23rd Oct 2020, 5:26 pm | #21 |
Re: Heatsink compound - refresh or not?
I'd say, if in place, leave it! Unless replacing the transistor anyway.
It's there to fill voids. And the compound is powdered zinc or aluminium oxide, good as a thermal conductor, and which needs an additional substance to make a paste but which can, in principle, slowly evaporate or otherwise migrate away leaving the active particles trapped where they need to be. Me too! And it's not cheap either. So only used where its performance could be justified, which is in a low-capacitance or high-voltage insulator, which needs to be thick for those reasons, and hence where excellent thermal conductivity is important. |
23rd Oct 2020, 5:44 pm | #22 |
I 100% agree with this ^^^ Kalee20
No point disturbing existing circuitry unless it it needs to be disturbed for whatever reason.
I don't suffer from Insanity. I enjoy every minute of it. |
23rd Oct 2020, 10:50 pm | #23 |
Arctic silver could possibly be problematic, as it may be somewhat conductive. I only use it when there's not insulation between the device and the heat sink. I use the regular white alumina compound when insulation is needed.
23rd Oct 2020, 11:01 pm | #24 | |
23rd Oct 2020, 11:04 pm | #25 | |
23rd Oct 2020, 11:16 pm | #26 |
It's not conductive at all. Have independently confirmed it up to around 400V.
24th Oct 2020, 10:57 am | #27 | |
Perhaps they're not made from BeO then. Please see attached pics. I think the TO-220 thin ones came from a Philips VR2020 PSU. The thick TO-220 spacers were possibly from miscellaneous parts obtained from Sendz components back in the 1980s. The pink TO-220 spacer came from I believe an ITT CVC40 CTV. On that chassis, the line output and chopper transistors plug in and I seem to remember the thick pink heat transfer spacer. Are they safe to use? Regards, Symon |
24th Oct 2020, 1:14 pm | #28 |
I can't find my reference books from my Army days with reference to this but there was quite hefty warnings about BeO heat sink compounds used in some radio equipment that I worked on.
I have it in my mind that the relevant radios were from the USA. One that does come to mind is a GRC-106 transmitter/ receiver and RTTY modem. I am talking about 1960s sort of stuff. "Let sleeping dogs lie". My thoughts are that heat sink compound is used to fill minor voids between a component and the heat sink. The original application of heat sink compound should have been enough to do the job. If I have doubts about that then I will replace the compound. Especially when other components within the same device are showing heat stress or failure. As stated by other posters it is the solid component that does the job and not the grease part. One other thought is that to get to the stage where it is possible to replace the heat sink compound yo9u have to sometimes disturb quite a bit of circuitry and this, on old stuff, will generate it's own dramas. "Been there, done that". When the lead snaps off the un-obtanium transistor because I wanted to replace the compound. "Oh why on earth did I want to do that for"!!!!!!!! Much swearing. Just my thoughts. Cheers, Robert. Last edited by QQVO6/40; 24th Oct 2020 at 1:30 pm. Reason: Added more info. |
24th Oct 2020, 1:51 pm | #29 |
24th Oct 2020, 7:03 pm | #30 |
I don't know for sure out what material the pink ones are made, but BeO wasn't used in simple consumer electronics due to high cost, being hazardous and not needed for the purpose. Philips used those ceramic plates in a lot of consumer electronics and they're almost certainly alumina.
24th Oct 2020, 7:20 pm | #31 |
Hi.
That's more reassuring. Yes, I've encountered many of those thin white heat tranfer plates in various Philips TVs etc. It does seem reasonable, for run-of-the mill consumer equipment, to not generally use pads made from beryllium oxide, not just on safety grounds but cost as you point out. Regarding the pink TO-3 pad, probably from an ITT CVC40 CTV, then best to err on the side of caution and not to use it. It would be good to find out if it is BeO though. Thanks for your reply. Regards, Symon |
24th Oct 2020, 8:04 pm | #32 |
Years ago when I was building and repairing computers, replacing heat sink compound was often the repair.
About a month ago, my wife's laptop started playing up, slowing, restarting etc. I added some RAM, fitted an SSD hard drive, but the fault persisted. Eventually, I removed the micom's heatsink, cleaned it and the micom, added a small quantity of HSC, saved from my pre-retirement time and replaced the heat sink. It has not missed a beat since. If I have a transistor out for any reason, and it has old, dry HSC, I replace on sight. Les. |
24th Oct 2020, 11:04 pm | #33 |
Beryllium oxide heatsink insulating washers are perfectly safe to use, and perform well. The problems occur if you start grinding them up or otherwise creating particles. Beryllium and human body chemistry are just incompatible. So, disposing of them is a responsibility, going into the crusher is just a no-no.
They're unlikely to be used except in specialised equipment owing to cost. AFAIK the only electrical insulator that is a better heat conductor than beryllia, is diamond - which has no adverse effects on health. Down side is it's difficult to saw into slabs - and it's even more expensive... |
25th Oct 2020, 1:04 pm | #34 | |
I quite agree. I wouldn't dream of just putting them out for the dustmen. I always take any hazardous/potentially hazardous components/chemicals to the recycling centre where they have a facility to accept chemicals etc. As is obvious, any such items should be clearly labelled. I also take old faulty components, other electronic scrap, and also batteries for recycling rather than placing in the bin. Regards, Symon |
25th Oct 2020, 3:51 pm | #35 |
You might find that you need specialist handlers for BeO. The local recycling centre here refuses a lot of stuff.
25th Oct 2020, 7:17 pm | #36 |
I searched for pink alumina and found this: https://alchemymineral.com/pink-aluminum-oxide
The pink stuff might contain chrome, which is also unhealthy when you chop it up and breathe it in, but significantly less unhealthy than berillium. I've seen similar stuff used in the antenna on household magnetron tubes as well. |
25th Oct 2020, 7:21 pm | #37 | |
25th Oct 2020, 7:54 pm | #38 |
Hi Maarten.
Thanks for the link. I've been trying to find any information on pink insulating pads and came across this https://www.silicon-ark.co.uk/discou...ulator-alumina which appears to be the same as mine. So pink alumina exists after all, you learn something everyday! I was aware about the pink insulating material on magnetrons which I believe is beryllium oxide. It would seem fairly likely then, that ITT would not use beryllium oxide in their late 1970s television receivers. So I think I'll use the T0-3 pad for a project. Regards, Symon |
26th Oct 2020, 11:21 pm | #39 |
I was looking at this circuit a couple of days ago, a mid 1980s ITT Prestel decoder, you can see my hand-written annotation I made on the training course.
The big distinction of course, it referred to the BeO inside the device package.
-- Graham. G3ZVT |
26th Oct 2020, 11:28 pm | #40 | |
B
