30th Nov 2020, 2:36 pm | #1 |
Rega Planar 3 motor issues
Hi all,
I'm repairing a Rega Planar 3 which has burnt out its resistor and the 0.22uF cap looks as though it's had a hard life too. I've had this with this type of record player before. Does anyone know the correct value of the resistor? Many thanks. |
30th Nov 2020, 4:45 pm | #2 |
Re: Rega Planar 3 motor issues
There seems to be some confusion as to what the value is on-line. See here..
https://www.vinylengine.com/turntabl...ic.php?t=76108 I have some Boards at work, I will take a look tomorrow and report back. Best wishes, James. |
30th Nov 2020, 5:17 pm | #3 |
I think part of the confusion arises because the resistor value varied according to mains voltage in different markets. Added to this the motor was 'improved' over the years and the resistor's value changed too. From what I can gather the value for the original version of the deck introduced in 1977 was 12k 7W for a 240V UK motor.
Alan |
30th Nov 2020, 8:33 pm | #4 |
Here's mine (not powered for years... )
George |
30th Nov 2020, 8:37 pm | #5 |
Thanks, guys. I've read different values on different forums. The resistor I have starts with a red band.
30th Nov 2020, 10:26 pm | #6 |
Worth bearing in mind that colour bands on hot resistors have a tendency to change shade. Red and brown in particular can often be confused. George's 15k example might be a good guide as the resistor looks unaffected by heat.
Alan |
30th Nov 2020, 11:50 pm | #7 |
On a unit I fixed a few years back I went for 12k. The original was too discoloured to read. As you have found the internet couldn't agree on a value!
30th Nov 2020, 11:53 pm | #8 |
Thanks, I'll go for 15k and a new cap. Why does this fault always happen in these decks? Is there a mod that can put less strain on these components?
2nd Dec 2020, 7:38 pm | #9 | |
Sorry for my tardiness regarding replying to you. I see others have done so adequately. Of the 3 PCB's I checked, removed from otherwise working Decks (where people wanted to 'upgrade' to the 24V DC Motor, I have found.... 10.88k OHM 11.7K OHM 12K OHM I think you'll be OK with a 15K OHM one, these Motors seem to run a little better with a slightly lower Voltage than 'advertised' !! James. |
17th Dec 2020, 12:22 pm | #10 |
thanks for your replies. Can anyone recommend a suitable power rating? Am having trouble finding anything but wirewounds above 3 watts. |
17th Dec 2020, 1:24 pm | #11 |
I tend to agree with James - if you check the speed of any Rega Planar turntable with a strobe you will find that it runs slightly fast. Industry gossip suggests that this was done to make Rega Planar turntables sound a little edgy - don't know if there is any truth in that?
BVWS Member |
17th Dec 2020, 3:44 pm | #12 | |
Thanks for your help. |
17th Dec 2020, 4:07 pm | #13 |
It’s a common problem because of the lack of air circulation in that little plastic cover.. make sure your wire wound is clear of the plastic and not down close to the circuit board.
17th Dec 2020, 8:24 pm | #14 | |
the bearing must have hypoid 90W EP gear oil in it. If the wrong oil is used, eg 3 in one or engine oil, or even EP85/90W synthetic oil, then there is insuffecient shear drag from the bearing to pull the motor down from synchronous speed onto the flat part of its torque curve. having put the correct oil in my bearing and checking the speed with a strobe powered off a calibrated separate ac source the speed was pretty much 33.333RPM at 50.0 Hz supply. with 1.5g tracking weight when playing. also timed 166 turns timed over 5 mins. That said, changing the speed is a ball ache, so I am changing the motor for a cheap chinese 3 speed DC motor so i can play 33/45 at the flick of a switch. The cheap DC motors are actually pretty good, mate in work has one converted and wow flutter and motor noise are A1 |
17th Dec 2020, 8:38 pm | #15 | ||
The applied Voltage though has no relation to the Speed,untill it gets so low it stalls. The Speed is down to the applied supply Frequency. Which is never a constant 50Hz. My comment about running better on a reduced voltage was because there seems to be slightly less mechanical vibrations when run at lower than 230V AC I have never experienced REGA's to run fast. Always pretty accurate when I measure them (about 3 to 4 units a week) James. |
17th Dec 2020, 9:40 pm | #16 |
I agree I rekon with the right oil theyre spot on speed wise at 50Hz supply frequency. the problem with mine was the oil was non existent allowing the motor to run at near synchronous speed which is higher than 33.3 rpm it ran at 34 rpm it is apparently a really common problem.
These aren,t synchronous motors though i think theyre asynchronous so run below synchronous speed except when there is zero load, when they run at near synchronous. The oil gives that tiny load required to make the motor work in its torque band. An asynchronous motor sped up to synchronous speed will draw no current, over speed it and it will generate power and push it back into the grid. they cant work as a motor or generator without some slip. Dropping the voltage will slow the motor down, but no more than a few percent, once slip get over a certain small percentage, as you say the motor will just stall. Last edited by Megatron; 17th Dec 2020 at 9:45 pm. |
17th Dec 2020, 10:04 pm | #17 |
Megatron "That said, changing the speed is a ball ache, so I am changing the motor for a cheap chinese 3 speed DC motor so i can play 33/45 at the flick of a switch."
Can you point me to where I might get the DC motor please.
Chris Wood BVWS Member |
17th Dec 2020, 10:16 pm | #18 | |
https://www.rega.co.uk/dealers |
17th Dec 2020, 10:32 pm | #19 |
Depending on whether you feel its worth the investment, ALL Regas can be converted/upgraded to the current 24VAC spec with one of the factory electronic speed controls, which basically synthesise the AC feed to the motor from a highly accurate frequency generator which is adjustable for those with a sufficiently accurate means of measuring RPM. And speed control at the push of a switch.
Of course there are folk on here clever enough to design and build their own frequency generator and AC feed to the motor. As an aside, as far as I know, Rega never made a turntable with a DC motor. I've had a couple of regas through my hands, an original Planar3 and I also own a well used but loved P7 which has the later motor and PSU upgrade and that's rock solid on speed. Andy. |
18th Dec 2020, 6:22 pm | #20 | |
not a straight swap though, you will need access to a pillar drill and a lathe. you will need to make a larger sub platter or it will be too fast, or you could make a smaller pulley for the motor which will be not much larger than the spindle. also a mounting plate and rubber mountings need fabricating for the motor and a dc supply. I havent done mine yet, but a mate in work has done a few. i ordered a couple of motors last week so we will see how it progresses. https://www.amazon.co.uk/ASHATA-Turn...8311720&sr=8-2 |
