Old 21st Sep 2016, 5:24 pm   #1
FRANK.C
FRANK.C's Avatar
Default David Robinson's System A modulator
Hi All
This is my attempt at building David Robinson's System A modulator which covers all 13 Channels. The original threads are here and here
Both Audio and Vision modulators are the same as David's. The only change that I made was to simplify the audio input as I don't need the separation between left and right channels that David did. There was some debate about whether the 3.5 MHz filter was necessary or not. I decided to keep it, the coil the David used is no longer available, I used a 'Mini Mod' transformer in it's place and it works quite well.
I have made some changes to the Microcontroller side of things. I am using a 18F1330 Microcontroller. The I2C buses for the two modulators now share a common clock. The microcontroler produces a very basic test card and an audio tone of approximately 300Hz which are fed to the modulators via switched phono plugs. When a Video or Audio plug is inserted into a Phono socket the test card or audio tone is disconnected.
I made a PCB for it which made assembly of the SMD's much easier. The PCB is double sided with one side used solely as a ground plane. The PCB was produced using the laser printer method which left the copper pitted but it is still acceptable.
Frank
ID:	130354   Click image for larger version
ID:	130355   Click image for larger version
ID:	130356   Click image for larger version
ID:	130357   Click image for larger version
FRANK.C is offline
Old 21st Sep 2016, 5:26 pm   #2
FRANK.C
FRANK.C's Avatar
Default Re: David Robinson's System A modulator
And this is the circuit.
FRANK.C is offline
Old 22nd Sep 2016, 10:23 am   #3
HamishBoxer
HamishBoxer's Avatar
Very tidy job I note and looks good results on screen.
HamishBoxer is offline
Old 22nd Sep 2016, 3:17 pm   #4
Dave Moll
Dave Moll's Avatar
Unfortunately, when I attempt to access the circuit PDF (using Acrobat Reader XI), it results in just the bit of image shown below, along with the error message also shown.
ID:	130394   Click image for larger version
Name:	Acrobat error.JPG
Dave Moll is offline
Old 22nd Sep 2016, 3:40 pm   #5
ntscuser
ntscuser's Avatar
Very neat, very professional looking. Well done!
Classic TV Show Theme Tunes
ntscuser is offline
Old 22nd Sep 2016, 6:26 pm   #6
FRANK.C
FRANK.C's Avatar
Thanks for the comments.
It preforms well, David did a good job in designing it. Been able to switch between channels is handy particularly when you have both London and Birmingham sets.
Dave
I don't know why it wont open for you. I have just downloaded it and it opened OK, I am using Foxit Reader.
I printed it using "Foxit Reader PDF Printer".
Maybe Acrobat Reader don't like Foxit?
I have taken 3 screen grabs of the circuit and attached them.
Frank
ID:	130405   Click image for larger version
ID:	130406   Click image for larger version
FRANK.C is offline
Old 22nd Sep 2016, 7:41 pm   #7
Dave Moll
Dave Moll's Avatar
Thanks.
Old 22nd Oct 2019, 12:51 pm   #8
AC/HL
AC/HL's Avatar
Reopened by request.
AC/HL is offline
Old 22nd Oct 2019, 12:59 pm   #9
FRANK.C
FRANK.C's Avatar
Bill, thanks for reopening it.
I have built a second version of this modulator and have made some changes to it.
I have changed the test card to one in the style of a PM5544, I have moved the audio gain control to the front panel and have fitted toggle switches for selecting test card and test tone.
If anyone would like to build one all the files that are required can be downloaded here.
Frank
ID:	192234   Click image for larger version
ID:	192235   Click image for larger version
ID:	192236   Click image for larger version
FRANK.C is offline
