test gear, I have quite an extensive range of cables, air lines, attenuators and adaptors,
The thing that gets used most often is a 1615A capacitance bridge. That has 6 figures of capacitance and 6 figures of D. The reference capacitors are invar spaced by silica in a dry nitrogen atmosphere. It is a measurement tour de force. Craig |
12th Aug 2020, 11:24 pm | #95 |
I, like quite a few on her no doubt have worked in various industries, I have had my fair share of different plugs and sockets over the years! Hi-rose types could be tricky depending on how many connections and how small, working backwards from the inside out!, Cannon plugs likewise, and yes we have all forgotten the shell! .
One of the scariest was a Stainless steel 50-way connector for Liebherr cranes that carried power and control to motorised head that needed to be rang out to the cores *BEFORE* you potted and sealed it as there was no turning back after, these cost a small fortune (probably more than my weeks wages!) apparently!
12th Aug 2020, 11:50 pm | #96 | |
for 2540 MHz 100 watt magnetron generators for gas discharges. They work very well. The UHF connectors were for frequencies below, usually well below, 30MHz, and what was on the other side was violently not impedance matched. |
13th Aug 2020, 12:27 am | #97 |
For those who hate soldering up Lemos there is a solution - get Lemo to do it. It took me years to discover that they have a cable manufacturing service but, once I discovered it, I had them make up all the cables we used that involved a Lemo connector.
The connectors I hate the most are Burton IE55 underwater connectors - they work fine at the surface and at the bottom of the ocean but they have a habit of leaking and having intermittent connections between about 500 and 1000m depth. |
13th Aug 2020, 12:56 am | #98 | |
I had a terrible time with these and my Airspy SDR radio. Being connected to a computer, grounding is the most important thing. I used expensive satellite cable. It was horrid electrically. I eventually traced the problem to a 2 ohm resistance between ground ends! I cut one end off and measured the resistance connector to shield: 1 ohm! I tried other brands ... none better than 0.5 ohm! This is horrible when you depend on low resistance to actually short out noise. The cable is of course all-aluminum shield so you can't solder. I later tried an identical cable with identical DC resistance on an expensive ($100,000) HP network analyzer. At RF it was simply superb ... no trace of any connector loss or mismatch. Above 30 MHz the capacitave impedance between connector and shield was so low as to be essentially zero. I went to RG-223 (double silver coated braid) and soldered-on quality BNC connectors ... works nicely. |
13th Aug 2020, 4:47 am | #99 | |
The contacts (which are hermaphroditic, so no hunting for a pin or a socket, just grab a contact) are separate from the plug/socket moulding, so there's nothing to melt when you solder them. There is a proper solder-tag contact which being gold-plated solders very easily. But the best feature is the back shell (cover, whatever you call it). It will fit over the cable after you've wired the connector. There is nothing you have to remember to put on first. Which, given there can be 100 or more wires connected to the connector pins is a major advantage. |
13th Aug 2020, 5:22 am | #100 |
The Australian 3 pin plug
Plug per se - take it or leave it, but the horrible push over plastic cover is a right royal pain to both put on and remove without taking chunks out of your hands. |
