27th Nov 2020, 11:01 am | #1 |
RCA 16X2 Radio
Hello, I know that this radio is not domestic to the UK, but I'm getting quite desperate and thus I'm hoping someone here has an RCA 16X(1, 2 or 3). You see, this radio marks the first time ever I cannot figure out how to get the chassis out!
Many thanks! |
27th Nov 2020, 11:09 am | #2 |
Re: RCA 16X2 Radio
The Radiomuseum has quite a few pictures of this radio, they may help you?
https://www.radiomuseum.org/r/rca_16x2_1.html
The difference between stupidity and genius is that genius has its limits. (Einstein) |
27th Nov 2020, 11:17 am | #3 |
Re: RCA 16X2 Radio
Do the knobs just pull off or are there holes underneath the cabinet for grubscrew access?
Looks like the chassis is retained by screws at the back accessible when rear cover is removed. The set looks a bit like a souped up DAC90!
27th Nov 2020, 6:27 pm | #4 | |
Re: RCA 16X2 Radio
Knobs just pull off and chassis mounting screws are visible after the back is removed. I have the last model produced, 1948. Dave, USradcoll1, |
28th Nov 2020, 5:49 am | #5 | ||
Hi, thank you. What happened was, I had given up, after seeing and removing the two screw bolts that secure the chassis. But later, before I went to bed, I just happened to tip the radio to have a look around, and yes the chassis slid right out. It was just kinda lodged in there.
Hmmm, DAC90. I'll have to Google! Thanks again. Quote:
Funny how things happened... I had removed the knobs and two chassis bolts but the chassis wouldn't come out. Later, I was just handling the radio and out dropped the chassis! Luckily it only dropped as far as my bench top. Thank you again. |
1st Dec 2020, 9:04 am | #6 | ||
Re: RCA 16X2 Radio
1st Dec 2020, 5:20 pm | #7 |
Re: RCA 16X2 Radio
The schematic is located at Nostalgia Air, a US website!
The website contains scan of all the Riders manuals. It's easy to access. Your radio is located in Riders Vol 12, which is around 1940. |
1st Dec 2020, 5:25 pm | #8 |
Re: RCA 16X2 Radio
Have you web site for Nostalgia Air, I get server not found on the links the search engine returns?
Frank |
1st Dec 2020, 5:30 pm | #9 |
Re: RCA 16X2 Radio
1st Dec 2020, 5:50 pm | #10 |
Re: RCA 16X2 Radio
Hi Lawrence, Thank you.
Frank |
3rd Dec 2020, 5:52 am | #11 |
Hi, yes, I have all that. But the radio was made through 1948, and usradcoll1 says he has one of the last ones. So, I was wondering how he can determine if one is an early or late model. I could not find RCA serial number records.
One thing that frustrates me is, the schematic designates numbers for capacitors (C7, etc). However, the parts list does not. Thank you. |
4th Dec 2020, 6:44 pm | #12 | |
Re: RCA 16X2 Radio
You'll have to go through the entire radio and the schematic for the parts values. The only one I have in that series is a" Radiola" branded set, which is a cheaper line, sold at smaller dealers. The circuitry is slightly different using a separate oscillator and mixer tube (valve) instead of a RF amp. It doesn't have a tone control or phono jack. Regarding the age, most post-war sets used the RMA system of code-dates on the parts. Dave, USradcoll1 |
5th Dec 2020, 7:44 am | #13 |
Re: RCA 16X2 Radio
Ah, OK, that explains that. I'm not familiar with RMA. Where would I find product code on the radio, and if I sent product code to you, could you determine the year of mine?
Also, I discovered a very vexing thing. I'm thinking someone prior miswired things. On my radio, 12SQ7 is where 12SK7 R.F. should be. In the schematic, please see 12SQ7's .0018 capacitor, the only one in the radio. In the schematic, it connects from 12SQ7 plate to the tone control. In my radio, however, this .0018 cap is connected from 12SK7 R.F. second grid to the tone control Again, on my radio the 12SK7 is plugged in where the schematic says the 12SQ7 should be. It took me 20 minutes to write that explanation I hope it makes sense Thank you |
6th Dec 2020, 6:22 pm | #14 | |
Re: RCA 16X2 Radio
The 12SQ7 goes in the socket it the right corner, facing the rear and next to the 35L6, per the location diagram. Dave, USradcoll1 |
6th Dec 2020, 8:38 pm | #15 |
Re: RCA 16X2 Radio
Yes, this is what's vexing about it to me. The tubes are in the correct sockets. Perhaps another way to explain this.The first 12SK7 is wired according to how the 12SQ7 is in the schematic; that is, with the .0018 capacitor connecting 12SK7 to the tone control. In the schematic, notice that the .0018 cap connects 12SQ7 to the tone control.
I've managed to get the radio to power on but am getting only a quiet hum, unaffected by volume control. |
8th Dec 2020, 3:33 am | #16 | ||
Re: RCA 16X2 Radio
I've managed to get the radio to power on but am getting only a quiet hum, unaffected by volume control. Brand new power supply caps too...all recapped and re-resistored. |
8th Dec 2020, 5:09 pm | #17 |
Re: RCA 16X2 Radio
You should get a loud hum with the volume control fully CW and your finger on the center terminal of the volume control. This proves that the audio stage is working.
Do you have a meter? Check all voltages against the schematic. The black meter lead goes the B- point for accurate readings. Dave, USradcoll1. Over 65 years of this nonsense? |
9th Dec 2020, 12:17 am | #18 | |
Re: RCA 16X2 Radio
I'm wondering, perhaps a weak 12SQ7. Also, as I've pointed out, the schematic is proving to be of little use. 1st 12SK7 is wired like the 12SQ7 is supposed to according to schematic. My radio also has a 12J6 in place of the 12SA7! Oh, yes, and when I plug in a 12SA7, I noticed the pilot light glowing much brighter. OK, well, I do have another of these radio coming any day now from eBay. Hopefully that radio will be my schematic. Last edited by platescreen; 9th Dec 2020 at 12:30 am. |
