Old 27th Oct 2020, 8:51 pm   #1
Sieco78
Default 1958 Fidelity Monarch HF10 record player. Value?
Hi.
I have a somewhat working 1958 Fidelity Radio Monarch HF10 portable record player.
I believe these to be quite rare. Wondered if anyone has an idea as to its value?
Thanks.
Sieco78 is offline
Old 28th Oct 2020, 9:43 am   #2
Edward Huggins
Default Re: 1958 Fidelity Monarch HF10 record player. Value?
No photo supplied so we cannot assess its condition. It's an early model and likely to use a BSR UA8 Autochanger. If this is still fitted with its original Mono-only BSR TC8H cartridge, it will have a very limited appeal as these will damage Stereo LPs. Mono LPs have not beeen pressed for over 50 years.
Edward.
Edward Huggins is offline
Old 28th Oct 2020, 10:44 am   #3
FIXITNOW
FIXITNOW's Avatar
£5 to £10 I guess as will need restoring but only if the case is in good order.
FIXITNOW is offline
Old 28th Oct 2020, 1:30 pm   #4
Half a Mullard
As mentioned some photos would help particularly if you could take one of the cartridge (the part that rests on the record)
Usually the best prices can be obtained on ebay.,
Welcome by the way!
Howard
Half a Mullard is offline
Old 28th Oct 2020, 2:12 pm   #5
Paul_RK
Paul_RK's Avatar
Nicely styled old thing, I had one a while back which used a UA12 deck and that appears to be the usual type fitted. I'd say up to £50 pre-restoration provided the cabinet looks good.
Paul
Paul_RK is offline
Old 30th Oct 2020, 5:26 pm   #6
Sieco78
Photos added
ID:	219246   Click image for larger version
ID:	219247   Click image for larger version
ID:	219248   Click image for larger version
ID:	219249   Click image for larger version
Sieco78 is offline
Old 31st Oct 2020, 10:15 am   #7
Edward Huggins
Thank for these pics. Yes, I have one exactly the same. These feature an 8" Elac speaker driven by a single stage EL84 + EZ80 amplifier and, for what they are, sound very good. Now I can see what it is, I would value it at £50-00 assuming that it's fully working. It is a rare, very well built, early Fidelity. It also has the rather rare BSR UA12 deck. There are 2 downsides, the green platter mat is missing (replicas cost £30-00) and that BSR TC8H Mono-only cartridge prohibits the playing of most LP's on it - unless the user happens to have a large proportion of early Mono LP's in their collection.
Edward.
Old 31st Oct 2020, 10:37 am   #8
John10b
It appears to have a twisted mains lead, does it use a mains transformer?
John
John10b is offline
Old 31st Oct 2020, 11:13 am   #9
Edward Huggins
Yes, it does with half-wave rectification.
Edward.
Old 31st Oct 2020, 11:19 am   #10
Sieco78
Not to my knowledge my grandfather swapped it .
It just plugs in and plays.
Sieco78 is offline
Old 31st Oct 2020, 12:17 pm   #11
electrogram
I think the transformer is for heaters only
electrogram is offline
Old 31st Oct 2020, 12:31 pm   #12
John10b
Thank you, perhaps my question was too vague.
John
John10b is offline
Old 1st Dec 2020, 2:37 am   #13
avalon.design
Default
Good evening I’ve just bought the same record player
ID:	221588   Click image for larger version
ID:	221589   Click image for larger version
ID:	221590   Click image for larger version
avalon.design is offline
Old 1st Dec 2020, 9:03 am   #14
Station X
Station X's Avatar
Very nice.
I don't suppose the instruction leaflet contains a circuit diagram?
Graham. Forum Moderator
Station X is offline
Old 1st Dec 2020, 10:00 am   #15
Edward Huggins
Well, it's not quite the same. Yours is the EXTREMELY rare Stereophonic version. This will have a different amplifier, possibly a 2 stage type.
Edward.
Old 1st Dec 2020, 10:04 am   #16
Ekcoman
Ekcoman's Avatar
I would have thought the cartridge would be worth around half the value of the record player if fully working. So adding the cost of replacing the rubber platter and cartridge could prove costly. At a guess around £50-60 costs and that's not taking into account any work required on amp. My value would be £10 - £20.
"I really am seriously downsizing "
Ekcoman is offline
Old 1st Dec 2020, 11:47 am   #17
avalon.design
Hi. Thank you for the replies is it is working but no sound.
I will be selling it elsewhere.
Thanks for all your advice.
Old 1st Dec 2020, 11:48 am   #18
avalon.design
Originally Posted by Station X View Post
Very nice.
Good morning Graham I will check for you
