Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval. |
27th Nov 2020, 12:01 pm | #1 |
Forum time?
Don't know if its me or the forum but posts are appearing with the time of post marked at an hour ahead of the actual time.
Kevin |
27th Nov 2020, 12:04 pm | #2 |
Re: forum time?
Unless you made this post at 10:01 its showing correctly for me at 11:01
Cheers Mike T
27th Nov 2020, 12:09 pm | #3 |
Re: forum time?
It's probably worth checking in your profile what time zone you have set. If you're set to Central European Time (or whatever it's called) you will be one hour ahead.
27th Nov 2020, 2:05 pm | #4 |
Re: Forum time?
The forum operates internally on GMT and adjusts what you see according to your local time zone as stated in your profile.
28th Nov 2020, 12:54 pm | #6 | |
Re: Forum time?
Regards David
http://www.youtube.com/ My Nixie Clocks |
29th Nov 2020, 10:01 am | #7 |
Administrator
Re: Forum time?
If you are logged out it follows the software default. That was GMT+1 but I have changed it to GMT, which will be wrong in the summer but at least makes sense.
29th Nov 2020, 3:33 pm | #8 |
Re: Forum time?
This was bothering me recently until I discovered that the device I was using was not actually logged in as me. It corrected itself after I logged in.
I was going to post about it but discovered just in time that it was a self inflicted problem. That won't be true in every case but at least be warned - it happens as mentioned in Post #6 above. |
29th Nov 2020, 3:42 pm | #9 |
Re: Forum time?
You could write a little script to set GMT/BST as appropriate, but it's probably not worth bothering about.
29th Nov 2020, 5:37 pm | #10 |
Re: Forum time?
At least if the default is GMT, that is equivalent to Universal Time (UT), which is an international standard used in some circumstances (where time zones are inappropriate).
29th Nov 2020, 11:29 pm | #11 | |
Administrator
Re: Forum time?
