21st Aug 2020, 2:52 pm | #1741 | ||
Re: The Audiophoolery Thread.
Before moving into marketing, he was involved in designing spectrum analysers, etc. The network analyser bunch were located up Fountaingrove Parkway in Santa Rosa (currently the HQ of Keysight) while the Spectrum analyser bunch had moved out, needing more space to a new place built 20 miles down highway 101 at Rohnert Park (That place is now a mixture of Nursery (kids) indoor gokarts, truck stop and tomayto farm.) David
21st Aug 2020, 5:35 pm | #1742 | |||
27th Aug 2020, 12:52 pm | #1743 |
I have been pondering new speaker cables recently.
These seem reasonable... https://www.ebay.co.uk/itm/AUDIO-ACO...AAAOSw1RJfQS8Z |
27th Aug 2020, 1:52 pm | #1744 |
Ridiculous.
27th Aug 2020, 2:53 pm | #1745 | |
Huh? I've spent many good years of my life trying to get rid of Wow and to avoid resonances. For the prices I see several of these cables being offered for, I'd fly down and give them 1:1 tuition in how to fix wow and resonance problems. David
27th Aug 2020, 4:22 pm | #1746 | |
Cheers, GJ
http://www.ampregen.com |
27th Aug 2020, 4:41 pm | #1747 |
They can't be totally mindless, can they? Otherwise where did they get £100k from for their last set of cables?
Inheritance? David
27th Aug 2020, 5:12 pm | #1748 |
What's the view here on bi-wiring? Or is that a no no also?
27th Aug 2020, 5:32 pm | #1749 | |
Am now trying to imagine trying to solder one of those wires to a 2 pin speaker DIN plug to use on my old Teleton SAQ-206. |
27th Aug 2020, 5:34 pm | #1750 | |
27th Aug 2020, 5:38 pm | #1751 | |
27th Aug 2020, 6:12 pm | #1752 |
You'll need audiophile speaker DINs, price-matched to the cable.
Bi-wiring is an amazing development. At a stroke doubling the profits of the cable companies. David
27th Aug 2020, 6:16 pm | #1753 |
The sad thing is they actually appear to be serious. There was recently (and may well still be) an 'in joke' on said buying/selling website, where vastly inflated prices were being asked for worn out 2 pence coins from around year 1971. It gave me a laugh, but somehow what i have just seen from the link shown in post No.1743 leaves me cold.. and rather suspicious actually. Enough said.
Dave |
27th Aug 2020, 8:33 pm | #1754 |
Well this would make a nice Christmas decoration to sit in the window.
Make a change from the five illuminated candles we've been using since 1988. https://www.nataudio.com/products/va.../26-magma.html |
27th Aug 2020, 9:24 pm | #1755 |
Snigger!
It's got "Super damping factor" (their underline) It's a single ended monoblock, but it has a "pure symmetric output transformer" High mass output connectors (Um, the output is electrical E-L-E-C-T-R-I-C-A-L, idiots, not mechanical. THe HT even for the output stage is regulated... Um just a minute... I don't see an even bigger tube as the regulator. Does that mean they let Silicon inside it? That'll poison the sound for sure ... and no big heatsink means switch mode! They don't tout that in their brochure. All the power getting to that big choob might have been processed in class D! How can it ever benefit from the right choice of mains cable if that gets done to it? It seems a pair comes in a flight case (130kg) No mention of money, so if you need to ask, it's out of reach. Five of 'em in place of those candles, even only at Christmas might make your room too warm, Mick. David
27th Aug 2020, 9:38 pm | #1756 |
Ah yes, if you need to ask, it's out of reach. Represented as 'POA' in other circles.
27th Aug 2020, 10:21 pm | #1757 | ||
I've serviced a pair of those (strictly speaking, an earlier version, but I suspect they have a lot in common)
Cheers, GJ
27th Aug 2020, 11:48 pm | #1758 |
I reckon they are right !!!
That cable should be perfect for a 1950's set of hearing aids. Joe |
28th Aug 2020, 10:33 am | #1759 |
The advantage is that it allows you to use two different cables for the high and low frequency, assuming of course that you believe different cables can sound different!
I have a pair of bi-wire Heco loudspeaker cables which have four cores - two with a handful of very thick conductors and two with lots of very thin strands. If you plug them into bi-wire capable loudspeakers they sound noticeably better the "correct" way round than the "wrong" way. However, I would agree that bi-wiring with two runs of the same cable is indeed pointless. |
28th Aug 2020, 1:26 pm | #1760 | |
