29th Nov 2020, 10:55 am | #1 |
PYE 15A on / off switch
Hi Every one I have just brought an old PYE 15A back to life by changing the old wax caps and valves, working great now but for one small problem the on/off switch won't always work but if I give it a good spray with PMA electrical cleaner leave for a few minutes it will work fine till next time any ideas?
29th Nov 2020, 10:59 am | #2 |
Re: PYE 15A on / off switch
Is it clicking ok but not making contact? Mick.
29th Nov 2020, 11:13 am | #3 |
I had this same problem with a very similar PyeP28. I got around the problem by fixing a miniature microswitch to the switch frame and using the remaining paddle of the original switch assembly to actuate it.
Neil
29th Nov 2020, 11:24 am | #4 |
Thanks for your reply's Mick & Neil Yes its clicking very positive Mick as I say if I give it a good spray it works fine will play all day long till I switch off and back on then nothing. I may well go down the micro switch route if there is no other way thanks for that Neil.
29th Nov 2020, 12:28 pm | #5 |
I had a similar problem with mine, as it's part of the tone control I've not found a suitable replacement so I've bypassed the switch and instead have an external switch on the mains input, until a suitable replacement turns up.
John |
29th Nov 2020, 1:44 pm | #6 |
I had something similar on the Strad PW461 that was on my kitchen table for weeks.
A dead set due to an open circuit (single pole) mains switch, that still had a positive click. I took measurements and noted the position of all wires in preparation for drilling-out the rivets of the switch to examine/clean the contacts, or worst case, appealing for a replacement unit. I had also fitted the new mains cable into the back of the switch. When soldering this I noticed the terminal's solder tag seemed a bit loose on its rivet. Cleaned up around the rivet and ran a thin bead of solder carefully between that and the tag. Not sure if it was this solder that did the job or just the heat of attaching a news mains lead, but the power switch worked well ever since. Can't guarantee it's a method, but may be worth a go? Regards, SR |
29th Nov 2020, 2:44 pm | #7 |
Thanks John & Stewart couple of tips to try there. Best regards Ron H.
30th Nov 2020, 3:46 pm | #8 |
If it is a combined potentiometer with switch, and you are feeling brave, then it is usually possible to separate the 2 halves of the assembly as described here:-
https://www.vintage-radio.net/forum/...0&postcount=36 Sometimes the 2 halves are held together by 3 bent metal tabs, in which case the above tip will often work. However, if rivets are used then you would have no choice other than to drill out the rivets and replace them with small screws and nuts. Screws with shallow enough heads are hard to find but will probably be necessary to avoid fouling the pot wiper. Self tappers are unlikely to work. Jerry |
30th Nov 2020, 5:06 pm | #9 | |
Mike |
